Nice! I sold one of these back in the late 80's and 2 weeks later, blew up my 428 and needed a block. Go figure, no I don't sell anything I don't have extra of.
Cool Keith! I love those 194.5's! Ran pretty good for what they were.
Here's mine 461 SD KRE 290's
clean...what intake are you running and how in the heck do you get that air cleaner under the hood???
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
The Following User Says Thank You to mchell For This Useful Post: | ||
Some nice looking engines in this thread.
Sandoval Performance www.sandovalperformance.com Pontiac Crate Engines CNC Edelbrock heads Custom Ground Cams JOHNSON Limited Travel Hydraulic Roller Lifters |
Here are some pics of a 407 I built for a friend.
More pics of 407 on dyno.
Here's one of a 460 I built from a 64 389.
cool looking at all the different setups......
Nice n stock looking! kinda,lol
Its a "no nothing" car
I don't need anything here in New England
The intake is a P4B-QJ Edelbrock. The air cleaner base is an old .75 inch drop base, which is about as flat a base as I've run across. Seems the newer ones have a huge hump just inside the element. Just clears the accel pump, throttle cable bracket and the bracketry for the secondary air flaps. 4" Purolator element. It all clears the hood by 1/2" or a bit more.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 12-21-2013 at 11:30 PM. |
I love how everybody has a Pontiac and each person puts their own stamp on them.
Well done guys.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
"I fishtail through the lanes, and I make my tires squeal. Power at my feet, and glory at the wheel. I wind the windows down, let the wind blow through my hair. God knows where I'm goin' to, but me... I don't care." |
There's those Strelka built valve covers!
#38
Paul, what is that oil system mod shown in the valley of that 407 you built?
www.hobracing.com |
#39
engine
Pontiac powered 31 Ford
#40
This was my turbocharged 462 in my '73 TA. Then I sold it.
This is what I'm building with the money from the TA sale. It was also built by Paul. Still mocked up in this pic, but it will be close to this configuration if I stay with the radiator in the trunk. . Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
