Old 11-26-2014, 05:07 PM
67'7F6'Bird's Avatar
DCI Motorsports - Don Johnston will be performing all the Machine Work and Complete Engine Assembly on the aftermarket block, making sure this 535 motor is done right.
  #342
Old 02-06-2015, 10:23 PM
DCI Ram Air V Engine Build for the 1967 Firebird listed in the Race Section.
Steve
  #343
Old 09-17-2016, 02:25 AM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
I have to say, you are a damn good craftsman. Great work on the body. I was looking for info on replacing my tail panel and came across your build.
I picked up a tail panel from Classic Industries today. I will be removing the tail panel tomorrow, cleaning up the trunk and underside of trunk, while the panel is off. I only hope i can put together correctly. If i do a halfway decent job i will attempt replacing the rusty roof.
Quick question, why use an air chisel? Is it easier than drilling out the spot welds?
I will be returning to this post many times in the next couple of weeks.
Thanks for this very informative and detailed write up.
Oz
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
  #344
Old 09-25-2016, 08:49 AM
Hi Oz,
The Air Chisel will be quicker and if used correctly panel distortion will be minimal to none. If you drill out the spotweld you will now have a hole that needs to be filled with weld - too much work this way.
Thanks for you interest in this post, my brother and I enjoyed the restoration. It's still ongoing.
The DCI Ram Air V hopefully will be completed soon.
Steve Page
  #345
Old 09-27-2016, 06:36 PM
Hi Steve,
After drilling for a few hours, waiting for my drill to cool down, resting due to fatigue I know understand. I may need to upgrade my pneumatic arsenal for any future spot welds.
I need to weld my tail panel back on, then pick up a roof panel, might even do a quarter panel. After messing with the tail I noticed some bondo on the left quarter near the top left part of tail panel. Before this i never noticed it but after scrathing the bondo i realized they tried to match the natural curve of the quarter, but its off and i may regret it if i dont do it now. Thanks again for your Info.
Oz.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
  #346
Old 07-10-2017, 10:23 PM
Back on the road.
Name:	67 Firebird Mann Orchasr July 10 2017.jpg
  #347
Old 08-06-2021, 10:53 PM
https://www.facebook.com/groups/220092308823847
