Old 04-23-2011, 01:01 PM
misterp266's Avatar
Originally Posted by Jim Robertson View Post
If Jack says Go...I will start posting some pics as we capture them and work our way around these.
Jack,
Do you have any pics of the rockers you use on yours? The more pics the better...
Who made yours?
Jim,
Here's a pic of a stock 392 exhaust rocker (one of Jack's) beside a M/T aluminum Pontiac Hemi rocker. Jack uses Donovan exhaust rockers which are the same size as stock. Steve has the M/T rockers on his boat motor.
Rob...
" Darksiders Rule "
Old 04-23-2011, 03:28 PM
Pontirag Pontirag is offline
rumour has it that somebody is doing an MT Hemi head? Is that what this is leading to?
Old 04-23-2011, 07:27 PM
Steve Barcak's Avatar
Jim,
Rob...
Correct. I am running the M/T forged alum rockers on my original HEMI Pontiac installed in a '72 HONDO flatbottom.
They work fine but, are too troublesome to service an engine between rounds and there are other limitations as well. Based on that, I am currently having a modern shaft system being manufactured for my other Pontiac HEMI stuff to be used on my 225" AA/FD.
Instead of a rocker shaft assembly as a whole, there will be a rocker base that bolts to the head. Then a separate custom shaft rocker will bolt to it individually on its own stand. This will make it much more adaptable and reliable. Plus easier and faster to tear down and put together between passes.
One of my heads is being used to do this and will be a vast improvement over the original design. As far as what they may flow, not overly concerned at this time. I am confident a 370-400" Pontiac with M/T HEMI heads can get a digger or funny well in the 5s at most any desired speed 250+. I've seen cars with iron 354 chysler heads, 6-71s, no trans and 12" nostalgia tires, old style point mag, 380-400 inches, etc already running 5.80s/ 240-50mph over 10 years back. It was very common and the M/T heads are far better in every way ( except availability ) than the iron 354s are. Exhaust ports need no work. This engine was designed ad built to be a Top Eliminator and other top class winner blown/injected engine- no compromises- The most power available.. No carbed intakes were made from the info I have gathered. Have not heard of injected intake as Jack mentioned, news to me.
It's really a neat engine. I'll be giving rides this summer and beyond to share!
I love and admire all the modern stuff out there in the Pontiac world but, it is really something to be able to do it with 50 year stuff that has yet to reach its real potential. Doing it 'Old School'.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 04-24-2011, 01:55 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Jim- post all the pictures you want. This whole effort is about sharing info.
As Rob said, my hemi V8 uses Donovan forged steel exhaust rockers meant for early Chrysler hemi, same basic configuration as the OEM cast-steel rockers. They work well to 9,000 RPM but are getting scarce and expensive. Stock Chrysler intake rockers worked fine for me.
If I use this head on a four-banger for the lakester, it won't use pushrods. I want to finish the details of a DOHC design I was working on, and employ it on the four (needs to be reliable at over 10,000 RPM to make my goal of 4 HP/c.i.).
Old 04-24-2011, 02:09 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Originally Posted by Ron H View Post
Interesting. I am curious why you have not digitized a head and started widdling them out? Eventually casting and selling?
Having M/T designed Hemi head available I am sure would bring interest.
if there was ever to be a set of m/t heads reproduced, `id hawk the wife, kids and anything else to have a set!!!!
Old 04-24-2011, 10:52 AM
misterp266's Avatar
This will give you an idea what Steve is talking about for rocker arms. This is a billet Alan Johnson 392 head.
ID:	242367   Click image for larger version
" Darksiders Rule "
Old 04-26-2011, 07:43 PM
Don Chapman Don Chapman is offline
Guessing, As cast @.700 299int/265exh.
66 Gto
65 Gto
Old 04-28-2011, 04:39 PM
misterp266's Avatar
Any updates Jim?
" Darksiders Rule "
Old 04-28-2011, 08:19 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
I can update you on Tom S's RAVs but that is another thread. :-) Besides Tom would string me up if I do not finish his first.
The Hemi's should have very good numbers for the valve size. You'll see the reason for asking about the rockers...
ID:	242866   Click image for larger version
Old 04-28-2011, 09:06 PM
Half-Inch Stud's Avatar
SHHHH!!!T, HOP'Solutely triple IPA & HEMI PMD heads don't mix. WOW.
Old 04-28-2011, 09:20 PM
misterp266's Avatar
Nice job on the guides and seats Jack, not sure I'd trust the nearly 50 year old originals in my heads. Flow numbers should be interesting!
Rob...
" Darksiders Rule "
Old 04-29-2011, 12:07 AM
Nice casting for early 1960s and excellent machine work in early 2011. Enjoy.
ID:	242886   Click image for larger version
ID:	242887   Click image for larger version
ID:	242888   Click image for larger version
Old 04-29-2011, 02:19 AM
Originally Posted by Half-Inch Stud View Post
... HOP'Solutely triple IPA & HEMI PMD heads don't mix. WOW.
Say what?
Old 07-27-2011, 01:32 AM
Some progress...we flowed the two different intake ports tonight
Had to mod a few things to get a fully operational set up to accept the Hemi. Will scan and post the flow sheet soon.
Fresh calibration tonight with the PAP plates.
Internal barometer read 28.08" Hg. Crazy low pressure and stupid hot temps.
Tall guides would allow .700" max lift
Flowed these on a 4.060" bore diameter at equivalent to 28" H2O pressure differential.
Noted a sound change at about .500" - .525" lift and it carried out to max lift on both ports.
Stock port - Some turbulence resulted in varied flow numbers at .700" lift anywhere from 276.1 - 290.6 scfm.
Modified port - also varied and flowed 282 - 295 at .700" lift.
ID:	251486   Click image for larger version
Old 07-27-2011, 01:47 AM
Intake flows @ .300"/.400"/.500" lifts?
Old 07-27-2011, 02:12 PM
Flow sheet attached. Will be working on larger bore flow numbers and the exhaust. Exhaust should flow fairly good...but we shall see.
Old 07-27-2011, 03:38 PM
Tom Vaught's Avatar
Boost Engineer
Would have guessed a LOT more flow there.
My "nothing" "2nd Run" Edelbrock boost heads will go 310 cfm at 28" at .600 lift and 255 cfm on the exhaust at the same lift.
Tom Vaught
  #38
Old 07-27-2011, 03:48 PM
tom s tom s is offline
2in intake a 4 in bore Tom!
  #39
Old 07-27-2011, 04:42 PM
Really not bad numbers for a 370-421 inch motor. SBC Brodix 11's have similar numbers with slightly bigger valve and smaller valve stem. Decent low and mid numbers too. Considering the era of these heads, thats pretty respectable. The exhaust numbers should be interesting. I'm thinking a much better in/ex ratio than a conventional Pontiac head. That would allow the intake to work more fully to its potential. Especially with a boosted motor.
  #40
Old 07-27-2011, 08:57 PM
I thought the numbers were good for a 2" valve up to .500" lift. After that both ports have a bit of turbulence that could in all likelihood be "tuned" with a bit of work around the seats.
More to follow.
