So I got the replacement cam gear today, the marks/dot are in the same place.
The distributor is new, is there any way for it to show a mark that is not where it shows, or do I dig into the cam and see if I can find anything. I'm at a loss for what to do next. |
Put it together "dot-to-dot", enough that you can crank the engine. Maybe even leave the timing cover OFF, for now.
Take a cranking compression test like I asked previously. Post the results. You took the engine apart too soon, you should have done some diagnosis before disassembly. Low cranking compression will make for a pig of an engine. You might be able to improve low compression by moving the cam around with advance/retard sprockets or offset keys. If compression is good, you've mostly verified basic bottom-end health, so the problem is probably in the carb or distributor, or the cam is too "wild". You could verify the cam with a degree wheel, and a dial indicator and a dial indicator holder that slides into a lifter bore, or a magnetic base and then measure either valve lift at the retainer, or the pushrod end of the rocker arm, or the edge of the lifter if you've got a long enough stem on the indicator. |
Driver side front to firewall #1 175
#3 175 #5 175 #7 170 Passenger side front to back #2 195 #4 125 #6 190 #8 180 Compression check. As far as the cam being wild, I don't think so as when it has ran, and I have ran it quiet a bit, it idles smooth, no more than a 068 but more likely the 350hp 400. |
![]() Quote:
Could squirt a little oil in it and see if the pressure goes up......Tell you something at the least
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
![]() Quote:
Could it be a bad cam lobe. I will work on the leak down test if I get home from work tomorrow. |
Rings?.......a leak down will reveal better info
Untill I get a chance to do a leak down, does this issue have any relationship to my original problem. Still wondering if it has the wrong crank that puts the balancer mark in the wrong spot?
Looks like two separate problems. |
The Crank keyway location on all of there cranks reguardless of stroke was the same.
As posted above, it's time for a leak down test!
Even with the one cylinder being a bit low, I doubt it
This initial timing problem been there the whole time or show up after the points to HEI swap?
I've seen reversed wires on pick-up coils cause this way off timing thing to happen. Clay |
![]() Quote:
together as the FiTech EFI needed 12 v tach signal so I bought a new online HEI. What can I check, are talking about the coil wires built into the cap? |
![]() Quote:
Clay |
Verified the white and green are connected properly.
Well I did a leak down on #4 and my results are input 70psi, cylinder gauge 30psi.
The air is most definitely escaping out the tail pipe. I am surprised because it ran so smooth. Guess I have two problems now. |
Yes, they can still run very good on 7 out of 8.....
