Old 04-03-2024, 05:23 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Default Directional cam
In taking the column apart to confirm the cam is bad. I noticed the two prongs bent over. Where are they supposed to go? I’m sure not like that. lol. Also in replacing the cams. Does all that harness come out too ? Replacing worn ignition switch while I’m in there.
ID:	631519   Click image for larger version
Send it! It’s going home on a trailer.
Old 04-06-2024, 12:05 PM
Peter Serio's Avatar
Those 2 prongs are part of a plastic/nylon switch that goes over towards the key cylinder. It is made that way on purpose so that if you leave the key in the column and open the door to exit the car a buzzer sounds. They complete a circuit on the reverse side of the TS switch, you can see the 2 touch "pads" in your photo #2. (One black wire and one pink wire.)
Peter Serio
Owner, Precision Pontiac
