Old 04-07-2024, 02:01 PM
form74's Avatar
form74 form74 is online now
Default Which Carb base gasket Quadrajet to RPM
Choices are 2 hole vs open.
What’s Correct / Best
ID:	631736   Click image for larger version
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
Old 04-07-2024, 02:23 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Whether you go 2 hole, 4 hole or open you need a spread bore gasket not the ones that you show in the pic which are for square bore intake/carb.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
The Following User Says Thank You to prostreet64 For This Useful Post:
Old 04-07-2024, 03:01 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
4 hole Quadrajet, insulating 1/4” . Just my preference.
Old 04-07-2024, 04:20 PM
Like Bill said, the 1/4" insulating gasket is a good choice. That is what I used on my 403 with a q-jet on top of the RPM intake. I know Cliff has these for sale.
