Old 02-02-2019, 06:22 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
Updated:
parts & prices:
8K tach & 160 speedo plus fuel, water, volts & oil (complete) 185
6k tach & 160 speedo 75
71 TA front & rear std blue seats - Very nice set 750
70-71 TA std blue door panels with 71 style lower panels 150
4 leaf rear leaf springs with drop block 100
stock UCA & LCA with Global west devalue bushings 150
used 70-72 snout style air cleaner 50
NOS 70-78 style spoiler ends 175
70-71 grills driver quality 40
72 grills driver quality 60
72-77 style lower door panels bright blue 80
70-78 dash cap 3/8" new in box 75
15" rally wheel trim rings (5) 50
73 TA hood hinges 100
71 TA hood hinges 80
70-81 power windows 50
door jam sticker 10
brake pad with disc brake logo new repro 5
PF-24 oil filter new repro but in an original box 10
PF-24 oil filter new repro 5
exhaust tips (pypes repro) 75
Dynomax transverse muffler 2.5" 17533 new (best for these cars) 75
1970 TA 4brl intake 95
7029251 carb running 150
7040240 carb worked 100
70-81 heater core no ac 25
Be cool alum radiator auto trans 125
700r4 & 4l60 conversion tranny cross member 100
DSE firewall smooth plate $60
71 TA ac heater control $100
2.5” header back exhaust with x pipe & 80 series flowmaster muffler $76
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
Old 02-03-2019, 02:27 PM
cnc's Avatar
cnc cnc is offline
Yes arms have the del-alum bushings.[/QUOTE]
Devalue bushings ...is that supposed to be greasable or del a lum.......lol
Any idea on the years of the arms....
I know they have different sets depending on years..the diameter of the bushings are diff frt to rear and there is something about bolt size too ....according to what I've read....
I can go check my car and post back on my findings....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 02-03-2019, 02:33 PM
71HO4SPD 71HO4SPD is offline
Default '71 blue seats and door panels
Pm sent.
Old 02-03-2019, 04:45 PM
cnc's Avatar
cnc cnc is offline
Pm sent
Old 02-03-2019, 11:13 PM
cdoggy81's Avatar
Arms are off my 71 TA.
I think the change was in 76 IIRC but that may be the subframe.
Old 02-04-2019, 06:57 PM
cnc's Avatar
cnc cnc is offline
This from global west
If they are on your 71 this may not work out....depends on my car....
Sometime during mid-1973, the factory changed to 1974 subframes. The geometry for both subframes is the same.
The lower control arm on 1974 frames use 9/16 bolts rather than 1/2-inch on 1973 frames. The upper control arms on 1974 models have two different size bushings; 1973 upper arms use the same size bushing front and rear. Therefore, you must check your components before ordering parts.
So need to do some checking...
PM Box is full too ....
Old 02-04-2019, 11:01 PM
cdoggy81's Avatar
Thanks, just cleaned out the in box
Appreciate the info as well. I remember a while back a friend of mine had the same problem with his car. Hopefully you have the 1/2” arms :-)
Old 02-05-2019, 07:49 AM
cnc's Avatar
cnc cnc is offline
I'll check tonight and get back to You....Florida is a go for transport so hopefully we can get something done
Old 02-05-2019, 06:41 PM
cnc's Avatar
cnc cnc is offline
Just checked 9/16
Gonna have to pass these up ... appreciate your patience....Chris
Old 02-14-2019, 12:35 AM
larrygroskopf larrygroskopf is offline
It's the center air deflector mounted center dash at the top it lets you direct the air . Tried to post picture if you can email me at lgto67@yahoo.com I could do it that way
Old 02-22-2019, 12:42 AM
cdoggy81's Avatar
Updated:
71 TA front & rear std blue seats - Very nice set $600
70-71 TA std blue door panels with 71 style lower panels $100
Buy both for $650
4 leaf rear leaf springs with drop block $50
stock UCA & LCA with Global west bushings $150
used 70-72 snout style air cleaner $40
NOS 70-78 style spoiler ends $150
70-71 grills driver quality $40
73 TA hood hinges $60
71 TA hood hinges $50
door jam sticker $10
brake pad with disc brake logo new repro $5
exhaust tips (Pypes repro) 75
Flowmaster series 80 2.5" transverse muffler $40
Manifold heat riser plate & tube $40
700r4 & 4l60 conversion tranny cross member $75
Used flowmaster series 80 transverse muffler & 2.5" x pipe with collectors & flange $60
71 TA ac heater controls $75
71 TA gas tank 8-24-70 date code, NICE $30
Misc window & glass trim $10-$20
If someone is local & takes it all I will do a crazy good price!!!
