My ac in my 73 ga is not kicking on, i have all the contacts checked and they are clean, the clutches never engage on the pully, i wasnt sure of what the problem was. Anybody have a similar problem in the past?
if the freon's low it'll blow a fuse that is probably mounted to the a/c bracket. it'll be black and usually have three wires in the connection.
to test it you can jump the connections and see if the comp comes on. do not do this as a permanent fix tho. mike
yeah its called a thermal lockout fuse or something like that. i got it and my freon is low so i'm recharging it with Freeze 12. Thanks a lot for your help. Also what is the best performance D port head for good compression and flow, and what cam should i use for street use. Another thing is that i want to get 3.73 gears but am not too sure if they are too steep for a 455. Thanks again guys for all your help, i'm starting to strip the whole car down in a few weeks, i will send pictures of it when i'm done.
Damien |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Pestilence68:
My car has a factory vynal top with the sunroof, did any GA's in 73 come with a sunroof without the vynal top? also where on the car does it indicate that the car had a vynal top from the factory?<HR></BLOCKQUOTE> Yes, my 73 GA has the sunroof and no vinyl top.
Steve F. |
I know where there's a '73 GA with a factory sunroof and no vinyl top in a junkyard...
Jerry:
Where is this car located?
