#261
Likely...
I don't know if the flat filter can be substituted.... AND of course you know there are 2 variations of the flat filter. One has the screen filter element (I was told by my engine builder to always use the screen type, little potential to clog), and the filter on the shelf at most all parts stores will be the paper media type....
#262
The flat filter can be used if you use the later pan. You really do not need the bolt according to a 1968 GM bulletin.
The screen type flat filter is for an Allison and is far better.
#263
Ask for the AT545 Allison filter that looks like a TH400 filter (there are 2 Different AT545 filters, they do not look even close..) then get a good TH400 gasket...
#264
I installed same early style t-400 by Wix 58879.
Tranny drank about 6 Qts total doing the usual 4 Qts to start then into R - D then right back to P and check level. I had to patch up the pan's gasket surface some as the cable support bracket made some small holes from contact. Now the only finished surface under the car ( besides the 55mm shocks) is the tranny pan...lol...some self etch primer & some dupli-color cast aluminum engine paint to the rescue! Drove to work again and seems fine. Not sure if my old filter was starting to plug up....what signs does that usually exhibit? Got to spend a quality day under car doing some wire wheel & POR-15 I did have an issue with the engine oil pan Friday and very lucky I was going to a local shop.
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 09-23-2019 at 10:05 PM. |
#265
A full year later after digging it out of it's to be grave.
Been a pleasant surprise season with this car and totally met my goals for it first year. It has responded well to the most minor amounts of attention. I've been driving it daily & enjoying it's reliability The more I use it the better it runs... What a sweet ride!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#266
#267
I can not believe my car made it into the local Pontiac chapter 2020 Calendar !
Thanks SteveP!
The Following User Says Thank You to shaker455 For This Useful Post: | ||
#268
You are welcome
#269
67' GP Back in action for Season 2
Took the family to our local ice cream stand . Memories ice cream Kingston NH https://memoriesicecream.com/
#270
#271
Nothing to report yet Jeff.
Besides some AFB work.
#272
Going out this evening for a sundown cruise
Ordered some color samples from Ames to get the ball on rolling on restoring the gold interior.
#273
Got my color samples from Ames but I'm disappointed they do not offer a Gold headliner.
Just Buckskin & Sandalwood Is there any other places to get a headliner in color?
#274
I think that is the first time i have ever seen a 67 GP with the headlights actually turned on.
Rally 2's look good on the car |
#275
Thanks,
I'm plugging away to make the interior inviting.
#276
Lost my brake booster today.
Called Ames and my replacement is discontinued Any recommendations where I can get mine rebuilt?
#277
I used a source that I found in Hemmings
#278
i have a carpet for ya
look at 1967 impala headliners |
#279
Thanks Steve & Ray
#280
Where can I get rear quarters or repro parts for that area?
I'm also consider buying a pair of cars, 67 & 68 Catalina's
