Old 06-02-2007, 10:41 AM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
Default 69 cruise control and 70, differences?
I was told years ago they are fully interchangeable and work on both years but something is visually different on a 69 unit compared to the 70, anyone know?
Old 06-02-2007, 11:33 AM
Chiefpontiac's Avatar
Chiefpontiac Chiefpontiac is offline
Mark,
They differ in where the bellows is attached and how it "pulls" on the throttle lever. The '69 bellows is mounted on the engine and attaches to the lever with a chain. The '70 and up bellows is mounted on the fender well by the transducer and uses a cable that attaches to an extended pin on the throttle lever.
I actually need the '69 bellows setup and throttle lever for my '69 Firebird.
Aut viam inveniam aut faciam
1971 Trans Am 455HO M22; Cameo White / Blue
1971 GTO Convertible 455 M40; Starlight Black / Black
Old 06-02-2007, 04:44 PM
68 is fender-mounted.
I JUST got a fender-mounted cruise setup from a 70s-80s Caprice (all I can say for the YEAR is it was a V8 with missing Q-Jet and had the newer fuses).
Certainly different from 1968, yet it is remarkable nicer than the similar year technology from 425CID Caddilac with Q-Jet & telescopic Tilt column, that mounted the Cruise bellows on the Valvecover.
Point is: The 68 cruise needs the speedo cable coupler/tap, while the Caprice Fender unit & Valvecover Caddy unit BOTH use a sensor at the speedo head to catch reflections from a bright reflection off the speedo bell. 2 reflections/turn. That keeps the speedo cable pretty clean.
In all cases there was the simple Cruise lever, rather than the clunky plastic lever. FWIW, I think the modern cruise CONTROLLERs can be an upgrade over the vacuum-break mechanical controller of 68 69 70.
A savy look would be that simple fender-mounted bellows, with the vacuum break hose going to the brake pedal, THEN use the modern GM controller to electrically vector the simple bellows. Result is cleaner speedo cable routing is retained.
Old 06-03-2007, 09:34 PM
Originally Posted by Chiefpontiac
Mark,
Bang on, the 70 system is better than the 69 one but will not look right if you are fussy.
Had cruise on a 69 GP 4 speed car back in 1990 or so (dealer installed 4 gear) and I remember driving to the POCI meet in Clevland on I-90. Had the cruise on at 90 or so and pulled into one of those New York State Thruway pitstops for fuel (a common occurence in a 428HO at 90MPH). Imagine my surprise when the engine decided to maintain the throttle position needed for 90 when I pushed in the clutch (more than enough RPM for mega disintegration of my engine). To save said engine I re-engaged the clutch but could not slow down enough with 465 foot-pounds wanting to go forward so I killed the ignition but it was reving so high it kept running anyhow (dieseling). I Finally got it to stop with a sudden release of the clutch in reverse gear (at too high a speed to admit) that almost lauched us through the windshield (that's what seat belts are for?).
Almost fried the motor and the brakes, nearly wrecked the car, why? That damn criuse chain had come loose and snagged the throttle linkage. luckily the only real damage (other than fried nerves) was that the A/C belt jumped. Being 95 degrees that day we took the time to re-install the belt (a rather unpleaantly warm job) rather than sweat over those nice leather seats.
Never did put that cruise chain back on the car.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 06-04-2007, 11:15 AM
Thats a very scary story John. I have been debating about adding the option but when I hear stuff like this it makes me think twice.
Old 12-30-2022, 12:50 PM
compsur's Avatar
compsur compsur is offline
Was noticing this thread and thought it would be a good one to jump on and pick some brains. I am scratching my head as it goes to the differences with regulators used from 67 and on. The parts books and PY online state:
1. Parts book state 67-68 uses 9787978 (Black Decal), shows up in PY online parts lookup.
2. Parts book state 69-72 uses 9797504 (Black Decal) does not show up in PY online parts lookup.
3. Parts book state 73-74 uses 490099 (Not sure about decal color), shows up on PY online parts lookup.
I also found the following Pontiac labeled Regulators for sale on Ebay:
1. 493406 (Blue Decal), not in any Pontiac parts book or PY online.
2. 498586 (Red Decal), not in any Pontiac parts book but does shows up on PY Online stating for 73-75 all.
3. Ames shows a decal for 69 only, with decal part 498556 printed on it, not in any Pontiac parts book or on PY online.
As you can I am thoroughly confused...how do all these parts cross reference, if at all, can the most common one 9797978 be used up to 1975, can 493406 and 498586 be used going back to 1967..what are the differences....each have the 2 wire connection.
Then there are the 3 connectivity regulators but i think they are only applicable to Lincoln, RR, International and Olds also used 3 wire units.
1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles
1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles
1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles
1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles
Old 12-30-2022, 03:59 PM
Sparky the GM Cruise Control engineer, kept discovering improvements.
Old 12-31-2022, 05:15 PM
gto4evr gto4evr is offline
I think Sparky was a bit slow on the improvements! I always thought my 71's cruise was a bit twitchy and assumed I had an intermittent switch. I figured out on my own it would work when I let go of the button slow but was 50/50 when I'd just hit it quick. I just came across this bulletin while updating my TSB spreadsheet.
The Following User Says Thank You to gto4evr For This Useful Post:
Old 12-31-2022, 10:06 PM
compsur's Avatar
Exactly....wondering what they were!!
Old 05-04-2024, 11:02 AM
compsur's Avatar
Today one can purchase repo bellows with the ringed spring, is the the center spring that pushes out in the center of both end plates still needed? Not certain the ringed spring replaced the internal center spring or both are needed?
