#261
What sort of potential could be achieved with a roller V Max Rhodes lifter setup?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads 1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455". What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere? |
#262
I Don’t believe they make Rhodes Roller Lifters for Pontiacs...that I know of.
#263
I know that.
I was asking what would be the potential benefits, and will ask an accompanying question that I have asked at other times- what would it take to bring such a working set up into existence.
#264
![]() Quote:
https://www.summitracing.com/parts/rhl-21488x?rrec=true Benefits would be less cam wear, no real 'break-in, the ability to use a more aggressive lobe, and the variability factor making a cam that is made to operate at a higher rpm run smoother at lower rpm. |
#265
![]() Quote:
What about the start up costs for an entity as Rhoads to create such? What would be the minimum perceived market for starting such a project?
#266
They don't even make them for a traditional Chevy V-8 let alone a Pontiac.
#267
http://rhoadslifters.com/sc2/agora.c...x_Flat_Tappets
They list 2 possible numbers for Chevrolets,: CHEVY V-8 OE ROLLER 21488X V-MAX FITS: Chevy, GMC & Truck (Buick, Cadillac, Oldsmobile, Pontiac) 1987-88 - 249 (4.1L) Allante 1994-97 - 265 (4.3L) Hi-Performance 1988-92 - 275 (4.5L) 1991-95 - 300 (4.9L) Vin B Cadillac 1987-03 - 305 (5.0L) 1987-03 - 350 (5.7L) And this: CHEVY BIG V-8 OE ROLLER 22798X V-MAX FITS: Chevy, GMC & Truck (Buick, Cadillac, Oldsmobile, Pontiac) 454 (7.4L), 502 (8.2L) --- The references to Buick, Cadillac and Pontiac are confusing, especially in conjunction with the 7.4 and 8.2 ltr displacements.
#268
A reg SBC for the most part would work depending on the base circle of the cam core just like all other SBC chevy hyd roller lifters.Tom
#269
They told me on the phone these Rhodes hyd roller lifter were not for a "regular" SBC. I'm no Chevy expert but I took that as the 1955 and 2003 type engines.
#270
Took the car out again today. Backed the timing 4 degrees so initial is now 8 and overall is 30. I can’t notice any detonation. Weather was over 90*F.
The last cam still had audible detonation at 28* in the middle of winter, so for sure the longer lobes on a wider lsa has made the engine less octane sensitive. |
#271
Hey mate, what distributor are you running and what do the plugs look like? That's surprising it pings with a 12/34 curve with no vacuum advance... It sounds like you're heading in the right direction though with the new camshaft and it's just a matter of dialling it in now.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
#272
Hey,
Running a factory HEI. Plugs look a bit black. Probably running a bit rich. AFR gauge shows under 12:1 at WOT. Going to put in 1 stage cooler spark plug |
#273
Yeah I think I run 7's in my e-heads, definitely something to try. What's the AFR look like when it was pinging/rattling? It's just when it's cruising yeah? By the sounds it wasn't too overly lean. It was also hot as hell the last few days. I just had mine out now because I just got the diff back into it after putting 4.3 gears in it, I saw air temps around 39*C so if you have somewhere similar over your way then it wouldn't surprise me if it has a rattle here/there if you've not had much time to dial it in. Another thing you could try is slightly heavier dizzy springs to slow the advance curve down a bit too.
#274
It was about 34*C when I took it out. Pings at WOT in 3rd gear(manual) only. Cruise is fine. I guess in 1st and 2nd the load isn’t enough for it to ping. It is ok at 30* overall. Plugs are 5 heat rating at the moment. Going to put 6 in. Hopefully it might allow me to put a couple degrees timing back. Then I’ll slow the curve down a bit. Going by magazine articles most 455 with iron heads seem to only need 32-34 total so I should get there
#275
I didn't go back thru all the posts but was TDC confirmed with TDC on the balancer. What rpm does the mechanical advance timing stop? Have you confirmed no advance creep at higher rpms? Have you confirmed the vacuum advance works and fully retracts at WOT?
#276
TBC mark on the timing cover is in the correct location. Mech advance stops about 3000rpm. Iv added a stop to the advance, it can only add 22*. WOT tests were done with vac advance disconnected
#277
![]() Quote:
Was helping my brother on his 89 Chevy 1/2 ton, 350. Mind you pickups seem to get newer technology last, his 350 had flat tappets in it, about 250,000 miles to boot, and NO flat lobes.. .(we were changing the intake gaskets and a broken fitting in the intake...). The roller lifters that GM started using in 87 were unique, not interchangeable into an older engine (or at least easily...), required alignment bracketry in the lifter valley to keep the lifters form spinning.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
#278
"The roller lifters that GM started using in 87 were unique, not interchangeable into an older engine (or at least easily...), required alignment bracketry in the lifter valley to keep the lifters form spinning."
Thanks. I wasn't sure on the dates but that's what I was alluding to. And what Rhodes was indicating, if I understood them correctly. .
#279
The fact is that other then in a true race solid Roller set up a solid lifter lobe can kick the valve open faster and that's just what a 455 and bigger stroke motors want with there very early big demand for air .
#280
The 1987 and later blocks were machined for "hardware" to use roller camshafts in them even though they still used flat camshafts in many applications. This machining includes flat areas at the top of the lifter bores for the lifter guides to keep the roller lifters from turning and drilled holes to bolt down the lifter retainer that holds the guides in place. The lifters are machined to accept the guides to keep them from turning. It's a very simple and effective system and eliminates the needs for a bar between the lifter pairs.
This hardware will include what is shown below plus the front of the block is also machined for a thrust plate to retain the camshaft in the block: https://www.jegs.com/i/Comp-Cams/249...CABEgIrRvD_BwE Earlier blocks require vertical bar style or "retro-fit" lifters to be used plus on an SBC build a cam "button" is required to keep the cam from walking forward in the block.......Cliff
