Old 11-02-2010, 11:28 AM
DEEZPAZ's Avatar
DEEZPAZ DEEZPAZ is offline
RH fender - this fender is in near mint condition considering its from the NorthEast!!! Some very slight surface rust on the inside of the front of the fender that attaches to the nose(pix 6). There is also a small dent on the top above the vent (pix 9).
ID:	223151   Click image for larger version
ID:	223152   Click image for larger version
ID:	223153   Click image for larger version
ID:	223154   Click image for larger version
Old 11-02-2010, 11:31 AM
DEEZPAZ's Avatar
RH cont.
ID:	223156   Click image for larger version
ID:	223157   Click image for larger version
ID:	223158   Click image for larger version
Old 11-02-2010, 11:34 AM
DEEZPAZ's Avatar
LH fender - this piece has some rust issues on the inside near the back of the fender (pix 6) but the rust hasn't come thru the outer wall. The bottom piece of the back of fender has some rust (pix 2) but nothing major. All in all this will clean up to be a very nice piece and has no dents at all!
ID:	223160   Click image for larger version
ID:	223161   Click image for larger version
ID:	223162   Click image for larger version
ID:	223163   Click image for larger version
Old 11-02-2010, 11:38 AM
DEEZPAZ's Avatar
LH cont.
ID:	223165   Click image for larger version
ID:	223166   Click image for larger version
ID:	223167   Click image for larger version
ID:	223168   Click image for larger version
Old 11-02-2010, 11:41 AM
DEEZPAZ's Avatar
Chrome headlight bezels - These bezels have some light pitting on the bottoms which should clean up nicely. Straight, no bends or cracks and all mounts are perfect.
ID:	223170   Click image for larger version
ID:	223171   Click image for larger version
Old 11-02-2010, 11:44 AM
DEEZPAZ's Avatar
I actually bought the caps awhile back but decided to go back to the originals..
Heres the pix of the cap and the inner GM sticker on them...
ID:	223173   Click image for larger version
Old 11-08-2010, 11:23 AM
DEEZPAZ's Avatar
Rear valance - In great overall condition with some minor surface rust on the inside(pix 2). A great piece which will clean up very well with a little work. All mounting holes and tabs where clips attach are in excellent condition!
ID:	223850   Click image for larger version
Old 11-08-2010, 11:29 AM
DEEZPAZ's Avatar
Cowl screen - $20 Took this off my car awhile back so it wouldn't get ruined sitting outside in the elements. The screen has no breaks or cracks but the mounting tabs are cracked but didn't effect how the screen held on to the body. Didn't even know they were cracked until I took the screws off.
ID:	223852   Click image for larger version
ID:	223853   Click image for larger version
ID:	223854   Click image for larger version
Old 11-08-2010, 11:33 AM
DEEZPAZ's Avatar
LH/RH Reconditioned bullet mirrors 79-81 - $175 These are in mint condition and are primed for paint. The glass is has some swirls but no scratches or cracks. The wording on the RH mirror is perfect. Comes with the inside door mounting bezel for the mirror control knob along with the screws to mount it to the door(pix 5). Some slight rust on tip of control arm (pix 2).
LH mirror
ID:	223856   Click image for larger version
ID:	223857   Click image for larger version
ID:	223858   Click image for larger version
ID:	223859   Click image for larger version
Old 11-08-2010, 11:35 AM
DEEZPAZ's Avatar
RH mirror
ID:	223861   Click image for larger version
ID:	223862   Click image for larger version
Old 11-15-2010, 05:35 PM
DEEZPAZ's Avatar
Repro A/T shifter bezel - $75 - New reproduction automatic shifter bezel for a '79-81.
ID:	224681   Click image for larger version
Old 11-15-2010, 05:39 PM
DEEZPAZ's Avatar
Front left flare - Has a crack in the middle near the lower mounting bracket(pix 4) and the bottom mount that attaches to the spoiler has a crack(pix 3) but didn't effect the application. The mounting bracket is in good condition.
ID:	224683   Click image for larger version
ID:	224684   Click image for larger version
ID:	224686   Click image for larger version
Old 11-15-2010, 05:43 PM
DEEZPAZ's Avatar
Front right flare - There are no cracks in the piece or attachment point but the mounting bracket has a cracked bolt that will need to be fixed.
ID:	224689   Click image for larger version
ID:	224690   Click image for larger version
ID:	224691   Click image for larger version
Old 11-15-2010, 05:47 PM
DEEZPAZ's Avatar
LH/RH OEM bullet mirros 79-81 - $100 These are original mirror in great condition. There is some slight rust on the mirror adjuster knob for the LH mirror(pix 2). The RH mirror wording "Objects in mirror" is in great condition(pix 6). There are some light swirls in the glass but no cracks, major scratches or chips. Comes with mounting bezel on inside door panel (pix 2) but no screws.
LH mirror
ID:	224693   Click image for larger version
ID:	224694   Click image for larger version
Old 11-15-2010, 05:52 PM
DEEZPAZ's Avatar
RH mirror
ID:	224698   Click image for larger version
ID:	224699   Click image for larger version
Old 11-15-2010, 05:53 PM
DEEZPAZ's Avatar
The reconditioned mirrors have been reduced to $150
Old 11-15-2010, 06:33 PM
The Boss's Avatar
The Boss The Boss is offline
Are the front & rear window trims black or natural?
What condition?
And go racin' in the street.
  #38
Old 11-15-2010, 08:43 PM
DEEZPAZ's Avatar
It is actually the outside molding for the front/back windows.. They are silver and brand new reproductions.. Don't know if you were referring to interior or exterior molding/trim but the description was alittle bit confusing so I just wanted to clarify..
  #39
Old 11-15-2010, 08:53 PM
The Boss's Avatar
That's what I was looking for - the outside. Where in NY are you?
What color is the interior? I need a Driver's side arm rest/door pull for the deluxe Camel Tan interior in perfect condition.
  #40
Old 11-17-2010, 11:34 AM
DEEZPAZ's Avatar
Boss - pm sent
