Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-09-2021, 08:23 PM
65madgoat's Avatar
Updated info on these heads:
2.25" intake valve size means these are best suited for large bore aftermarket blocks.
Springs in them are actually Crane #99893 dual valve springs with a 1.460 in. outside diameter, 391 lbs./in. rate, 1.080 in. coil bind height --- with Manley titanium retainers.
Set up for a hydraulic roller cam and you could run either hyd roller lifters or Crower solid roller lifters 66260H.
Old 11-14-2021, 07:41 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Are these heads still available?
Steve 703-615-5027
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot.
Old 11-15-2021, 09:48 PM
chuckies76ta's Avatar
I'll take water cross over.
Old 11-16-2021, 12:08 PM
65madgoat's Avatar
Off the market for now. Thanks.
