#221
![]() Quote:
Thanks for the compliments.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
#222
What happened to all of your build pix and website link Sez "404 Not Found" here http://www.akvalley.net/~ss/1966GTO.html
Reason for my Q was I remember some of your GR8 GTO build info & pix from the past... ![]() |
#223
![]() Quote:
I have since hosted some photos on photobucket. It is relatively easy, but not really in any order. If you need a specific photo, let me know, as I still have every one of them. I would love to say I somehow will have the time to put all the photos that were lost. Unfortunately I cannot edit any of my posts to re-insert the pictures. Not much has changed on my car in the last two years since this thread has been updated. I've been building a 461 for the car, but that process has been slow due to my involvement in many other activities. Almost everything is bought (including KRE CNC ported D-port heads), the machine work is all done and assembly has been started. I am on the fence about induction, as I really wanted to run the tripower, but I think at my level it will not make the power I want. I may build it with the trips anyway and then dyno with the trips and/or a single plane intake and a single 4 bbl. I plan to dyno the engine before it is installed in the car as well as chassis dyno tuning after it is installed. I dyno'd the car (with the tired 389) last spring and made a whopping 197 rwhp ![]() I was trying to upload the video of the best run to PhotoBucket but somehow I can't embed it here. I will try later when it is visible in my recent uploads page. I also have been trying to decide what transmission and rear diff I will be running with the new engine. I'm pretty well decided on a Strange S60 rear, but on the fence whether I want overdrive with 3.73 or 3.90 gears (not a big fan of the TKO shifting) or just run a Richmond 4+1 and maybe 3.23 gears. Quote:
The car has been driven a good bit in the last few years and the steering is perfect. As a matter of fact the entire suspension is great. Not a squeak or rattle in the entire car, stick like glue in the bends and stops great. The real crime is that the engine has no where near enough power to get me in trouble in the twisties. The front tires are badly worn on the outside and probably due for replacement. I think the tires are the weak link at this time, only to get worse by the near future of added horsepower. That cam has made it to my automotive shelf of shame - where all the broken engine parts from the years of abuse on my vehicles are on display. There are a few bent Chevy connecting rods, shattered BBC piston, a Broken BBC connecting rod, part of a broken BBC crankshaft, a sheared SBC distributor gear (roller cam), and now this lone Pontiac part ![]()
#224
I know this is revisiting a 3 year old post from Paul, but I posted this in another thread and thought it was worth adding here for future reference.
#225
Tod,
Your 66 still looks great! Do you plan on going to the PY show in Lansdale this coming June? I would love to check it out in person. I plan on going with my 67 I think this year -Dominic |
#226
Tod, what are yo up to these days with that car? Last I remember you were going to pull the motor for some reason.
#227
![]() Quote:
![]() Well I was going to pull the motor because it was using alot of oil and not really running up to par. I decided to put that on hold for another year or so because I wanted to build something special and I knew my budget was going to probably double or even triple (I have a bad habit with Mission Creep), so I left the car all together and decided to just deal with it. If you read my post above, I am coming along nicely now on the motor build. The car still runs/drives until the motor is finished/dyno'd. Then I will pull the car apart. I'm planning to repaint under the hood and the front frame when it is apart. How about you - how's your car running after the engine swap? Photo/video I promised above of the 197 horsepower Dyno run A photo of the Monster tied down... ![]() Click below for the video...
#228
Tod, I had the same thing happen with my wipers several years ago. I had my car at a show about 50 miles from home & the wipers stopped working about 3 blocks after I left the show. Since then I rebuilt the heck out of both of my wiper motors. It was not a fun experience driving all that way in the rain without wipers. Jerry.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald |
#229
![]() Quote:
I haven't even looked at it to see what is wrong yet.
#230
Tod, always carry a bottle of RainX with you just in case. As long as you're moving the rain rolls right off, so no need to run the wipers.
Helps keep the windshield clean, and the bugs don't stick as good when it's not raining. ![]()
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#231
I was just fortunate to have a few spare wiper motors in my parts stockpile. Some of them were hardly used & I managed to combine all the best parts to make good motors for my cars. The one tricky part is the little plastic insulator that goes in the end of the motor shaft. If you don't have that & know where it goes, the motor won't work. Jerry.
#232
![]() Quote:
#233
#234
Yeah, buddy!!!
You WILL be part of the burnouts at the PY show this year!
Mitch Kunath |
#235
I'm hopin'
#236
Nice
#237
SWEET! Got any specs on the build? Are you keeping the 3x2's?
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
#238
Tod, was it the wiper motor or the switch? Had both go on my GTO when I first got it. After the motor was replaced I found out the switch was bad too.
#239
![]() Quote:
I'm working with Gary Cygan at Cygan Speed Engineering. He has built many Pontiacs and runs a Pontiac powered Pro Mod '70 GTO. He has been helping me along the way and will dyno it when done. It is his choice for the camshaft, based on my needs. My plan is a completely streetable motor that makes a big fat torque curve. I want 475-500 lb-ft off idle and maybe 650 lb-ft or more peak. Peak horsepower is less of my concern. The original plan was to run the trips. However I am way past what my original plan in terms of spending and cylinder heads. I may dyno with the trips and also a single 4bbl. Problem is I have an OEM cast iron 3x2 manifold and really don't want to port it (gasket match), yet I don't really want to buy an aluminum 3x2 intake either. My car is still together and driveable so to even look at the intake, I got to start tearing the car apart. I may even decide to run EFI on it. I had all the machine work done and bought most of the parts last year. I assembled the bottom end back in December/January timeframe. I run a small side business thru the winter months and it takes alot of my free time from about October thru February (as well as work a fulltime job). I have just been dragging my feet on this build. Life sort of gets in the way if you know what I mean. Now we are approaching spring and I really want the motor in and running for the summer. The car hasn't been driven since the wiper motor failure and I haven't even looked at it. It really wasn't much of a concern as the car rarely goes out in inclement weather. I may go down to the garage tonight and work on it a bit. I want to get my power windows fixed and may pull the doors apart. The 2 front power windows in this car are my biggest aggravation with the entire car. There isn't a battery in the car and it is up tight against the wall (driver's side). Plus my motorcycle is next to it on the pass side and if I move the car the bike has to go outside. I can at least tear into the pass side door though.
#240
Nice to see the car is coming along Tod. I really enjoy the updates on the motor. Keep 'em coming.
