Old 05-22-2016, 08:35 AM
blubomber's Avatar
blubomber blubomber is offline
SD455J
My former '69 Bonneville YH 428 was re-built in a similar manner. It got a .030 overbore, a .067 equivalent Comp Cam, new pistons with a 9.5:1 CR, stock intake, balanced crank, fuel pump, new timing gear and chain, main seal, HEI kit, rebuilt Q'jet, log manifolds and dual exhaust. I had a set of original 428 HO long branch manifolds and the large volume air cleaner intake that went with the car when I sold it. I never had it dyno'd but would expect the numbers to be roughly similar as your said. Whatever the exact numbers it ran exceptionally strong and smooth. New owner is installing the Long Branch manifolds with stock 2 1/4" pipes (2 1/2" from the manifolds tampered down to 2 1/4" after the mufflers) which will boost its performance even more.
'69 Bonneville convertible
Warwick blue/ parchment interior
53 option accessories
2 more to go :-)
Old 05-22-2016, 10:57 AM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
One of the now defunct Pontiac magazines did a comparison test on #15 heads vs. some other large valve heads. I don't remember the exact large valve heads, but the 15s actually did quite well and had good breathing. The main drawback was the pressed in studs, and even that was only an issue if larger lift cams and heavier springs were used.
I quit using the #15s years ago (80s) because the engine pinged a lot, (even after a total stock rebuild) after they eliminated high octane leaded fuel. Back then, the local expertise about cams to compensate for that was not easy to find. And there was no internet to discuss with other Pontiac people.
Old 05-22-2016, 12:40 PM
blubomber's Avatar
pressed in studs are of course easily addressed if that is a concern due to high stress use of the car. They can be drilled for screw in studs or they can be pinned.
2 more to go :-)
Old 05-22-2016, 03:43 PM
SD455DJ SD455DJ is offline
David, I had my rocker studs pinned like the good old days. With proper cooling, timing curves, jetting and 93 octane fuel, it behaves fairly nicely, except for really hot days (90 and higher) it'll complain when loaded. It needs a better radiator and I have a new Cold Case aluminum to try out in it. It got 17.5+ mpg at 60-65 mph travel on the 2-way state highways driving to Norwalk on its maiden voyage. So that included stop & go driving through the towns adn villages along the way. This motor is in my 70 LeMans 4-dr sedan with an M-20 4-speed and a 3.08 GP 12-bolt (Canadian McKinnon). So it is about 700 lbs less weight to haul around and i'm sure that helps in the stop & go fuel economy.
Old 05-22-2016, 03:52 PM
David & Blubomber, Here is the dyno sheet (also tested it as a 2-bbl), pics of the motor, new rear end and car.
Dennis
ID:	428965   Click image for larger version
ID:	428966   Click image for larger version
ID:	428967   Click image for larger version
Old 05-22-2016, 03:56 PM
...forgot the car...I appologize for hijacking North's thread...sorry.
Dennis
Name:	Dennis' 70 4-spdeMans.jpg
ID:	428969   Click image for larger version
Name:	New Interior With Front Seat.jpg
Old 05-22-2016, 04:11 PM
I switched from the #15 to lower compression. I battled the pinging for 2 years. It was worst in the summer with the A/C on, but living in south Florida, summer is at least 1/2 the year. I switched to 96 heads from a 1971 or 1972 GTO. That lowered the compression enough that it never pinged again. But the engine was no slouch with the #15s.
Old 05-22-2016, 05:01 PM
blubomber's Avatar
My Bonneville had the heavy duty radiator as std equipment with A/C. I still have the Super duty radiator from the Bonneville Brougham convertible 428 HO car I parted several years ago. Pretty rare. I know the aluminum rad's are more efficient but I am a sucker for original equipment.
I found the same thing driving my car around central VA in the summer. It would ping in the summer (very hot and very, very very humid) when pushed hard but if I waited until the sun went down and cooled things off a bit she really woke back up. Of course the best was in Nov to Jan. clean, cool, dense air.
2 more to go :-)
Old 05-25-2016, 11:39 AM
North, do you have the PHS, window sticker, and or build sheet for your Brougham? I'd love to see all she was equipped with. I love the color combination, it exudes the '60's. She should move along pretty well even with the small valve 428 coupled with the 3.08's.
Dennis
I have the PHS and the order form from the original dealer. It looks like the buildsheet is in the rear seat back but I didn't pull it out yet. I'm at work so I can't post the PHS but by memory:
TH400, A/C, duals, PDB, PS, Brougham (includes PW), six way seat, power trunk, AM radio, rear speaker, power antenna, tilt, cruise, gauges, soft ray all, Cordova top, wire wheel covers, deluxe belts, lamp group (reel out hood light and cornering lamps), door edge guards, rear defog, remote mirror, visor mirror, headrests, mats front and rear, J78 white walls, HD batt, HD air cleaner, Instant-aire. It was ordered with power locks but they didn't happen. I added a woodwheel and I'm waiting for a repair service to install a spare 69 B car stereo radio with the correct dual rear speakers.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 05-25-2016, 11:44 AM
btw no apologies required for the engine mod takeover of the thread, I'm doing the engine in my Bonneville convertible as we speak, 428HO with original 62 heads but I swapped in a 455 crank and cast pistons that result in 9.5 compression. I can't think of the brand but the cam is basically a 067 but with greater lobe separation to address octane concerns, I've run the same cam in a 400 with similar compression and like how it runs and sounds. We have 94 octane here but it has ethanol so we have to run 91 octane to get pure gas.
1969 Bonnie Cvt
Old 05-25-2016, 12:41 PM
Thanks North for listing the options (by memory no less). I have really grown fond of the B-bodies of all varieties and years...hi-po, lo-po, 4-dr, 2-dr, hardtop, sedan, convert...you just don't see that many anymore.
Dennis
Old 05-25-2016, 12:57 PM
North, the Summit 2800 is similar to the 066/067 cams 204/214 vs 200/211 at .400"/.422" vs. .410"/.410" ground on a 112 LCL. If it isn't too late, you should consider the Summit 2801 cam which is 214/224/112 at .422"/.444" which will work with stock valve springs if needed. The 2800 will make a 9.5 to 1 455 a detonation machine and will need a very sharp tune to run on 93/94 fuel. I run the Summit 2802 cam (224/236/114 at .444"/.466") in my 9.9 to 1 455 (464) and even with 93 octane fuel, I have to run the best cooling system (alum rad., big vane wp and small pulley), watch the ignition curve, and jet on the rich side. I think the RAIV cam with Rhoads lifters would work better with my compression. I think the 2802 would help your driving situation and it runs and idles like a smaller cam, you would think you had an 067 in there. However, you would need aftermarket valve springs to allow the lift of the cam.
Dennis
Old 05-25-2016, 01:48 PM
By memory the cam is between the 2800 and 2801 in terms of duration and lift. I might be wrong about the compression, maybe it is more like 9 and a quarter.
1969 Bonnie Cvt
Old 05-25-2016, 01:50 PM
I drive these type cars very sedately, what I want is nice smooth idle and effortless low-mid pull. The car is heavy and only has 3.08's which equate to 2.73 in typical musclecar type wheel circumferences.
1969 Bonnie Cvt
Old 06-01-2016, 12:54 PM
I think with a cam that has 218/228 in a 9.25:1 428 with small or big valve heads will pull the Brougham very well with the 3.08's.
Dennis
Old 06-01-2016, 06:31 PM
blubomber's Avatar
I don't remember the exact figures but the cam sounds about right. What I do know is that even with the lowered compression, pump gas, and small valve heads I surprised more than a few younger fellows driving newer Mustangs and Camaros. Re-building the carb and the accelerator pump on the Q'jet was probably the most important factor though. The car had a little "hiccup" on hard acceleration up to that point.
2 more to go :-)
Old 06-02-2016, 05:16 PM
Pontiac Derek Pontiac Derek is offline
Very nice! I honestly would recommend a Real Original 067 cam
Its 200in 213ex .410-.410 113lsa 113ilc these were a very good cam for the big cars and added a lot over the 066, i have had both in my 69 370hp 428 Grand Prix and the 067 was much stronger, i highly recommend using at least 1.65 rockers with it to get aprox .448 lift
The 066 was the grocery store max power below 4000rpm cam lol
Many try to say the 066 and 067 are the same but its not true!
I Had Howards Grind me a Higher Lift Version and it worked great in 389-400-428 motors in big cars!
Specs were 202in 215ex .458in .465ex lift 113lsa 268-280 advertised
It pulled from idle to 5000-5200rpm and had a nice Heavy idle sound
My 72' came with a 2bbl 400, number 7J2 Heads with 1.92in 1.66ex valves
Mine had 65k when i got it last year and even though my car has a measured compression ratio of 8.00:1 it surprises people and so far runs 15.8-15.9 in the 1/4 mile, not a rocket Ship but more than enough to blow the tires off !
Here is what i have done, these changes Made Huge Differences!
First thing i did was a tune up and i rebuilt the 2GC
That helped a bit
Next i took off the timing solenoid and set the total timing to
36* with the vac advance disconnected, This was a Night and Day
Change!
Next after tuning the 2bbl a bit i said F-it and i got a
Q-jet from a 77 trans Am, completely redid everything, i build Q-jets as well as engines for a living.
At the same time i got a 72' iron intake, you must make sure you use the correct intake/and gaskets because the Ex crossover is different up to 72'
I port matched it to standard gasket size
I also Added a Pertronix Style ignition to the car
Man its a whole Different Car from when i bought it!
It went from i would guess 150-160hp stock to i would say 230-240hp
With those changes, it now Roasts the tires if i stand on it and it pulls much harder!
72' 400 2bbl specs
8.00:1 compression, small valve heads, 254 cam .379in .408ex 196in 204ex duration, 269-277 advertised duration, 113lsa 113ilc
Very Anemic stock but being a 72' 400 it still had the better pistons so its identical to most any 400 before it so i am adding some mods here in the coming weeks fwiw
Adding 270cfm #17 heads, compression with be 9.35:1, summit 2801 cam
214-224 with .489in .511ex lift 112lsa 108ilc budget deal!
HS 1.65 rockers, fully ported Iron 4bbl and 850 Q-jet
Long 4 tube headers, dual 2.5" exhaust, 22-2400 stall with 3.42 gears and a trutrac posi, plus a ratchet shifter of course!
Because of the heads it will be 405-415hp and 455-465tq
Just something to play with until my 467 is done!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #38
Old 06-02-2016, 07:30 PM
blubomber's Avatar
All good info. Just goes to show how much potential is in these motors. Adding the Pertronix HEI to the distributor did help, new coil, good wires, plugs, and of course timing are essential. Good radiator and water pump are also important. With all that said if the motor is well maintained and all set up correctly these are very potent mills. The genius of the Pontiac engineers to be ale to make one block have so many variants and be able to perform wonderfully across all of them. Truly from mild to really wild. No other manufacture had such a multi-talented block.
2 more to go :-)
  #39
Old 06-02-2016, 10:59 PM
Red face
I hear some builders saying step up to Modern Parts, the old pontiac parts are Ancient and you will leave a lot of power on the table, Dont use those Old School Cams lol i say thats alright they havent built a new pontiac engine in 35 years either and we still use those!
Other than Buick,Olds, and Caddy Pontiac understood how to move a heavy car!
There is still a few things we have yet to improve on!
The RA4 cam is amazing in applications that can use it and you would be hard pressed to get a modern cam the same size to out perform it!
The 068 cam is Probably the most versatile street performance cam made for a pontiac
The Factory 4bbl intake is still the best intake that fits under all hoods and was designed during the SD421 engine program!
Machined Combustion Chambers
Doweled main caps, still the best way to locate caps.
Anyways, yeah Unbelievable how smart these guys were!
BUT i will never understand why they used cast rods!
Sorry for the high jack!!!
  #40
Old 03-17-2017, 12:59 AM
Update on my 4door Bonnie;
Productive winter, put a nice set of 235/75/15 goodyears with a 3/4 whitewall as the tires on the car were early Michelin X radial tires from the late 70's.
Also popped on a Waldron exhaust set up, clone of the original dual system the car was ordered with. Fit beautifully, but they don't offer any factory style hangers. I was able to salvage the four original hangers by changing out the rubber from the universal hangers and fit it to the dry factory ones.
I also found a really nice original nose and had it and the rear valance painted (was banged in). Came out nice and blends in better than expected considering the fading of the hood and trunk.
Today i spent the evening swapping out the factory AM for an original 69 2piece stereo and an 8 track, took about 5 hours but went very well. Started by replacing the blown factory rear speaker and added a second rear (both were reconed originals) with the factory insulating boxes. Had to pull the glovebox, ashtray etc to mount the multiplex properly (over the glovebox) and run the 8 track cables. Carefully measured the factory installed 8 track in my Bonnie ragtop and located the mounting bracket properly. Amazingly all worked great right off the bat.
Sounds really nice, Howard Foulds has done a bunch of refurbishing of radios and 8 tracks for me and as always his work is top notch!!!
Funny thing is 69 B bodies had the 8 track unit always in black while the A, F and G cars were all color keyed to the dash pad color. I guess they figured the black 8 track matched the black dash bezel area.
Next is to pull the engine, clean it up and do all the gaskets and seals etc, detail the engine bay a bit and drop the engine back in ( someone put in a HEI distributor and painted the upper part of the engine ford blue but left the original distributor in the trunk complete with Q3 68 factory dated wires). Engine runs so well that I won't rebuild her.
After that is a front end freshening, springs are still perfect ride height wise but some bushings look bad.
ID:	449882   Click image for larger version
ID:	449883   Click image for larger version
1969 Bonnie Cvt
