#201
None at all. I used a 1/4'' rubber hose to check for clerance between the trans and the tunnel. My car was an original 4spd car,not sure if that makes a difference or not.
#202
I'll soon see. I hope to get the runout checked today. I was going to try to get by with a board on my floor jack as a trans adapter but chickened out and ordered a trans adapter http://www.northerntool.com/shop/too...D-_-707-_-CONF for my floor jack from Northern tool. Probably be here early next week.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#203
Good luck checking your run out,mine was out .011 but I cheated and used this.
#204
I think mine is .009.
I found the "low" spot and marked it zero with some painters tape and a Sharpie. I rotated the engine 90 degrees and marked each spot. 180 degrees across from zero was + 19 thousands. I checked it every way I could and came up with those same numbers. I want to get my son to pull the engine through and I want to watch the dial indicator rotate, just for laughs. Make sure my zero is really the zero. Keisler wants those numbers documented so I'm going to take a picture of the results.
#205
455 Pontiac, what is that in your pictures?
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#206
It's a Brownell alignment tool. I read about it as I was looking in to doing this swap.
http://www.camaros.org/bellhousings.shtml RobbMc .007 offset dowels ordered. .019 divided by 2 is .0095. RobbMc's .007 dowels will bring that down to .0025 which is under Tremec's .005 requirement.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 04-12-2012 at 09:51 AM. |
#207
Looks like me be making another tool on the lathe!
Neat inspection tool!
I would suggest that you machine the tip to fit into the bushing or needle bearing. Doing that and bolting it down gives you the truest center you can get. If the hole for the bushing isn't parallel to the shaft's centerline, that will contribute to misalignment but won't show up if you just use the surface of the flywheel with a center rather than a centerline
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
#209
that Browell tool would be perfect for the method of leaving straight pins in the block and relocating the bellhousing alignment holes with welded washers/bushings.
#210
I just installed my RobbMc dowels (same 0.007") Tuesday and can say they're an exceptional product. Just make sure you carefully mark the direction of maximum off center before you install them. I didn't and it added to the time it took.
BTW, I used your method to pull the old dowels after the grease zerk method failed. I thought I was going to blow a seal on my grease gun. They came out easy with the bold and socket method.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
#211
Do you have a parts list that you can post up for someone looking to do similar to what you are doing?
Very good info so far.
57 Superchief IAII CV-1 Heads, Megasquirt EFI, S480 turbo |
#212
A more adventurous mechanically inclined person could source and install an aftermarket or junkyard 5 or 6 speed manual trans in their car for substantially less than any companies pre-engineered kit. Having a little tech support behind you is an advantage with a Keisler, American Power Train or Hurst purchase but quite frankly having a forum like Performance Years and it's wide array users is, I think, of more benefit. Guys on here have attacked installations like this from every angle possible and have some incredible insights on how to do things. A kit was right for me. Looking back (which is pretty easy to do) I could have done most of this with a credit card and a little time on Summit's website selecting the right parts. If I were to do it again I might do that, but then I'd have the benefit of having installed one before.
#213
Just got my RobbMc offset alignment dowels in. I ordered part number 1011, GM .007 offset. No guesswork here because they are neatly lazer engraved with 1011 at the top. They have a groove cut in them showing proper depth and have flat spots on either side for turning them with an open end wrench. Once positioned, lock them in place with the allen screw at the top and off you go. I have a RobbMc fuel filter in my fuel system and also start the car with one of their starters.
These guys produce some quality stuff.
#214
note: I was notified today by my credit card company (Nordstrom Bank) that the dispute over the lack of refund of the down payment to Keisler was resolved in my favor and will be credited back. I tried to do this with Keisler and they were not helpful.
#215
What was that 3 months for a refund? That sucks.
#216
Keisler sucks!!!!!!!!
#217
I climbed back under the car to verify my readings and can't seem to do that now. After a couple of hours of sliding back and forth and rotating the engine in quarter turns and then back to the dial indicator I pulled the Rube Goldberg contraption out and tightened it all back up. I stuck it back onto the flywheel and will start fresh again, maybe tomorrow. This whole process has been somewhat....frustrating.
I've got to get a good reading or I've read of all manner of issues that can arise down the road. I'd love to be able to fab a bolt on bracket to replace the magnet in attaching to the flywheel but can't see how once I did that how any adjustments could be made to properly position the pointer. Shower time.......
#218
OK, so after a Top Gear/Peanut M&M breather I slid back under the car and tried to look at it freshly. I took all my tape markings off and started where I know the zero spot is. On the second trip around I realize that something has mechanically moved the dial indicator. Then I see the mechanical throwout bearing pivot that is still screwed into the scattershield. I take it out. No more interference. I spin the engine around about a dozen times and get the same numbers I got that led me to order the .007 dowels.......0095 out.
NOW the shower calls. Next time the scattershield comes down and I'll swap dowels and re-check.
#219
Progress tonight......I pulled the dial indicator, scattershield, flywheel and the new longer dowel I put in a few days ago. The driver side OEM dowel is pretty tight. I've moved it a little (vice grips) but not much. This dowel is in a harder to get at spot. No way to get a drill in at it straight. I have managed to get a hole in it fairly straight but before I attempt to thread it I need a new tap. I'll get that tomorrow. Right now I have the dowel soaking with a little PB Blaster and will hit it again a time or two before I leave for Chicago Thursday morning. I also heated it up pretty good just to try to loosen up some of the 40+ year old crud. No more real time to work until one day next week.
#220
Dale |
