#201
I'm new to this forum, so educate me please. |
#202
Well, if you dont wanna share, i'll just have to base my opinion off of the things you've said in this thread...
Maybe you can tell me what makes a car a ProMod...That way if I am wrong about it, I can apologize and clear this up. |
#204
Minimum weight at the conclusion of run, including driver: Nitrous-assisted entries (910 cid) - 2,475 pounds Supercharged entries (526 cid) - 2,600 pounds Turbocharged entries (526 cid) - 2,650 pounds Stan
#205
TURBOCHARGER
Twin turbochargers limited to 88mm each. Turbocharger size will be verified by measuring the housing bore at the leading edge of the impeller wheel. The maximum diameter of the housing bore at the leading edge of the wheel may not exceed 2mm more than the maximum allowable turbocharger size permitted. All turbochargers must meet SFI Spec 61.1. Air-to-air or water-to-air intercoolers prohibited. Boost controller manufactured by Hyperaktive Performance Solutions, part No. PMBL mandatory. No other boost controller or form of boost control permitted. Must be installed per manufacturer’s instructions as documented on NHRARacer.com: NHRA Accepted Products, NHRA Accepted Product Specifications, Pro Mod, Hyperkontrol Boost System Installation and Operation Manual. Any modification to or any attempt to disable or defeat the boost controller is prohibited. Any attempt to corrupt or delete data associated with the boost controller is prohibited. Maximum boost may only be set by NHRA officials. Boost Pressure Limit: 38 psi Stan
#206
Possibly a deck extension? (or used them for torque plate when honing?)
#207
Chief ran the 3.99 at Lights out 7 in the Radial vs the world class. Those rules are more forgiving then Pro mod. |
#208
Stan
#209
Looks like additional cylinder head fasteners to me.
#210
Looks like 10 extra head studs per side to me. Hard to see from the pic, and I didn't know how to make it larger. They look like 7/16" studs if the big ones are 9/16". Or 3/8" if the big ones are 1/2", hard to tell from one little picture. Having a 5 on 6 bolt pattern around each cylinder and a billet block should allow a huge amount of boost without popping a head gasket. Bridging across a 4.6" bore center with only 10 bolts requires a very stiff head without using additional fasteners. Looks like they chose to do both. Billet custom block and deck layout gives you lots of flexibility in design. Very nice. So is that a Kauffman designed billet block? If it is than at least 2 companies have a few out there.
#211
Travis and Rodney ran really good, ALONG time ago, with way less quality pieces...It doesnt take anything away from KRE, nor Tommy, to say that... I am glad as hell to see the new stuff rolling out for our brand...And I look forward to seeing the results that will surely follow... |
#212
GTO George |
#213
I don't know Do You? Stan
#214
If I knew I wouldn’t have asked the question!
GTO George |
#215
Nitro? In a turbocharged combo?
#216
In one of the last no prep episodes Chief said he can't run 3.9s/4.0s without nitro. Nitro isn't allowed in the no prep series. He normally runs M5 fuel which starts at 5% nitro, who knows what % he normally runs.
#217
Yes.... m5 is very user friendly... large window for error... little tuning over a normal tune to make more power.
#218
What percentage of nitromethane is in M5?
#219
5%.... it's a very low amount... nitro is just highly oxygenated fuel... that where the power comes from.... it's all illegal in most sanctioning bodies...
Like I said, you can run it without really tuning an engine any different.... There are products that are undetectable in a fuel test... Last edited by Scott Roberts; 11-01-2019 at 09:21 PM. |
#220
https://www.youtube.com/watch?v=4GuITMyrEB8 |
