Old 07-18-2012, 06:11 PM
Formulajones's Avatar
Well maybe this will refresh someones memory and help us at the same time
Plastic valance is easy to spot with it's very unique openings.
Here is a shot of one I have still attached to a front bumper. It's been many years since I pulled it so I don't remember the year I pulled this off of. Maybe 71 or 72? I can't get a great shot at the rubber to see how it might be molded in this area because the valance is still attached and this unique opening covers it up. But you can notice what I was referring to as a "straight accross" metal section just behind the opening...
Here are 2 pictures of a metal valance with it's larger opening that exposes more of the lower bumper. You can see this one has a jagged metal frame with holes. I also took a shot of the molded area around the metal that you refer to as this one appears to be different from your pic. This one has the entire area exposed and then comes down on either side. Both sides of this bumper are done exactly the same way. Maybe this bumper is a 73? There has to be a specific year between these bumpers as they are obviously made differently as you can see.
  #202
Old 07-18-2012, 06:37 PM
FunctionalShaker FunctionalShaker is offline
I don't remember ever seeing one with the edge like that. Maybe someone else can help clarify.
  #203
Old 07-18-2012, 06:48 PM
Me neither. I never really see many (if at all) 70-73 birds at car events to compare with. The ones I have seen are just straight accross in that area like the blue bumper I pictured. So I'm a bit curious.
  #204
Old 07-18-2012, 07:15 PM
Transamric's Avatar
FWIW,...plastic valances started with the '72 model year. But there is engineering paperwork that shows Pontiac intended to start using them for '71's. I've never documented an original '71 with a plastic valance. Has anyone else seen one?
I'll check my assortment of bumpers (about 20) on this lower edge diff to see what I have.
  #205
Old 07-18-2012, 07:38 PM
70 Assembly manual, sheet 12-8.1 of 4-3-70 (front lights) references the plastic valance panel.
  #206
Old 07-18-2012, 10:37 PM
Thanks. There must be some explanation for it. Either a one year only thing or maybe at some point GM used a different supplier for bumpers and had a short run of this style at one assembly plant,,lol. Who knows?
I'm told there is a difference between a 70 bumper and the 71-73, and that the 71-73 bumpers also weigh slightly more than a 70 bumper.
  #207
Old 07-18-2012, 11:01 PM
We definitely know the 73 is different because of the extra bracing.
  #208
Old 07-19-2012, 01:54 PM
Any pics of that? I'd like to verify the bumpers I have laying around. I only have the one with that oddly shaped lower portion I pictured above, and I never see other 2nd gens with it.
  #209
Old 07-19-2012, 02:28 PM
I don't have any 73 pics.
  #210
Old 07-23-2012, 12:11 PM
Anyone else have any insight?
  #211
Old 07-25-2012, 05:49 PM
Don't tell me I stumped you guys
  #212
Old 07-25-2012, 06:01 PM
It's difficult to get fellow enthusiasts to reply sometimes.
  #213
Old 07-25-2012, 10:36 PM
Maybe if you start a "1973 One Year Only Parts" thread, you'll have more luck?
  #214
Old 07-25-2012, 11:02 PM
We got side tracked a little, but my initial query was regarding 70 endura bumpers. You've got a couple of seventies. If they have the original bumpers, what do they look like underneath?
  #215
Old 07-26-2012, 12:36 PM
Yes the 70 bumper was the original question, as I'm told they are different from 71-73. So I posted some pics of what I have here along with what I believe to be an unusual bumper, to see if someone could decifer them. Figured this is as good a place as any to post since we are on the subject, and it's fitting for the 70 only parts, to show the difference. I think that's the only thing this thread is missing,,,,pictures to help explain differences,,,,then make the darn thing a sticky
I'm guessing those pics must have stumped everyone, and now it appears I'd have to post them again (Photobucket doesn't keep my pics up long).
  #216
Old 07-26-2012, 01:59 PM
Tazzz2's Avatar
Tazzz2 Tazzz2 is offline
I'll have to have a look because if memory serves me the 73 bumper had studs molded to the inside (back) of nose in the center (should still have my original one),,,, 70-73 didn't.. Also the 70-72 had little bumps on the return section of the center of nose where the grills insert and 73 didn't if I recall too...
  #217
Old 07-26-2012, 05:55 PM
Held for Ransom's Avatar
I can't remember where I saw other pics of '73 noses, but these are on Hotrodizz' thread.
  #218
Old 07-26-2012, 08:48 PM
There's that notch. Still looking for further info regarding pics at #198.
  #219
Old 07-26-2012, 10:00 PM
Both of my 70s have the big square areas where there's no endura like the pics in post #198.
  #220
Old 07-27-2012, 07:26 PM
There's that notch.
Aha,,,,yes I see it. So I guess with this being a 73 bumper (although it's the only example so far) then that "notch" must be a 73 bumper thing? This may be another quick way to tell without having to look at the backside for the studs in the middle.
