#281
Yes, and this is where you will find the oil band sits below the oil hole while on the base circle. If the oil band was raised high enough to reach the oil hole while on the base circle, you wouldn't be able to run much more than .300" lobe lift before the oil band pokes out the top of the lifter bore.
#282
I am going to be right at the edge of that I guess with .389 and .391 lobe lift. It's running Crower Hippo solid's so I am not sure if that is different with the oil requirements.
#283
No they don't have to pump up. You'll be fine.
#284
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
#286
So bottom line what is the answer to all this? I need to buy HR lifters in the near future... I would like quiet operation. Is this all just a crap shoot? I really don't want to go roller then be PO'ed at myself... I would like to go with the bushed stile as opposed to needles, but anybody's are upward of $1000.00. An expensive learning lesson in my opinion. Does anybody guarantee quiet? The cam I'm looking at has almost .600 lift with 1.5 rockers. Is the trick to go to a lower lobe lift and go to 1.65 rockers to make up the difference?
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#287
I will repeat!I have used the new Comp Hyd rollers in my last 3 engines,just replaced a set of solid rollers on a Hyd roller cam with them.My 366 engine made HP to just under 7K.I run 150-160 on the seats.2 of the engines have the 400 lobe lift Hyd roller cams.I run 10-30 moble 1.If I was to build another engine it would have the same setup.Your results could be diff.Tom
#288
#289
I don't know. We don't use Comp lifters. We have seen too many failures with them to use them. Too many axles coming out and destroying engines. A 455 we just fixed had Comp lifters that came apart. Luckily it was caught in time before it ruined the block. The lifter band is still low I'm sure, because like I said, if it was high enough to reach the oil hole on the base circle, it will poke out the top of the lifter bore at .400" lobe lift. On the lifters we raised the oil band .150", they almost come out the top of the lifter bore with only .356" lobe lift. They are .025" away from coming out. The relief cut we made in those lifters just barely reaches the oil hole in the block.
#290
#291
Paul,Morels like many Hyd roller lifters are SBC like many other mfg.They confirmed that with me,just diff link bars.SBCs have been a problem with both HFT and SFT forever depending where their oil band is.As Dave posted pics back on a early page the diff of the early 857 and the current 857 is much diff.Tom
#292
#293
Paul,they changed their builder.I know the engine I just put them in is way tighter than 2.As I said I was worried about it was just tired of working on it and wanted to drive it.I put it together with the outer solid roller springs which had me worried after some told me what happens if you break one.Had a friend do the change over to duals in his shop as I was too lazy.160 lb at a 1.920 IH.Have put a lot of miles on it now with extended trips.I guess after 4 sets with no issues I have faith in them,enough to to put a lot of street miles on them in a virtually erreplaceable 366 NASCAR RA V engine.Tom
#294
Well hopefully they have them figured out now. I wonder who makes them. Do they oil good to the rockers? Have you actually checked to see if the oil band comes out of the top of the lifter bore? Also, have you measured any of the oil band heights, and compared it from the cam lobe to the oil hole to see where the top of the oil band sits? I'm just curious of these measurements for more knowledge and understanding of what's going on here. My theories, are just that. Theories based off of the measurements I got off of the few blocks I have here. I do not have a RAV 366 block to check. Maybe they are significantly different in these areas than a stock block. After all, those blocks were designed for NASCAR use, so they may have modified oil hole placement, and lifter bore heights to accommodate NASCAR type cam profiles. I just don't know about that as I have never even seen a RAV 366 block in person, let alone measured lifter bore specs from one. :^]
#295
Page # 8 of this thread, post # 143.
#296
Yes, I saw that, but the picture doesn't tell me where the oil band sits compared to the oil hole, at base circle, or if it comes out of the top of the lifter bore at full lift on a .390" or .400" lobe. According to my measurements, if the oil band is in the oil hole at base circle, the oil band will poke out the top of the lifter bore at full lift on lobe pushing the .400" lift mark. Maybe my measurements where wrong. I will double check them when I get to work.
#297
I did not do the builds on the engine.The engine I just did the swap I did check to see if it came above the block and it did not.It is a generic 4 bolt 428 block.As I said under 2 thou.Had oil around the lifters,plenty up top and carries 35 plus at 1100 RPMs hot idle.The pump has been in the engine for 18 years.This cam is not the 400 lobe lift,touch under as I recall.The 366 was not the 400 either.The 400 was in a the weak block,557? And the other is in a generic 2 bolt 69 block.In the last 18 or so years the only valve train issues I have had was with a set of Isky solids on a Hyd roller where the needles were going away.caught it in time,had the rebuilt and just removed them from the engine I made the switch.The other was with the lash caps going away on the same engine,caught that it time also.Tom
#298
Paul this may be a dumb question but is there any reason a person could just grind a small 1/4 channel like you did with a dremel? They make some nice small round bits that seem like they would work.
#299
Sure, that's all we did, only we used a 1/4 head porting die grinder.
#300
I spent hours studying this thread and taking notes. There is really some good information here. Great job for bringing this information to light Paul.
I don't think I saw what lobe lift exceeds the cam journal? I also didn't see what lift would cause the oil band to come out of the bore? I'm sure it would depend if you were using the new Comp Cam HR with the 1.7 oil band height or the morels (as I understand it they have their oil hold at 1.56) On a side note I talked with my engine builder and he has been changing the old Comp Cams with Lunati(Morels) with great success. He may not know about the new Comp Cam lifter by Shaver Specialties. I plan on calling Comp Cams on Tuesday and see if there is anything they can do for me. I have had mine in for 5 years now with lots of startup ticking. |
