Old 12-31-2018, 12:29 PM
61-63 61-63 is offline
That's probably it, thanks. Funny I see that PRW rockers were used in it so we know that had to have been some years ago.
  #322
Old 12-31-2018, 12:44 PM
Stan Weiss's Avatar
Originally Posted by Steve C. View Post
Not sure if this is the specific combination Cliff is talking about regarding Ray Klemm's first combo. But here is a link with his feature....
12:0 compression
110-octane
http://www.hotrod.com/articles/hppp-...9-pontiac-gto/
Steve,
Looking at that article I have to say the shift RPM looks low to me for that cam timing.
Stan
Pontiac Pump Gas List
  #323
Old 12-31-2018, 12:48 PM
Steve C. Steve C. is offline
Ray's cam in that article are Comp High Lift Magnum lobes 3115B & 3116B
Dave Bisschop "Road Paver" and used with Crower solid roller lifters.
See how easy these threads can get discombobulated !
Old information here:
  #324
Old 12-31-2018, 02:13 PM
Cliff R's Avatar
Cliff R Cliff R is offline
"Not sure if this is the specific combination Cliff is talking about regarding Ray Klemm's first combo. But here is a link with his feature...."
Different person, Ray Klemm Jr.
Also different engine, transmission, converter, gearing, tire diameter and vehicle (heavier 1981 FB)......Cliff
  #325
Old 12-31-2018, 02:32 PM
Thanks Cliff, to be honest I had completely forgot about his son now racing. Sorry for the confusion here.
( A side note: Many years ago when I went to the Pontiac races at Norwalk I had the pleasure of spending the weekend with Cliff at his home and then in the pits with him. Pitted next to us was Ray Klemm and his family, I just would like to say you couldn't find a nicer guy, and family, and their enthusiasm was very refreshing )
  #326
Old 12-31-2018, 03:27 PM
Stan Weiss's Avatar
These lobe lift files are not from measuring an actual cam but I computer generated them form listed specs. The graph shows valve lift for a comp 3115 lobe with 1.5:1 and a 041 with 1.65:1 both @ 110 ICL
Stan
  #327
Old 05-28-2019, 02:13 PM
Lee's Avatar
Lee Lee is online now
Originally Posted by TCSGTO View Post
. It’s interesting Lee Atkinson had gains making the exact same swap I did. I’d bet he had 3.73 or steeper gearing and a fairly light car. Who’s to say he wouldn’t have run close to the solids’ performance with milder gearing and lower shift points with the hydro cam?
Searching for something else, and just saw this for the first time.
I had 3.42 gears, ran 275/60-15 MT ET Street radials - ran that with both cams. Full exhaust, all steel street car - not super-heavy but far from being considered "light".
When I changed to the UD SFT 280/280 (247/247 @ .050") from the UD HFT 288/296 (231/239 @ .050), the ONLY things that were changed were the cam, lifters, valve springs and the valve job was freshened up. The HFT liked to be shifted around 5300, the SFT like to spin closer to 5900. If I had kept the car (that is, if I hadn't gotten divorced about that time) I would have kicked the stall speed up a few hundred rpm, as I lost some 60' with the SFT.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #328
Old 05-28-2019, 03:10 PM
Stan Weiss's Avatar
The green line show a generated valve lift curve for the UD H5. The blue line show a generated valve lift curve for the UD H5 with 0.007" lash (equal to 0.045" lifter raise - Adv duration with 1.5:1 rocker ratio). The magenta line show a generated valve lift curve for the UD N66 with 0.025" valve lash.
Stan
