Years ago Greg Merrick gave me a ride in their 70 LeMans. It's a RA IV headed roller cammed 428 and it was something else. A great combination.
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
I've got some Pontiac journal 6.8 Crowers from Paul Spotts a few years ago for the connectors on it. Going to be a heck of a dish for the 69cc chambers to run pump gas though!
I'm planning one for the GTO as I think it will be a good match with the Richmond 4+1. The lack of choices in the 4" crank category is not a good sign however.
Singleton, thanks for the info regarding the RPM forgings. Anyone else??
"Objects in mirror are closer than they appear" ![]() |
RPM site lists a 4340 forged 4" stroke, 3.25 main, (with 2.20 rod journal), on sale for $429.99, (40% off).
The 3"main version is regular price, $720
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
Mine will go in the 65 GTO with a "race" straight gear Richmond 5 speed behind it also.
I'll be building or having built, a 4" 400 for my street/auto X car. I want to be able to run mid 11s, drive anywhere, and ring out the mill on straightaway but not have so much tq that I'm busting loose after turns. The 4" crank seems like the best choice for power/RPM comprimise.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Yep a 455 with any tweaking and goose it in the turns and you get some bad oversteer no matter what the tires are even sticky DOTs
Not sure of others, RPM had the 428 cranks (forged)on sale most of last year for 40% off. They have specials.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
I have been running the 4" stroke engines for years. I have tried 3.75,4.00.4.21.4.25 strokes in stock blocks.
Currently have a 4.050 stroke with a 4.180 Bore--in my experience this is the best combo to date I have run. Consistently revs 7200-7500, and has made enough power to push a 3800lb street car to 10.0xx et's with Carter AFB'S and 335CFM E-heads.
