![]() Quote:
![]() Door parts and column photos attached. DanC
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon |
Two more pics....
The tag I have on it says that I removed it in 2002 and the lower bearing is bad and upper bearing is good.
Dan:
Thanks for the pics. I'm going to keep looking. Thanks Again! |
Tim John,
Here are the photos of the caps...
Hi did you sell your th400 cross member yet?
Hi did you sell your th.400 cross member yet?
Yes it has been sold.
DanC |
All these items and more are going to the Moultrie Swap Meet this Thursday - Saturday. I will be in spaces A251 & 252 along with two other guys and their stuff. Look for the Pete's Paint & Restoration 24' enclosed trailer (logo below)!
Engine / Drivetrain Intake Manifold 2bbl V8 $30 Carburetor 2bbl (1 serviceable, 1 parts) $40, $15 Carburetor Q-Jet (1 rebuildable, 1 parts) $75, $20 Misc Q-Jet parts $10 Timing Cover, V8 – ’68 $45 Push Rod Cover, V8 $20 Fuel Line, Fuel Pump to 2bbl Carb $5 Crank Pulley Set 2pc, dbl groove and a/c V8 $30 Dipstick & Tube, AT – ST300 (2 speed) $15 Dipstick & Tube, AT – TH200-4R Chrome NIB Mr Gasket $25 Flexplate (“flywheel”), V8 AT $20 Axle Shafts, bolt in ’67-69 $50 Driveshaft w/ yoke, ’67 ‘400’ AT $100 ************************************************** ******** Chassis Trans Crossmember TH350, ST300 ’67-’69 $30 Four Piston Caliper LH & RH, need rebuild $150 pr Rear Disc Brake (remd fr Cad Seville) Park Cables, Calipers, Mounts, 1 modified disc for mockup $100 Rally II Wheel set, 14x7 rust free, damage limited to trim ring scratches $120 Rally II Center Cap set, Red ‘PMD’ used orig $35 Wheel Cover, Deluxe 14” blk centers $15 ************************************************** ******** Body Front Bumper Assy, complete (less grilles) used orig ‘400’ $300 Rear Bumper w/ four brackets used orig $200 Tail Light, good housing and trim, cracked lens ’67-68 $10 Windshield Wiper Linkage Assy, complete nice serviceable ’67-69 $45 Convertible Header Seal Kit 3pc w/ molded ends NIB (SoftSeal) $75 ************************************************** ******** Interior & Accessories Door Panel Standard ’68-69 pair for trim parts only $20 Deluxe Door Parts ’67 only $20 for all Convertible Dash Speaker (Frame only) w/ dash mount $10 Instrument Panel Lens w/ Chrome Rings, new repro $20 Instrument Panel w/ printed circuit, Standard “Idiot Lights” ’68 $10 ************************************************** ******** Miscellaneous Lots of small misc parts, inquire Service Manual, repro 1968 VGC $30 Wiring Diagram, 1968 Firebird VGC $5 Misc Brochures and Magazine Advertisements, inquire ************************************************** ******** 2nd Gen Parts Air Cond Muffler, ’71 w/ service port $50 Fisher Body Manual, 1971 orig VGC $25 Service Manual, 1971 orig GC $30 ************************************************** ******** Misc 1969-72 GTO/LeMans Defroster “Y” Duct, VGC, mount tab present 69-72 $35 Hood Scoops, orig diecast , good studs ’71-72 GTO $40 pr |
are any of the parts still available? thanks
Still have those bumpers? Interested in front and rear.
Dec 2016
Engine / Drivetrain Timing Cover, V8 – ’69-up $40 Crank Pulley Set 2pc, dbl groove and a/c V8 $30 Flexplate (“flywheel”), V8 AT $20 Axle Shafts, bolt in ’67-69 $25 ea Driveshaft w/ yoke, ’67 ‘400’ AT $75 Throttle Cable , 2bbl used orig $5 ************************************************** ******** Chassis Wheel Cover, Deluxe 14” blk centers $10 ************************************************** ******** Body Front Bumper orig ‘400’ 67-68 *fresh rechrome* $425 (brackets & upper reinforcement avail extra $) Rear Bumper orig 67-69 *fresh rechrome* $375 (brackets avail extra $) Tail Light, good condition, no cracks/damage 67-68 $35 Tail Light, good housing and trim, cracked lens ’67-68 $10 Trailer Hitch, Custom Light Duty. only thing seen is the chrome tongue below license plate $25 ************************************************** ******** Interior & Accessories Printed Circuit Rally Gauges , good used $40 Rally Gauge Face (no instruments) , good used $10 Deluxe Door Parts ’67 only $20 for all Dash Speaker Frame (cut out center for custom mounting newer speaker) w/ dash mount for A/C car $10 Instrument Panel Lens w/ Chrome Rings, new repro $20 ************************************************** ******** Miscellaneous Lots of small misc parts, inquire Service Manual, repro 1968 VGC $30 Wiring Diagram, 1968 Firebird VGC $5 Misc Brochures and Magazine Advertisements, inquire ************************************************** ******** 2nd Gen Parts Air Cond Muffler, ’71 w/ service port $50 Harmonic Balancer , used orig 1975 $35 ************************************************** ******** Misc 1969-72 GTO/LeMans Defroster “Y” Duct, VGC, mount tab present 69-72 $35 Axle Shaft, Bolt in style $25 ea
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon Last edited by DanC; 12-01-2016 at 08:26 PM. Reason: add parts |
I just posted an updated list in this thread
DanC
I do have the bumpers, however they have now been rechromed and the price has gone up to $425 for the front and $375 for rear. Brackets are available for both at extra cost. Of course everything is negotiable
![]() DanC
Do you still have the TH350 Crossmember?
I will have to check on that tomorrow. Don't remember if that sold.
DanC
PM sent about driveshaft
![]() Quote:
![]() DanC
#38
#39
Pics of Rally Pkg face and printed circuit.....
$40 plus ride
#40
pics....
