Old 02-11-2016, 03:44 PM
blubomber's Avatar
blubomber blubomber is offline
I think the long branch exhaust manifolds and a larger volume air intake are really the only differences between your XF and a XG coded 428.
The heads, cam, carb, transmission are identical.
Your Ram Air manifolds certainly are good substitutes for the long branches.
HO cars came with chrome valve covers and air cleaner lid.
'69 Bonneville convertible
Warwick blue/ parchment interior
53 option accessories
2 more to go :-)
Old 02-11-2016, 04:11 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
This car has the chrome lid and valve covers too.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 02-11-2016, 04:29 PM
Ram4king's Avatar
Ram4king Ram4king is offline
I might have a positive for it. Your car is totally correct. Your getting bad info here. Never have seen 48 heads on a automatic gp. I've seen 46 heads on a automatic 428 but never 48's. I also believe the carb and cam are different on the HO. But that is neither here or there. All 428 engines when equipped in a gp have chrome valve covers and air cleaner lid.
Old 02-11-2016, 04:56 PM
1oldgoat's Avatar
Thanks for the info Don. I know a little about GTO's but a little light on GP knowledge. It just seems like a decent car to make a cruiser out of and keep almost all original. My email is sda24237@gmail.com if you want to talk about the axle or I can call you later when I get off work.
Old 02-11-2016, 08:01 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
standard gear for a '69 with A/C is 3.23. if it is equipped with a safe-t-track, it will have a "medium duty" 4 pinion case.
Old 02-11-2016, 09:48 PM
blubomber's Avatar
Don,
Were #48 heads used on M/T Grand Prix cars?
#46 heads with a 10.5:1 cr were used on the std 428 in B body cars. They had a 262 carb and used a .066 cam.
B body 428HO's had #62 heads, a 10.75:1 cr, 4 bolt main caps, a 268 carb and the .067 cam on A/T cars. Almost no M/T B body cars were produced.
I have always understood that the .068 cam was only used on M/T cars
2 more to go :-)
Old 02-11-2016, 09:52 PM
blubomber's Avatar
chrome valve covers and air cleaner lid were std on the B body 428 HO but not the std small valve 428's. I did not know that chrome valve covers and air cleaner lid were std on all GP 428's, either XF or XG's
2 more to go :-)
Old 02-12-2016, 12:50 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Originally Posted by 1oldgoat View Post
Do you guys know what the standard axle ratio was for a 69 SJ? There is nothing on the PHS so I am guessing it is whatever is standard for a 428 automatic with A/C.
Equipped with a/c the ratios would be either... with "no" axle option shown on the invoice 3.23 is the std ratio... if the "economy" axle was shown on the invoice you would have 2.93.
Old 02-12-2016, 01:10 AM
428ho4spd's Avatar
FYI... early production '69 GP's with either the 428 engine option or SJ option were built with the limited slip rear axle prior to the bulletin released on Jan 9th, 1969... what is the production date code on your data plate?
Old 02-12-2016, 02:32 AM
1oldgoat's Avatar
My car is 04D production date. No economy or any other axle options on PHS.
Old 02-12-2016, 01:16 PM
428ho4spd's Avatar
I've only seen a few SJ's over the years that didn't have safe-t-track listed on the invoice, your car would be another. The axle stamp for a 3.23 posi in a GP is "5F", these are fairly common if you wanted to search for one.
Old 02-12-2016, 02:33 PM
1oldgoat's Avatar
Here's a copy of the PHS.
Name:	69 GP PHS.jpg
Old 02-12-2016, 02:46 PM
1oldgoat's Avatar
There is an interesting twist to the story about this car. The dealer who sold this car new was good friend of my father. I was actually in that showroom in late 1969 or early 1970 as a 5 year old kid.
Old 02-12-2016, 03:05 PM
428ho4spd's Avatar
Great story! Thanks for posting the invoice, always neat to see how these cars were optioned. Does your GP still have its original alternator?... it should be the "open face" self regulated 61A unit having a/c and heated rear window.
Old 02-12-2016, 03:10 PM
428ho4spd's Avatar
I had a similar '69 SJ to yours back in the early 90's, here's two old photos of it...
ID:	420607   Click image for larger version
Old 02-12-2016, 04:36 PM
1oldgoat's Avatar
I don't know about the alternator. I will check it. Are they hard to find?
Old 02-12-2016, 07:22 PM
428ho4spd's Avatar
Yes, they can be.
  #38
Old 02-12-2016, 07:48 PM
1oldgoat's Avatar
Looks like it might be the right style but looks like a rebuilt that has had the numbers taken off.
Name:	69 GP Alt1.jpg
ID:	420618   Click image for larger version
Name:	69 GP Alt2.jpg
ID:	420619   Click image for larger version
Name:	69 GP Alt3.jpg
  #39
Old 02-13-2016, 04:03 AM
428ho4spd's Avatar
That looks like the aftermarket unit on my car as well. Its similar, but not the original type unit.
  #40
Old 02-13-2016, 08:05 AM
1oldgoat's Avatar
What number should it have?
