Assuming you have the Scarebird adapter plate kit you need:
2 1977-79 Cadillac Seville Rear rotors NAPA 85776 One Pair 1970-76 Firebird Calipers NAPA 242-2004/2005 One Set 1970- 81 Firebird front brake pads NAPA AE728AM 4 1970 - 1981 Firebird front caliper bolts NAPA 82203 15" wheels. The instructions don't tell you that. If you had 14s, they won't won't fit anymore. Last edited by krautwolf; 07-17-2007 at 12:15 AM. |
John here are the photos.
Raybestos master cyl #MC36361 Proportion valve SUM-G3905 I made my own lines out of pre-flaired 1/4" tubing and couplings. I dented the inner fender in so they would fit nicely. Let me know if you of anybody else needs any additional photos. I can only comment on my set up. Any tech questions should be sent to Scarebird. Last edited by PITTSBURGH 64; 10-24-2007 at 10:06 AM. |
Thanks for the pictures. Ill post mine tomorrow, they will only be progress pics.
1964 Pontiac GP |
John,
I mounted the adjustable proportion valve under the master and put the metering block where the junction block was. Did you get a combination valve (proportion and metering block in one unit) with the kit or an adjustable unit like I have? Last edited by PITTSBURGH 64; 10-24-2007 at 10:06 AM. |
![]() Quote:
In the 1st picture how the lines exit to the left side of the car, my kit you can have those lines exit either the left or right side. You take plugs and block one side and use the other. I believe i have a combination valve. My mechanic is in late today when he arrives i will head over to take a picture.. I know I am explaining it badly.
1964 Pontiac GP |
![]() Quote:
Another question... are there any options for bigger brake kits? I anticipate going to a 17" wheel on my Cat (similar to what I have on my GTO) which would allow for much larger diameter brake discs if there is a kit for that. If I follow this process, do you think a big brake kit upgrade for a 77-79 Seville would work (since those are where the rotors are coming from? Also, is there a rear disc upgrade? |
Here are some pictures of some progress on my car. Still not done, might be a week or so.
1964 Pontiac GP |
Guys, the design has been improved to use 1977 Bonneville wagon rotors and calipers. These are a unicast rotor, 11-7/8" in diameter. Require 71 or newer 15" rims to clear.
