if you want the most power potential i would go with the ported hurricane. SD performance is one of the best pontiac head & intake porters, so your getting that work already done, just match the ports to your heads & clean up the plenum area. if you are looking for a place to do the porting, check out SD performance, they are also one of the best values for CNC porting out there.
i havent installed mine yet, i use a factory SD ported HO intake that im happy with, but may install the hurricane some day just to see what it does. you still have the 10sec t-type? would like to see a pic of that. |
![]() Quote:
Shawn 1971 Formula #s match white/tan 1973 TA Brewster/white #s match 1972 Buick GS455 #s match 69k miles now a 470 stroker. 1986 Buick Ttype 66K miles many mods 10 sec street car. 2001 Mustang gt premium vert. Mamas car |
![]() Quote:
should have a "manage attachments" button when you select post reply. then just select where to get the pic from & it will download the file & post in your reply.
See if this works. The GS should make it into the mid 10s this year also we just finished the 470 motor it made 670 hp and 620 tq.
The Tomahawk is about the same height as a stock factory iron intake.
nice car. thought it might still be the turbo v6.
It is a turbo6, the gs is a 1972
![]() ok, confused it when you said mentioned the 470 motor... care to share any specs on the T-type? 10's out of the v6 is awsome? |
Sure it a rebuilt stock shortblock forged pistons,, ported heads & intake, 66 MM turbo 23 row intercooler. . Hydraulic roller cam, 80# injectors, dual intank fuel pumps. volt booster, full stainless exhaust including headers. 3" downpipe, built 200r4 with a 3500 stall vigilante 5 disc lock up TC. Stock 3.42 posi.
Run a Tomahawk. Mine works great on a 9.3 455. 10.98 with it.
![]() Quote:
any other specs on your engine/car? 10.9 with a 9.3 455 is pretty fast. is the tomahawk ported? & what carb?
How much does it weigh??
Mike here drives his street car to the track and has gone 11.30's in the past with a 9:1 455, using self ported iron d-port heads that only flow 220 cfm. Doing it in the desert heat no less, in a 3500 lbs car. He uses an old school warrior intake on it. The combo works pretty well. Here's just one pass with 3 lbs. fuel pressure. Struggling fuel system problems has caused his ET's to be all over the place but we've always felt once that's ironed out the car would drop in the 11-teens or so. https://youtu.be/TWZBq9aM1bs |
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
Yes id love to know too i was hoping for mid 12s out of mine.
#38
Here's an SD performance intake comparison, interesting.
http://www.sdperformance.com/newsStory.php?newsID=44
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
#39
"Yes id love to know too i was hoping for mid 12s out of mine."
That should be a cakewalk ! .
#40
![]() Quote:
The carb is a Proform 850 main body with the rest from a basic 850 DP. Car is a 69 GTO without interior and roll bar, 9 inch rear with ladder bars. .060 TRW 455 with ported 71 HO heads and Hooker Super Comps. Solid roller cam .689- . 264-.271 UD. Converter is a PTC 9". I leave at 3600 with brake. I trailer it as the ex is open. It has been 10.84 with a Warrior intake. Engine is long in the tooth (1990) but still runs great. IMO the Tomahawk is a very good intake for most with iron heads. |
