Hopefully no one would use a dial indicator by cycling the crank and trying to decide where the highest position would be on a piston. I use a dial indicator on a bridge all the time by going .050" before and .050" after TDC and splitting the difference - which is the same procedure as a piston stop but a little less barbaric. When using a crank socket and degree wheel I prefer to come up on the measurements in the same direction since there is slop in the crank socket keyway.
How about you TRY to answer the OP's question instead of spouting off? Quote:
Hope that helps.
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
The only person who runs rampant here is YOU Chief. Been doing it way to long. Another time out should be on the way for you.
Practicing social distancing for 65+ years |
