Points replacement
I used the Lectric Limited. It uses just one wire and looks completely stock once installed. Best mod I've ever done!!!
http://www.lectriclimited.com/breakerless_se.htm |
how are you picking up your 12 Volt? some fuse block terminals are switched off during crank. not like a chevy. found that out when converting my 66.
Jim |
I used mallory uni-lite conversion and was very happy, until I screwed it up by shorting it out. They now have protection from accidental shorting included..
If I remember right, you can use the original resistance wire, but it was over 20 years ago when I installed it. Ran for years until I screwed it up. |
I used a Pertronix Ignitor II in my GTO stock distributor for 5 years with no problems. 4 years ago I did a big engine rebuild and went with a Pertronix Ignitor III to get a rev limiter and it's worked perfectly so far. So that's 9 years of no problems. Probably just jinxed myself.
Check out my cruise night! www.brewcitycruisenight.com |
Aren't those the same as the old Unilite module? The Unilite was a fragile POS. Even Mallory suggests you buy a $40 "Power Filter" to prevent frying the Unilite module. http://www.summitracing.com/parts/maa-29351 |
Pertonix works, just dont have the key on and engine not running , they will burn out alot faster that way.
Wiring and install errors are the bane of electronics. It's not forgiving. No engineer in his or hers right mind would release a design into production that doesn't work.
I've installed several units and they work correctly. The Ignitor versions are points-replacements and the key should never be on for extended periods with the engine not running. The Ignitor II is more like the HEI design; it is safe to leave key on with engine not running, but why do it anyway? That's what the ACC position is for. A point system has the same problem if the engine stops with the points closed...the coil can get hot and fail. I've read all these horror stories and I'll bet 90% of them are due to miswiring/ and or customer-induced damage. Not blaming anyone directly, just sayin' one has to be careful and read the install instructions. George
The Pertronix is wired up different and winds up without power during cranking.. I wired in a seperate toggle switch on my 60 and just supply direct power to Pertronix and Shazam...!! It starts. Many ways to cure but that is mine.... Will try a relay activated when cranking next...soon as I figure it out..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Morongineers build a product that "works" under fairly ideal conditions, using as many surplus parts that are already "in inventory", at the lowest-possible cost, giving the highest-possible profit margin. It's especially rewarding for them if the product can be built to fail just outside of the warranty, and cannot be repaired. They won't challenge Management when Management wants a product that would be unethical to produce. |
Just run the extra wire ( actually it should be in the harness either yellow or white) down to the starter .If you have it bolted on with the purple wire, then move it to the other terminal .DONT just hook it up like that as it will cause the starter to run and run and run ....... |
old school for the win!
Does anybody else have experience with the lectric limited HEI conversion? Did a little research and seems like all the corvette guys love it. I'm not overly concerned about original look but an HEI distributor won't fit with my edelbrock P65 intake.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
Dan |
Morongineers, I like that! I seem to run into their work quite often!
How long have you had it installed and how many miles?
I have them in two cars with no problems. If they did fail just put the points back in. Had two Pertronics fail. Nuked one while having the key on to trace an electrical gremlin. The other not a clue. You have to pull the dizzy gear to convert back to points. Also like the single wire stock look.
#38
Lectric Limited
I installed one (Vintage GM truck) 4-5 years ago and probably put 5,000 miles on it. I also installed one in my GTO 2 years ago and have put around 4,000 miles on it. The only hick-up I've had was I learned it won't run if the wire isn't tight (installer error). Installation was quick and the GTO loves it. If you look at their web site you'll notice they engineered out many user type failures like leaving the key on. Great product!
#39
I have used Pertronix Ignitors for the past 15 years without a hiccup.
The LSS version, the II and III versions as well. The coils and wires are good as well. They need a full 12 volts to get the most out of them. |
#40
Have run nothing but the stock points distributors in my GTO's for over 35 years with no problems and 100's of thousands of miles. Aside from normal maintenance (which I enjoy) there is no reliability downside to points, and no performance gain from electronic, only the convenience of not replacing points every so often. I'd rather do that than be stuck out on the road with a dead HEI unit.
Jeff |
