Old 03-29-2024, 11:37 AM
JLMounce JLMounce is offline
Oh a physical vacuum modulator, that's cool. As opposed to being commanded by an ecu.
I should have guessed that from the pictures on the first post. It's clearly visible.
What are you using for the intercooler pump?
-Jason
1969 Pontiac Firebird
  #102
Old 03-29-2024, 07:35 PM
darbikrash darbikrash is offline
It’s a Bosch brushless electric water pump, flows 6 Gpm.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
  #103
Old 04-18-2024, 07:40 PM
So it was back to the dyno last Tuesday for round 3 of the blower wars. This time I think we got a decent outcome and I am very happy with the results.
There were several differences and upgrades from the last effort, where we were plagued by high speed miss issues which I attributed to ignition problems coming from the dual sync distributor. This is both puzzling and disappointing, as I have a dual sync on my ’69 GTO and have not had issues with it, but here we are.
The fix was to switch to an external crank trigger, and just use the dual sync to fire the coils and provide the cam signal. This turned out to be the correct move as virtually all my issues went away, and it was apparent from the first few pulls that this was a very different engine.
Originally, I had 3D printed all the crank trigger mounting brackets and hardware using a high temp material, but I discovered that one of the 3D printed parts (throttle body spacer) had softened during the previous dyno run and had loosened to the point where a bolt actually fell out inches from the throttle body intake. So I took all the 3D printed parts out of the motor and remade everything out of billet aluminum.
The plan was to start with the smallest (boost -largest diameter) pulley and work my way incrementally into the higher boost numbers.
We did not quite make the 700 hp number I was looking for, but the torque was just ridiculous.
So here are the results:
- 5 psi (lowest boost pulley) made 546 HP 5300 rpm w/643 TRQ
- 8 psi boost, made 611 HP 5300 rpm w/685 TRQ
- 11 psi boost made 656 HP 5300 rom w/784 TRQ.
These were pump gas pulls, after the last torque number we put some better gas in, ~100 octane.
After that, the smaller pulleys started to show belt slip, so we did not get any full pulls on the higher octane, but we did see a 817 TRQ number before the belt started slipping.
Next steps are to get some Grip-Tek pulleys, I’m kind of kicking myself for not buying a few and bringing them just in case.
Keep in mind this is a stock 2 bolt main block with a factory cast crank, and perhaps the worst flowing cylinder heads (cast iron 4X, untouched) possible, so I feel this is a great result and clearly with regard to torque we are reaching the limits of the factory block.
A better head with say 300+ cfm flow will make a bunch more power at lower boost due to improvement in restriction as compared to the 4X heads.
But the goal of this project was to see what could be done for the guy with cast iron heads and a stock bottom end- making power with cylinder pressure and not RPM.
This time I set up a different (identical) blower with the fuel rails mounted externally, just to test this configuration. It worked well and there was no difference between this configuration and the previous config with the fuel rails and injectors mounted underneath in the valley. Note the stock valve covers LOL.
Some data:
Partial pull with belt slip. Take a look at that torque number before the belt slip kicked in:
The Following 3 Users Say Thank You to darbikrash For This Useful Post:
  #104
Old 04-18-2024, 08:27 PM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
Definitely interested . Would love to do this to my 78 TA. Just have to figure out how to get a shaker attached to the top of the blower
Atoll Blue, Blue interior, 1970 RAIV Judge/4 spd/ 3.90/ pwr steering/ pwr brakes/ hoodtach/ gauges/ sport wheel/ console/ remote mirror/tinted glass.
Starlight Black, Camel Tan interior, 1978 Trans Am . Auto/AC/door edge guards/ am/fm, Cassette stereo/ floor mats frt and rear/Hurst Hatches
Cameo White, Blue interior, 1971 Trans Am/4spd/ Am/Fm/ power windows / AC. 28,000 original miles
  #105
Old 04-18-2024, 09:27 PM
Incredible results - Really incredible
Congratulations on your work !
  #106
Old 04-19-2024, 12:20 AM
R 70 Judge's Avatar
Awesome job! Those torque numbers are ridiculous. Any car with this combo will be super fun to drive
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
  #107
Old 04-19-2024, 02:26 AM
65 Lamnas's Avatar
This must be eyeball-flattening torque....
  #108
Old 04-19-2024, 09:18 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
This would be my setup for my next build. Congratulations, but more importantly, thank you for all your dedication and hard work. This is a fantastic win for the entire Pontiac community.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
The Following User Says Thank You to 73LeMans For This Useful Post:
  #109
Old 04-19-2024, 09:56 AM
* Reinforced seat mounting suggested
  #110
Old 04-19-2024, 10:02 AM
Those are fantastic numbers for this combo!
-Jason
  #111
Old 04-19-2024, 10:31 AM
gtospieg gtospieg is offline
Turbo LS what?...Awesome to see what can be done to a real Pontiac engine.
  #112
Old 04-21-2024, 05:18 PM
I've had a chance to dig into some of the Holley EFI datalogs from the dyno session earlier this week, and though I'd post up some of the plots.
This shows engine vacuum at idle converted to inches of mercury. This is a pretty docile engine to have 17" of vacuum:
This one shows the total timing under boost, we were at 28 degrees for the entire time.
The Following 2 Users Say Thank You to darbikrash For This Useful Post:
  #113
Old 04-22-2024, 12:35 PM
Thanks for providing these graphs. I think what this shows is the true potential of what this type of system provides.
At 8psi, which I think is a great baseline here and around where a lot of people would run the system, you are producing at or a bit over 600hp. Some would say, you can build a 600hp 455 for cheaper and keep it NA. That's true, it's only 1.3hp/cid after all. The difference here is that the blown setup is going to be far more docile around town in normal cruising. Yeah it's probably going to be more expensive going this route, but you get to have your cake and eat it too.
-Jason
  #114
Old 04-22-2024, 04:04 PM
Thanks for your feedback, and I agree.
The baseline run N/A with a carb made 419 HP, so the supercharger made +50% more power- with a disproportionate increase in torque. Not many 600 HP engines are making over 800 ft/lbs. which goes to the overall drivability and "seat of the pants" performance much more than HP.
One of these will be in a street car soon, so we will have some real world feedback as to drivability, which I expect to include instant boost, unlimited torque anywhere in the powerband, and the ability to use high (numerically) low rear end gears with no overdrive transmission needed for street driving.
Not sure yet of the cost comparison to get the same HP N/A. Pretty sure you'll not get the same torque regardless of money.
The TVS head unit is capable of over 1000 HP with the right combination- but that was not the goal of this particular build.
There is still more work to be done.
The limiting factor in this build was the cylinder head. On a good day, these (untouched) 4X heads flow ~205 cfm. On the subject of boost what you are really seeing here is better stated as a flow restriction- which shows up as measured boost. The name of the game is airflow not boost.
As a next step, a better flowing cylinder head is already in the planning stages.
Anyone care to speculate what this combo will produce with a 310 CFM head allowing 50% more airflow as compared to the 205 CFM 4X heads?
Stay tuned, but in the meantime the casting tooling is underway and I am working to simplify the ignition, refine the tune to make this as close to a thoroughly tested and validated system as I can.
  #115
Old 04-22-2024, 04:40 PM
I'd love to see it with out of the box D ports. I run a set of as cast KRE D-ports and they were impressive enough of a gain over my untouched #62's. Even at around 260cfm on the intake as advertised, I would assume 8psi would gross somewhere close to 700hp. In the real world I would bet on somewhere around 670.
-Jason
  #116
Old 04-22-2024, 04:50 PM
Agreed.
In Post 103 above we showed a best of 657 HP (first graph) on the 4X heads with the pulley slipping. I'm confident that had we not had the pulley slip we would have touched 700 due to the higher boost. Those heads flow 205 cfm, give or take, and I would hope that a 310 CFM flow number would result in substantially higher HP at a lower boost number due to the lack of restriction.
The Following User Says Thank You to darbikrash For This Useful Post:
  #117
Old 05-29-2024, 05:11 PM
JC455 JC455 is offline
Any updates on this?
John
IG: @crawdaddycustoms
  #118
Old 05-30-2024, 04:31 AM
Drag Star Le Mans's Avatar
Stout numbers for the combo you have. I'm sure you have many thinking of a combo like this.
DragStarLeMans
  #119
Old 05-30-2024, 11:19 AM
I’ve delivered one of the superchargers and it will be in a car soon. In the meantime, I’ve been busy developing the 6 rib serpentine accessory drive for Type II PS pump and a 140 amp alternator.
I’ve seen aftermarket serpentine systems for Pontiacs with no belt tensioner, and I’m not at all sure of the advantage of going to a serpentine if you don’t have the auto tensioner, so I put one in.
This system has the dedicated 8 rib to drive the blower, and the 6 rib accessory drive for the alternator and power steering. Both have dedicated tensioners. I also plan to add AC in the next revision of the drive plate. AC will be a small Sanden compressor on the passenger side of the engine. The belt routing has been designed to accommodate this. I’ll post up some photos of the accessory drive with the 3D printed mock up parts as soon as I get some time.
The plan is to schedule another day on the dyno to test the motor with a set of higher flowing heads to see how much HP can be made with a typical low compression engine. I think this will be later this summer.
I met with the foundry last week and they are moving along nicely on the casting tooling, so we should see some prototype castings later this summer.
I am also working on an online web store, which should be up in a few weeks showcasing all the various products related to the supercharger project.
  #120
Old 05-30-2024, 11:33 AM
<add to cart> 🛒
The Following 3 Users Say Thank You to kingbuzzo For This Useful Post:
