Old 02-20-2011, 04:40 PM
My442 My442 is offline
The factory built the chassis upside down.
When the assembly was finished, a line worker with a spray gun dusted the components with a thin coat of black paint.
Just enough to keep it from rusting at the dealers....
Old 02-21-2011, 01:44 PM
brians's Avatar
brians brians is offline
Originally Posted by 68RamII View Post
In the first set of pictures it shows a heat shield over the driver side exhaust manifold. This is the first RA II that I have seen that has this heat shield. Has anyone else ever seen an RA II with that heat shield???
John:
Good question. In theory, yes the RAII should have had one as delivered.
The std. air cleaner should have been on the car and taken off by the dealer.
Being this was a “fair” weather RA system, you had to put the regular air cleaner back on
during winter months and the heat shroud was part of that system. Personally I have never seen one, but it probably was one of the first things tossed. From a restoration standpoint, I’d consider it just as correct to not have it as having it. I have also never seen a RA car being shown with the std. air cleaner and closed scoops in the trunk.
The 69 parts hood lists a 9794227 part number for the outer ex. shroud for the 68 GTO RAII. It calls for the same inner as the 69 RAIV. Some of the pictures I have of supposed original cars do show studded head bolts on the LH side location.
Now the odd question is what did the 9794227 shroud look like? That is a different number then the 69 RAIV.
gto66yellow – where did that ex. Shroud come from? Was it on the car when you got it? From your picture it looks like a cut-up version of the RAI heat shroud.
Brian
“If you ain't first, you're last” - REESE BOBBY
Old 02-21-2011, 08:43 PM
gto66yellow gto66yellow is offline
That is the original. I bought a repo Ram Air III and it is stamp the same but the original is smaller, I was able to clean up the original and save it. It was painted black from the factory. The inner sheild looks to be the same as a Ram Air IV. John if you want I can make you one from the repo I have or I will take my money back for it if you go this route.
Old 02-21-2011, 08:49 PM
The Boss's Avatar
The Boss The Boss is offline
Any chance you could make two? PM or email me your address I can send one out!
And go racin' in the street.
Old 02-21-2011, 10:30 PM
68pongto's Avatar
68pongto 68pongto is offline
Maybe you could post some more detailed pictures of the heat shield. Front side, back side. Since the RA II piece is so rare. Scott
Old 02-22-2011, 09:06 PM
Diego Diego is offline
I'm presuming Verdoro sprung from verdant which means:
1. (of countryside) Green with grass or other rich vegetation.
2. Of the bright green color of lush grass.
In Spanish, green is "Verde." "Verdant" comes from the same root, presumably Latin.
Old 02-22-2011, 09:08 PM
68RamII's Avatar
68RamII 68RamII is offline
Hey Rick,
Thank you for posting these pictures. If guys like Brian haven't seen one of these heat shields then it must be really rare!!!
I would appreciate you being able to make the other one so I can install it on my car. I will give you a call.
It would be great to see a few more detailed pictures of the heat shield off of the engine.
Thanks...
John R. Zerucha
1968 GTO RA II Convertible
Sorry..The race car is Buick Powered
70 Skylark @2800 lbs
8.78 @ 153 mph 535 Stage 4 2850 lbs
8.97 @ 149 mph 523 Stage 4
9.36 @ 143 mph 464 Stage 2
9.77 @ 135 mph 464 Stage 1
88 Hawk @2355 lbs
8.06 @ 167 mph 535 Stage 4
7.90 @ 171 mph 572 Stage 4
Old 02-22-2011, 10:11 PM
The Boss's Avatar
That's a real gift to find an original out there!
Thanks Rick!
Old 02-23-2011, 08:44 AM
Judge273's Avatar
Judge273 Judge273 is offline
Anyone got the production number breakdowns on the sleeper roundports?
GTO Man vs Auto?
FB Man vs Auto?
Mike/Illinois
Old 02-23-2011, 08:52 AM
The Boss's Avatar
GTO
RA II, Manual 199
RA II, Auto 47
These numbers include the convertibles.
Old 02-23-2011, 08:55 AM
Judge273's Avatar
I've seen two GTO vert RAIIs. Which is about as many HT I've seen. A green one and the OP's car,
Boss, How many HT have you seen or know about? I don't think the vert breakdown is 50/50.
Mike/Illinois
Old 02-23-2011, 09:01 AM
The Boss's Avatar
3 verts that I know of, John's, one in NY & one in Chicago - that one an auto.
Hard tops? Around 15, only 3 auto's though.
Old 02-23-2011, 09:13 AM
Judge273's Avatar
Probably the lowest survival rate of any roundport? Any pix of John's vert?
Mike/Illinois
Old 02-23-2011, 09:18 AM
muscle_collector's Avatar
there are probably several still out there sitting in someones field or garage and they dont have a clue what it is.
with the engine missing, there isnt any stand out tell tale signs of what it is. with 4:33 gears in the gto, it didnt take much to lose the engine. if the dealer or original owner didnt put the ram air scoops in them, they would look just like a regular gto.
Old 02-23-2011, 09:23 AM
Judge273's Avatar
That what keeps the hunt on for those sleepers in the sheds...Just like the OP and brians FB story. Ebay is good for some Pontiac treasure hunting still.
Mike/Illinois
Old 02-23-2011, 12:01 PM
mcduck mcduck is offline
Found figures on some website which gave RAII engine production, which was slightly higher than number of cars built but still under 400 total. not sure how accurate that info is but either way they are scarcer than RAIII, RAIV or 455SDs.
I am slowly acquiring all the mechanical bits... I would **love** to find an original RAII car minus drivetrain at this point.
1968 GTO Convertible... triple black, 4spd, 46K orig miles - SOLD
- 1963 Catalina Coupe... marimba red ext/maroon int, 389 auto, 53K orig miles!
Old 02-23-2011, 12:24 PM
Judge273's Avatar
400 built from March of 68 til when? It maybe more scarce since it came late in year, and only in GTO or FB. Out of nowhere for many who didn't see it coming...
I think by that time the Judge and TA for 69 were advertised. Both could be had with the RA IV...
Mike/Illinois
  #38
Old 02-23-2011, 03:05 PM
More pictures of the heat shield
ID:	235656   Click image for larger version
ID:	235657   Click image for larger version
  #39
Old 02-23-2011, 04:01 PM
The Boss's Avatar
Earliest build date I've seen so far is my Pontiac built 05C with an invoice date of 05/28. My 05A Baltimore built RA I has an invoice date of 05/08.
  #40
Old 02-23-2011, 05:04 PM
Judge273's Avatar
March 68 is when Pontiac offered it or made it available? Seems to be the written word...
Mike/Illinois
