Old 11-21-2010, 12:49 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default cont...
If you look at the build sheet, you can match up all of these tags and stamp numbers with the corresponding boxes of the build sheet... pretty cool.
ID:	225256   Click image for larger version
ID:	225257   Click image for larger version
ID:	225258   Click image for larger version
ID:	225259   Click image for larger version
Old 11-21-2010, 12:55 AM
428ho4spd's Avatar
Default cont...
All of the heater hoses are original with the original clamps and control valve. The upper & lower rad hoses have been replaced.
ID:	225261   Click image for larger version
ID:	225262   Click image for larger version
ID:	225263   Click image for larger version
ID:	225264   Click image for larger version
Old 11-21-2010, 01:05 AM
428ho4spd's Avatar
Default cont...
The passenger's side outer T-3 is cracked... luckily I have some good spares. The two rear GR70-14 tires with the narrow white-wall and the spare in the trunk all matched and were all dated 1982 prior to the sizing number change.
ID:	225266   Click image for larger version
ID:	225267   Click image for larger version
ID:	225268   Click image for larger version
ID:	225269   Click image for larger version
Old 11-21-2010, 01:17 AM
428ho4spd's Avatar
Default cont...
Upper nose of front bumper was punched at one time and repair to right nose edge of hood. Paint was blended in to original paint on hood. Last reg sticker and original gas cap.
ID:	225272   Click image for larger version
ID:	225273   Click image for larger version
ID:	225274   Click image for larger version
ID:	225275   Click image for larger version
Old 11-21-2010, 01:25 AM
428ho4spd's Avatar
Default cont...
First GP I've owned with the funky plastic rear valance... of course its cracked and a chunk missing out of it. Anyone got a nice original metal one to sell?
ID:	225277   Click image for larger version
ID:	225278   Click image for larger version
ID:	225279   Click image for larger version
ID:	225280   Click image for larger version
Old 11-21-2010, 01:31 AM
428ho4spd's Avatar
Default cont...
Old CA NOX system emission decal.. it was basically a vacuum plug kit that disabled the vac advance. All glass is original.
ID:	225282   Click image for larger version
ID:	225283   Click image for larger version
ID:	225284   Click image for larger version
ID:	225285   Click image for larger version
Old 11-21-2010, 01:38 AM
428ho4spd's Avatar
Default cont...
Passenger side door panel is excellent, driver's has some very small cracking where you'd rest your elbow. Original mesh package tray is very nice, even for a non-tint glass car.
ID:	225287   Click image for larger version
ID:	225288   Click image for larger version
ID:	225289   Click image for larger version
ID:	225290   Click image for larger version
Old 11-21-2010, 01:45 AM
428ho4spd's Avatar
Default cont...
Tear in driver's seat back... hoping I can just have that section replaced between the beads.
ID:	225292   Click image for larger version
ID:	225293   Click image for larger version
ID:	225294   Click image for larger version
ID:	225295   Click image for larger version
Old 11-21-2010, 01:55 AM
428ho4spd's Avatar
Default cont...
Looking at an old smog station receipt dated 1/13/93 that I found in the glove box... the car has traveled 541 miles since then.
ID:	225298   Click image for larger version
ID:	225299   Click image for larger version
ID:	225300   Click image for larger version
ID:	225301   Click image for larger version
Old 11-21-2010, 02:01 AM
428ho4spd's Avatar
Default cont...
Black electrical tape wrapped around the column... maybe to protect it from one of those old spring registration card holders?
ID:	225303   Click image for larger version
ID:	225304   Click image for larger version
ID:	225305   Click image for larger version
ID:	225306   Click image for larger version
Old 11-21-2010, 02:06 AM
428ho4spd's Avatar
Default cont...
Passenger vanity mirror...
ID:	225308   Click image for larger version
ID:	225309   Click image for larger version
ID:	225310   Click image for larger version
ID:	225311   Click image for larger version
Old 11-21-2010, 02:15 AM
428ho4spd's Avatar
Default cont...
Driver's side door at rear center body line & front of quarter panel have some filler and are blended into original paint. Unsure if this was related to front damage or not?
ID:	225313   Click image for larger version
ID:	225314   Click image for larger version
ID:	225315   Click image for larger version
ID:	225316   Click image for larger version
Old 11-21-2010, 02:19 AM
428ho4spd's Avatar
Default cont...
Original white top is very nice, just a little dirty. White paint on top molding is flaking off... will need to strip and repaint them.
ID:	225318   Click image for larger version
ID:	225319   Click image for larger version
ID:	225320   Click image for larger version
ID:	225321   Click image for larger version
Old 11-21-2010, 02:25 AM
428ho4spd's Avatar
Default cont...
Unfortunately, the original spare tire was used and swapped out for a newer radial down the road. Jack setup is in nice shape, looks to have been used once or twice.
ID:	225323   Click image for larger version
ID:	225324   Click image for larger version
ID:	225325   Click image for larger version
ID:	225326   Click image for larger version
Old 11-21-2010, 02:39 AM
428ho4spd's Avatar
Default cont...
Original rear speaker there, but cover & retainer are missing. All four original spiral shocks in place. Right rear drum has rear axle ID tag (WT) and drum retainers still in place. The left rear drum had been off before, no retainers on that side. Left side had a small amount of brake dust, right side was loaded. I'm thinking these are the original rear shoes? They have some life left...
ID:	225329   Click image for larger version
ID:	225330   Click image for larger version
ID:	225331   Click image for larger version
ID:	225332   Click image for larger version
Old 11-21-2010, 02:49 AM
428ho4spd's Avatar
Default cont...
New tires and cleaned up wheels & trim. The original paint on the wheel faces are quite nice. The backs of the wheels came out great with just a light scrubbing with degreaser. You can see some spots of undercoating on the back sides from the original dealer undercoat. The original spare wheel cleaned up real nice, got a 5th matching tire for it. All 5 wheels have the same date code stamp.
ID:	225334   Click image for larger version
ID:	225335   Click image for larger version
ID:	225336   Click image for larger version
ID:	225337   Click image for larger version
Old 11-21-2010, 03:25 AM
428ho4spd's Avatar
Default cont...
Did a quick wash with brake clean on the rears. Found a tag on the left rear frame rail, but couldn't read anything on it. Front calipers are original, linings are getting low with a little life left. Had a friend hiding up above the left rear coil spring while looking at the rear brakes, luckily I saw her first! She didn't like PB Blaster... have found three so far, one was hiding behind the horn relay cover (sneaky) and another inside the fan shroud.
ID:	225343   Click image for larger version
ID:	225344   Click image for larger version
ID:	225345   Click image for larger version
ID:	225346   Click image for larger version
  #38
Old 11-21-2010, 03:32 AM
428ho4spd's Avatar
Default cont...
Got the trunk vacuumed out and the jack & spare back in place. New tires are on ready to cruise.
That's it for now...
ID:	225348   Click image for larger version
ID:	225349   Click image for larger version
ID:	225350   Click image for larger version
ID:	225351   Click image for larger version
  #39
Old 11-21-2010, 09:25 AM
robz's Avatar
robz robz is offline
Yep and we even make a T Shirt for it too!!!!!!!!!!!!!!
Great stuff, Brad....!
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
  #40
Old 11-21-2010, 09:36 AM
robz's Avatar
or he had a column attached tach?
Pretty nice car...and I don't think it is low on options (unless you compare it to today's stds)...Congrats!
1969 Grand Prix SJ
