Ok back to the harness. The ebay link was/is dead so I never got a chance to look at it but.. I did google H4 and H1 sockets and I see that the H4 is a 3 prong that looks at least similar to the factory sealed beam configuration and the H1 is a single prong.
I understand about the relay but will the factory socket plug into the H4? and how does the H1 ground?
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
suscribed
http://www.ebay.com/itm/CERAMIC-H4-H...item4847c662d5 The H1 is a hot and a ground so two prong. Hella include short jumper leads so it fits the SAE/DOT H1 connector on American cars. Factory will plug right into the H4 low beam. |
I tried to video the results last night, but using a Droid Razr HD didn't work so well. I don't see anywhere near the amount of light in the vid that I see with my eyes, but you can sure see how it lights the road side signs as if they're on fire
http://youtu.be/xt4lV1XD24k And I got a youtube copyright notice on J/A's White Rabbit playing in the background and trying to remove the audio track left it scratchy and distorted. Last edited by 61 389-348; 09-03-2013 at 10:30 AM. |
I don't know if these were halogen or not, but if they were, I should have wiped finger prints off of them after I put them in the lamp socket. Giving them the benefit of the doubt, I'll try another pair. They did make the taillights way brighter so it's well worth another try. |
I'm sure these lights are the best answer for lots of light which I appreciate. But I feel the need to relate what I did "back in the day". Had a 64 GTO which liked to run fast at night. So I bought a set of Lucas Flamethrowers (really a spot light beam) to put in my high beam sockets. I used an old Ford starter solenoid for a relay so I wouldn't overload the factory wiring. Remember that back in 64 you couldn't get a lot of what is available now.
I transferred the system to later cars until the Lucas had injested enough water around the bulb to screw up the reflectors. Remember the Lucas were English who were not noted for fantastic electrical systems. But I did have people flash my brights from a mile away. Then I used the wiring to put a set of aircraft landing lights in the high beam sockets. They were sealed beam and fit the 5 3/4 holes. Of course you had to be careful when to light them or you felt you could burn the paint off the trunk in front of you. One time late at night I was driving an interstate and could just pick out one of those big green signs up ahead. I kept an eye on the sign and the odometer and I drove 2 1/2 miles before I passed the sign. Eventually the lights burned out and I trashed the rest of the system. Might have to return to yesteryear and put in what is being suggested here. |
Plus, I'm not getting anyone flashing me on low beams so I've got them adjusted pretty well by now. |
I appreciate the tip.
1965 Grand Prix 2002 GMC Sierra Denali (4 wheel steering is highly underrated) The views and opinions expressed by me in no way reflect the views and policies of General Motors. |
Just curious. Did anyone end up trying this? If so, thought?
Need to replace my high beams on the 66 wagon. Looked at this and am wondering if that Summit harness linked will work. Confused as to the relay deal. Know what bulbs to use, but not sure on the other. Got some good halogens in for the low-beam already. They are what Scott had in the '66 GP. Had to modify the cup to get them to seat, but an improvement.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
Is this the same kit for a little bit less
http://www.ebay.com/itm/CERAMIC-H4-H...-/331051630353 Thanks for a good informative post;
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
This is great info; thanks;
Low Beam link from Summit http://www.summitracing.com/parts/hl...0811/overview/ High Beam link from Summit http://www.summitracing.com/parts/hl...5831/overview/
Kind of funny Jim, but I was thinking about this thread just the other day. I saw the one that you found on ebay and this one also http://www.ebay.com/itm/151152323094...ht_2513wt_1161 They all look to be the same kit. The one I posted is free shipping. The one I found does not state that it is ceramic, so I sent a msg to them 2 days ago w/out any response. I will try again, but from what I can see in the pics, they all look like the same kit.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
And regarding the harness on ebay: it's too short to reach each side in a car with vertical headlamps. There's a version that an ebayer name 57mike or something similar who sells the same thing that's about 6" longer and even that will barely reach. I used the ceramic extension he also sells for it to reach easily. 63 is finally in the body shop now getting the deer damage fixed, but I drove it up until a couple of weeks ago. While on low beam, still not one flash from oncoming cars due to glare, but even my higher end HID German car owner friends find it hilarious what kind of light I can throw way way down the road with the high beams. Last edited by 61 389-348; 11-04-2013 at 12:47 AM. |
Avoid this seller. It's the only negative feedback I've ever left someone on ebay. This is the one I used .... as his is about 6 to 8 " longer holding it side by side with SunC untClassics one http://www.ebay.com/itm/H4-HEADLIGHT...8ee361&vxp=mtr |
http://youtu.be/xt4lV1XD24k the vid doesn't do it justice because the amount of light that the phone camera doesn't pick up. It will make roadside signs appear as if they're on fire. I found a vid somewhere shot with a good camera that is a lot closer to what I see with my eyes. I don't remember what camera he was using but it's much closer Last edited by 61 389-348; 11-04-2013 at 12:46 AM. |
#38
Found it
http://youtu.be/bWS30yHBuLQ this guy has 840 watts of light on the road, shot with a proper camera, and I have 560. Mine aren't quite as obnoxious, but close |
#39
Thought I'd bump this one to the top since a PYer had some questions about relay and harness.
#40
'61, I see nothing about how you resolved lighting both filaments in the low beam bulb. Did I miss something ? The relay harness on ebay doesn't appear to have this capability.
The simplest way I can see to light all (6) filaments is to move the wire at the dimmer switch so that the low beam filament ( low beams ) is connected to the power coming from the light switch on the dashboard. This way the low beams are on ANY time the light switch is in the on position. Then the dimmer switch would toggle to the high beams setting and connect the high beams to +12v, but the low beams would still be energized due to the low beams being permanently connected to the incoming +12v. Hope I didn't confuse you. This is essentially what the Ron Francis kit does. I spent 3 hours in garage last night with computer and wiring diagrams to get to the bottom of this. So how did you get the low beam filaments to stay on when dimmer is in high beam mode ?
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x Last edited by Jim Doran; 07-30-2015 at 01:05 PM. |
