I got the new HPP yesterday and there is an article on Rodney Butlers's new motor. Interestingly enough he used mild steel headers and coated them with a "special 2000 degree coating from BCD coatings" Anybody familair with this product?
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
No, but I hate to see what will happen if it decides to "go away".
It would be interesting to see what the cost comparison is between using such a coating vs. stainless steel. |
When Marty was on the board, He would have mentioned that his headers were mild steel. I am
with Larry though. I do a lot of work with the McLaren company on my Ford turbo projects and I am glad that Ford is paying for the tubing. Any left over tubing immediately disappears into someone's tool box. I am also interested in the coating on Rodney's headers.
Excellent points G-man.
George Hill '63 Star Chief, '95 Chevy P/U, lots of BMW motorcycles and cars |
Even if you coat mild steel, the problem goes from oxidation to strength. Mild steel is only good to a little over 1000 F if it is lightly stressed (like headers), but will give up quickly when temps are 1500+ along with the weight of a turbo hanging off it. This doesn't mean it can't work, just that it wouldn't last very long, which helps to justify the higher cost of stainless (Inconel takes a lot more justification, of course - unless you get some "scrap" for free...). Inconel can run at bright orange (2000 F) all day without flinching while you could poke a center punch through mild steel without much effort.
Larry '63 421SD LeMans... in pieces in my garage and basement |
Larry F,
Even when we run the good stuff we never run a turbo engine without a floating turbo support to help hold the turbo. When the exhaust is really cooking the pipes are like plastic and tend to move around quite a bit. A simple but correctly designed turbo support really helps out.
