'69 Pontiac 400 YA, .060 over, stock crank, 10.2:1 comp, CAT H-beam rods, HS 1.65 rockers, Crane cam 248/252 660 lift, Edelbrock 72cc heads ported 300 cfm, Performer RPM Intake, Ruggles 800 cfm Q-jet, Summit 140 gph electric fuel pump, 12 bolt 4.10 posi, 200-4R, Transgo HD shift kit, 2800 stall, aluminum radiator, 2" MadDog Headers, DMH 3" cutouts. 12.51 et @ 111 mph |
wow about 3350 with the interior in it, and u have a 68'. interesting
Ryan stated 67's are the lightest yours seems pretty light is it an early 68?
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
Thanks Murph. I'm prepared to give you the time you need to sharpen the razor. Then I need a shave. SHOTGUN! hahaha
I know when we were at the track last year my car came up 3660 with me in it, 215# Once I'm done I hope to be around 3500 with me in it. All steel and stockish. But then I am going to add connectors. Anyone else have the weight of some of the components? I have some factory buckets I can weigh, but they're 200 miles away right now... I figure this thread can help document where the weight is and common over all weight too. Cammer, I bet the OHC is fun to drive! |
-4.11 posi 12 bolt -welded in subframe connectors -200-4r -E-heads -headers -Dumps -A/C delete and shaved firewall -what did I forget? hahah All the above make her very pretty |
FireBjorn http://FirstGenFirebird.org/show/closeup.mv?CarID=221 breathe and enjoy it , life is temporary 69 Firebird convertible 71 Triumph TR6 |
Man, you HALF guys are brutal!!........and, oh, Bjorn, next time we hook up, make sure there are PLENTY of Shiners available, then we'll see who the lightweight is Kel
im lightweight too 160lbs
you`ll have me beat.... BUT , put the cars on a 1.5 lane wide gravel forest road , and we`ll do some rallying!
Besides at the track where are some typical places one can go to get a car weighed for a reasonable price?
My 68 is a stripper (bench, no rally's, no AC, no PS, no PB, spacesaver, etc) so I'd love to see just how light it is. AMA guidlines for weight seem to be pretty genreric although whoever posted 67s are the lightest is definitely right on. Weight-wise, 69>68>67. PS I'm in S FLA... |
I remember using a truck scale once. A friend of mine knew about it. Ask some truckers in your area.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
I don't know why though.... |
I can think of a few wieght diff"s.
Vent windows. But think that would add some... Interior panels. Doors at least. Rear springs. Big diff. Frt park & rr side marker lamps. But the 67 ft lwr pnls wieght more Maybe sheet metal was thicker on 68"s?
'68 backhalved, S&W ladder bar/ 12pt. MS, metal tubs, stock front sub.& susp w/drum brakes, 9" narrowed stock housing w/drums, stock block/crank/TH400, Eheads, all fact sheetmetal (exc. hood) & bumpers, all fact glass/ window regulators, front carpet/ door panels/ gutted dash w/pad/ 2 racing seats., 5 gal cell, alum rad.
3100lbs (3280 on Maple Grove scale w/ my 180 in it.) Mark O.
Ain't as good as I once was, but I'm as good once as I ever was. |
I added some more individual part weights. Finally got to my storage.
the 67 is lighter because they didnt have so many options on them as the 68/9's did. also tthe metla is slightly thinner from what ive read. depending on what you doing with the car you can get it down ALOT! just depends on what you willing to sacrifice for the time slips. if you drop the spare tire/jack you'll save around 25#. i read once when a mag was doing this if you stripped the interior down to the drivers seat with door panels, removed the spare tire and lessendd the tire pressure to 15# you can knock off almost a second from your slip. alos raise the back of the hood to make it more arrowdynamic so the air flows better over the car. this knocks off.2 from the time. putting a washer under the hood where the rear bolt is accomplishes this.
#38
I posted this awhile back but thought I'd add it here for reference in case anyone wondered what that lump under the hood actually weighs.
Complete 400 engine, iron heads and water pump, but without headers or flywheel attached. Not that you could run without it, but now you know. Anyone know what is the wt difference between aluminum heads vs Iron? Aluminum water pump vs iron? Aluminum bellhousing vs Scattershield? |
#39
Rear drum brake assemblies
20 lbs each side |
#40
Race wieght at Pontiac Nationals(Norwalk) last year was 3565.
Been think'n bout this all winter. Car has to be repainted. Vinyl top is off for bubble rust underneath. May go with a glass bolt on hood. Lower fenders corners will have to be patched. So maybe replace them with glass also. Main concern is fenders for street/strip. Both wheel houses FULL of stuff. Remote filters, ignition module, line lock, etc. Anyone try factory wheel houses with glass fenders? Keep in mine street/strip car. The pic's of the fenders look like i would have to make brackets/mounted on firewall to hold hood hinges. No big deal there. They do have light strength hinge springs.
