I'm going to play the "Price is Right" on this one... 1 HP
Looks like a great build... cant wait to see what it does. SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
Whats the compression? I would assume its gonna be low for an NA application due to the goal of the blower being added
I based my estimate on the 12.5:1 in his post. Stan
My first thought was 750 hp... I hope you make more!!
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
855 horsepower
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Following User Says Thank You to Gary H For This Useful Post: | ||
I went down to the machine shop today and we started it. It busted right off and sounded lazy...timing light showed 5 degrees of timing. We have it locked so we bumped it up and it’s no longer lazy...sounds like a complete animal! Let it run 1400-1500 rpm for about 25 minutes and shut it down. Tomorrow morning we go in and re-torque all of the head studs, start it and get it to operating temp and then shut it off to check lash and then we start making pulls.
A lot of variables that go into a cam selection... basic knowledge calls for more exhaust lift... duration is good in my opinion but lift is shy...you don't want a lot of overlap and spent exhaust getting in the mix...
Again, if your builder has experience with roots blowers, you're good ... he looks att all aspects... Roots are different than Pro chargers,turbos and nitrous... closest relation will be nitrous.. I look forward to the results... im gonna say 830hp on nuts.. |
845hp
I missed that..lol...
My guess is 800 hp. 680 tq. |
I think you were the closest with Slowbird next in line...837 hp, 755 Torque...dyno kicked our ass today...of note was a super sucker spacer lost 5 foot lbs but tied HP... Sent from my iPhone using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
The Following User Says Thank You to 69Goat1 For This Useful Post: | ||
Good job! Nice build
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Very nice! It really liked 40° timing? What fuel was used?
We tried 38 and it lost a few HP. Plug straps were perfect at 40. We used my Grid ignition and Q16...
Didn't realize you were running Q16. You running it in the car like this or blower going on?
Great numbers!!
The Following User Says Thank You to scott70 For This Useful Post: | ||
#38
The Q16 is what I run as gas on motor.. When it is blown it will have Alcohol in it...
#39
Are you changing camshafts before the dyno of the blower?
GTO George |
#40
I was way off... LOL
Good Job! Those are solid numbers!!! SPEED SAFE, NICK
