Where to get original GM paint colors mixed as single stage urethane?
I would like to cheapo garage re-spray my 62 wagon. It is belmont red poly. Metallic maroon basically.
Ive done this a few times and Im comfortable with my paint gun, and urethane single stage. Ive used both Eastwood and Summit paint with solid results for the situation. I could get something close from one of those brands, but Im lazy and I really dont want to have to re-spray the door jambs to match. So I really want the factory color here. But again Im comfortable spraying that type of paint with my equipment. Is there anywhere that I can give my paint code too (WA2670/PPG 50568) and get a gallon of it mixed as a urethane single stage? https://paintref.com/cgi-bin/paintde...oogle_vignette
Maybe try these guys:https://www.autocolorlibrary.com/pag...2-Pontiac.html
Most of the Eastwood urethane paints I've used are 4:1. I have used it a little, but its clearly not exactly the same. So its an option, but Im a little leary of the difference in mix ratios, there is something different there. It is an option though. Maybe a paint expert can tell me what the difference between the products are and if I should care about it.
You might try the local O'Reilly's IIANM O'Reilly's corporate picked up the Dupont Nason 2 k urethane line
Now under the Axalta brand Shot a few cars in it, been a few years but it gets hard and has very good gloss retention. I am not sure if they order it in or if like some stores can mix in house. You are a braver man than me with shooting single stage Poly , getting older, going to stick with base clear because of the ease of getting the metallic even.
1984 RX7 Jim Hand style 455 /200 4R Project car 67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold. Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed, Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post Last edited by 455dan; 06-13-2024 at 07:04 PM. |
I tried to find that product on their website, but couldn't. I will stop in and ask them about it though. Seems worthwhile. I did find a page that says they do custom paint mixing but it didn't say what the options were as far as product.
Automotive touch up dot com will most likely have what you need. They have colours available from touch up lipstick size to gallons. Their prices are pretty good but you may have to go bc/cc. If you can lay down a singe stage its not that much more to put the clear on. I used their product for my TATA and touching up under the trunk lid where the original still was it matched perfect!
Its just more me knowing that the 1.3mm tip on my Eastwood gun will lay down that urethane based single stage pretty flat. I don't pretend to be a professional, and Im afraid a different material might leave with fish eyes or something.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 06-14-2024 at 04:44 PM. |
Good luck, James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed |
The Following User Says Thank You to jamesq For This Useful Post: | ||
Looks like ppg has that color available in either Shopline or Omni single stage urethane. Not sure where you are located, but NCS or Painter's Supply store should be able to mix it for you. Hope that helps.
Im also going to follow up with Oreileys and see what they can do for me locally. Edit: There is actually a painters supply in Bloomington right next door to me. Their website isn't much help though, Ill have to pop into the store and see whats up.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 06-21-2024 at 02:54 PM. |
I bought some Limco that was mixed for my 77 Seville that was a powder blue metallic.
It matched perfectly. Single stage urethane
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
These guys have great paint and have most of the color codes from the classics: https://tcpglobal.com/pages/restorat...BoCYrcQAvD_BwE
Whoever said you can't buy happiness never bought car parts! |
No getting booger’s....bugs...dirt...sweat drips...runs...fisheyes...out of Metallic Single Stage...
But back in the 80’s ...sprayed plenty of RM super max....Centauri...Ditzler....Single Stage Metallic on everyday drivers... What you see ...is what your get |
Which is why I was really looking for something in a product line/type that Im familiar with. Something Im confident I can get right with my equipment first time.
