it will reduce by-pass coolant and force a greater volume/percentage thru the radiator. Drill plug too .250..
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
I'd love to hear what you consider "super tight squish", along with your rod/piston combo (material, weight, piston-to-bore clearance, etc.)
I think I put Father-In-Law's 455 together with .045 squish/quench; but only because my machinist didn't follow my instructions to ZERO-DECK the block. He got it to .005 in the hole. I was shooting for .038--.040 squish. Apparently I was too conservative...I assume you're running less than .040. |
My '73 runs at 190F in the head all the time... except when sitting at a stoplight for more than 20 minutes with the AC on when the outside ambient is above 95F. It crept up to 210ish. My clutch fan could be stronger I guess... But then my modern cars don't exactly like to sit at idle with the AC on for 20+ minutes either!
A toilet overflows, but only when it's stuffed full of chit.
So don't stuff your car full of chit, and it won't overheat. |
I have a '72 vert with the stock 350 2 bbl radiator in it with a 455 with 9:1 CR and a 160 F T-stat and flex fan. Car only gets up to 170 F on a 90 +F day regardless of driving conditions. I have to put in a 180 F T-stat so It will get to a higher temp. In the fall it doesn't get above 140 F.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Your cooling system seems "too good to be true"; which could be worth some investigation. |
I haven't verified the temp with another gauge, but before I put the flex fan on, I had a Hayden severe duty clutch with a factory 7 blade fan. The car would get over 210 F on a hot day idling which is why I replaced the clutch fan. I had the flex fan sitting around and tried it to see what happened.
