Old 04-02-2021, 04:26 PM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
Originally Posted by jeff chmura View Post
Keith,
What product did you use?
I checked my build thread and the link has expired; it was something from the Eastwood catalog.
We also used a product called "Pliogrip" extensively on the special vehicle I worked on right before I retired.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 04-02-2021, 07:11 PM
Rob in NH's Avatar
Rob in NH Rob in NH is online now
As soon as the sun hits the seam it expands the glue that why it shows.
Old 04-02-2021, 08:08 PM
jeff chmura jeff chmura is offline
Thanks for all the feedback
I'm going to seam the door patch under the moulding.
I'm going to seam the cab corners lower and fill the seam with filler.
The paint is black so we'll see if I get the ghosting
Thanks again, Jeff
Old 04-28-2021, 07:02 PM
ponjohn's Avatar
ponjohn ponjohn is offline
My nephew went to Autobody school. The bonded two pieces of metal and stretched them on the frame machine. The two pieces tore around the bonded pieces.
Old 12-12-2021, 02:41 AM
justincampbell's Avatar
justincampbell justincampbell is offline
Does anybody have any opinions about this particular product? https://www.autobodytoolmart.com/pro...otive-adhesive
I have never used the adhesive before, but I've heard some really good things. This will be for rockers and possibly quarters(haven't decided on several small patches or just doing whole quarters) on a driver 1979 Firebird.
I could weld them if I have to. But, that would mean I wouldn't be able to do the work in my own garage(don't have much space and I have my welder at a friend's place because my current garage doesn't have 220).
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 12-12-2021, 10:03 AM
Murf Murf is online now
I’ve used it and also Lord Fusor. Both work well. IME you have to plan where you use it as I have experienced ghosting with both when using it where / how I probably shouldn’t. They both take their own style of guns to apply. IIRC, they aren’t cheap. I’d see if I would borrow one from someone and use whichever adhesive you can get the gun for if it’s a one time job for you.
Good luck !
Murf
The Following User Says Thank You to Murf For This Useful Post:
Old 12-12-2021, 03:02 PM
[QUOTE=Murf;6301881]I’ve used it and also Lord Fusor. Both work well. IME you have to plan where you use it as I have experienced ghosting with both when using it where / how I probably shouldn’t. They both take their own style of guns to apply. IIRC, they aren’t cheap. I’d see if I would borrow one from someone and use whichever adhesive you can get the gun for if it’s a one time job for you.
Good luck !
Murf[/QU
I've used a number of 3M 2 part products in the past. Hopefully one of the guns I've got from past projects is correct for this product as well.
Easyrider
Old 12-12-2021, 08:19 PM
Formulabruce's Avatar
Keep in mind, having used a few different brands, that the SLOWER the cure time, the STRONGER the bond. This doesn't mater much on non structural parts. The Temp MUST be at 70 at least. One huge advantage is the bonding " epoxy " has rust inhibitors, and with No air, and super clean metal, you have no condensation, NO rust.
The " glue expanding and showing" can be easily handled by a wire wheel cleaning out the Grove so there is no excess in the seam. Then use short strand filler in the groove sand,, Epoxy and finish.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 12-12-2021, 09:31 PM
MUSLCAH MUSLCAH is offline
Who cares about a ghost on a cab cornah…..use the adhesive ,where you can’t weld ( like between the bed and the back of the cab ) . just use the duck bill on a porta power to keep it tight overnight. Then weld up the rest
Old 12-13-2021, 01:48 AM
It's amazing how much stuff I've managed to accumulate. I just went to see if I have the correct gun for the 3M product I was asking about(I do) and realized I also had a Duramix gun and 2 new tubes of adhesive(1 for plastic, 1 for metal). How long since I put them in the cabinet and forgot about them? 2007.
I wonder what the shelf life on that stuff is?
Easyrider
Old 12-13-2021, 10:11 AM
dhutton dhutton is offline
Toss it. It’s trash.
Don
The Following 2 Users Say Thank You to dhutton For This Useful Post:
Old 12-14-2021, 03:17 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Don
100% agree. I had some Fusor 2 part (acrylic based) seam sealer I used barely beyond the expiration date because I couldn’t find my new tube and was in a rush. It was a nightmare. I’m also very careful to follow the ideal storage spec’s on the package while I have it.
I’ll have to find a direct link, but the Fusor small tubes that I’ve used (sealer, bond,) have worked perfectly in the cheap generic applicator gun that’s all over Amazon. It’s usually $10-$14 depending on which name you buy it under. That cheap gun can outweigh the extra cost of 2 small tubes vs 1 larger tube.
The Following User Says Thank You to Entropy11 For This Useful Post:
Old 12-14-2021, 03:48 PM
Originally Posted by Entropy11 View Post
...I’m also very careful to follow the ideal storage spec’s on the package while I have it.
I've been thinking about this a bunch as well. Since the building isn't heated, I won't be able to tackle this until next year. I figure I'll just wait until I'm close to needing it to order the 3M adhesive. Then I don't have to concern myself with proper storage.
Easyrider
Old 12-14-2021, 10:19 PM
jcleinmark jcleinmark is offline
Yes he is right,,I did it myself years ago,, patch panels only way to go
