#261
![]() Quote:
Lucy blue (as well as some other colors) will be very difficult to color match the welting compound to due to the variations in paint types, brands, metal flake, formula, and base coats (primer or seal coat) used under the paint sprayed on the rest of the car. it doesn't surprise me at all that someone got the Lucy blue and it doesn't match their car, meanwhile others will find the match is good on their car. You can spray the same Lucy blue paint over different color bases and get lighter and darker end results. This is why paint shops use spray out cards to decide what will work best when they're doing paint repairs for collision work etc. (pic below) If you'd like to have some welting pieces tested for painting let me know and I can test different procedures, possible use of adhesion promoters, possible use of primers, colors of Lacquers, Enamels, and Urethanes in both single stage and BC/CC. Pieces don't need to be very big, scraps the size of the one in pic below would do. As for the person who has Lucy blue welting who might consider painting it with the Lucy blue paint they used on the car, the likelihood of getting a good color match is kinda slim because the Lucy blue welting isn't going to act the same as a base compared to the rest of the car which probably has some shade of medium or light gray primer/sealer. I'd test it on a small piece to see if paint will stick and how color will match before attempting painting all of it. ![]() ![]()
John Paige Lab-14.com |
#262
Good info as usual John!
I'll try to give you a call tomorrow ![]()
************************************************** ******************* 73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014 Last offical pic of the car can been seen here: http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf People have seen it posted FS on Craigs List back in late 2013 early 2014.... ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!! |
#263
Sorry Guys for my absence from the thread for a few days. I had to go out of town on business. Skunkworks and Not A TA, logically I would tend to agree with you on painting the blue welting, but I would have to defer to anybody who know more about painting than I do. I can tell you that Steve at Musclecar Memories did a painting test on some of one of the other colors. Not unlike what we might be experiencing with the blue welting and the match to existing paint jobs, he has a customer that he installed new welting on their car and they wanted it painted to match their car. I think Steve told me the system that he used was Spies Hecker(Maybe?). I believe that is the system Steve uses for all his paint now. Anyway he used some flex additive in both the base and the clear on the welting and told me that it adhered very well and was very flexible. So I know it can be painted successfully. I just wish we didn't have to.
Not A TA, I have no problem sending you some for you to experiment with if you would like. Just PM me an address and I'll send it off to you. As always, if anybody is not happy with it and would like to return or discuss it, please do not hesitate to contact me. James |
#264
Would it be possible to obtain a LB paint match sample before committing to a set?
Chris
Like the sign says, "speed's just a question of money. How fast can you go? Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. Albert Einstein |
#265
Sure Speedfreq, PM me and I'll cut off a little piece and send it to you.
James |
#266
![]() Quote:
Matches if the light is held at the angle to make Lucy Blue the lighter metallic color. Since this paint does have metallic and a small amount of pearl in it, the paint does a color change depending on what angle you look at it. The Welting does not change color in this way. So you will get some miss-match with the paint vs the welting depending on where the light is hitting the panel and the welting. I know from paint experience that PPG 2213 code Lucy Blue is lighter than the other formulations and the original in my opinion. Have done many a test panel over the years. I would think this color welting would match better leaning toward the darker extreme of the color Lucy Blue, the color that appears darker to the eye when it is not in direct sun light. I still think depending on one's personal anal retentive level, these will need to be painted to match the car. Happy with my purchase. Thanks for your hard work James.
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
#267
Skunkworks,
Thank you for the feedback. I knew this was going to be a hard task to do, but I didn't realize how hard it would be. Regards, James |
#268
Did Not A TA & others get any samples to paint? Just curious to see how al that turned out before I pull the trigger on LB or poss even the white...
Either way I want to thank you James for starting this endeavor for us. I think I speak for all TA owners who are tired of the stiff, crappy gray stuff we have had to deal with!
#269
Yes I have some pieces I 'm doing some paint testing on.
#270
![]() Quote:
That being said I would still want blue material that is close to the correct color to enable a very thin spray film to keep the paint flexible and get the correct match on color. Some people will get lucky and it will closely match their car. Not everyone will be so lucky. Thanks.
#271
Skunkworks,
I am afraid you might be correct. I have had both good and not so good comments. I think I am going to press on to Starlight Black. We'll see after that. Thanks, James |
#272
Are you still taking orders for Lucerne Blue then?
#273
Hello Transamric,
I still have it for sale. You might want me to send you a small sample to see if you have a good color match to it before you purchase. I might even still have your address from before. I am currently out of my office until the 27th. I can send you a sample at that time. James |
#274
![]() Quote:
#275
Have you done any silver yet? I need some please. Thanks.
#276
Yes silver please!
Crusin in the Great White North! |
#277
Hello Greybeard421 and Mr T/A,
If I do Sterling Silver, it will be next. Thanks to everybody for their help and support. NOT A TA is doing some testing with some interesting results and some good information for those that might want to paint the welting to match low production colors or custom colors. I have not been on the forum much lately, my regular work has had me about as busy as I can be, and certainly as busy as I ever wanted to be. In the interim, Starlight black has arrived and looks very good as far as color match and gloss. I will be pricing this color the same as Cameo White and Buccaneer Red. $ 90.00 plus shipping for a "kit". I will put a thread on the later years forums since this really isn't a 70 to 73 color welting. Thanks, James |
#278
I know it hasn't been mentioned but maybe once, But I would interested in 79 Nocturne Blue if you venture out to the lower volume colors .....
#279
I think Solar Code (code 50) would also be a worthwhile color as there are many cars built in that color along with the Y88 special editions. I would be interested in some LB for my '70 T/A and would like to get a sample.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1993 Trans Am 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 2006 GTO |
#280
No Problem 3tas4me,
I don't think I have an address for you, so if you would, please PM me an address and I'll get a sample out to you. Thanks, James |
