![]() Quote:
For St Louis I ran the 10.00 index and won the True Street 10 sec cutoff. For Martin I bumped my index to 10.25. (and broke the trans ![]() K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
![]() Quote:
Compare ET to new weather conditions Leave the 2nd ET conditions at the sea level values and compare your Tulsa and Norwalk to sea level conditions. Or put your Tulsa ET and weather conditions in #1 and Norwalk weather in #2 to see what it would run at Norwalk using the Tulsa run. ![]()
The Following User Says Thank You to johnta1 For This Useful Post: | ||
I've always heard it used in a relative fashion, such as those times when you have a DA thats radically lower than usual. In the Midwest, its the late fall season time when your stuff runs better than it has a reason to - the cool days where the humidity is negligible and the Baro is way up.. Great for setting those Personal Bests that any other time of year you cant get close to running again.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
The Following User Says Thank You to Mr Anonymous For This Useful Post: | ||
![]() Quote:
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
![]() Quote:
GTO George |
![]() Quote:
I would think at your power level u should see about .06-.08 for every 1000 ft drop if the cars tuned optimum!
The Following User Says Thank You to grandville455 For This Useful Post: | ||
![]() Quote:
I input my info from my run at Norwalk and then let is show what it should have ran at sea level and this is what I got... ![]() Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
![]() Quote:
Thank you... Sent from my iPad using Tapatalk
![]() Quote:
I can hardly wait for November for another reason than just deer hunting now... Sent from my iPad using Tapatalk
![]() Quote:
And start your burnouts in 2nd gear. (Assuming T400?) |
The Following User Says Thank You to Gary Kubisch For This Useful Post: | ||
I have to assume you were at Norwalk...lol. I am still stuck in my youth on the burnouts but I do go all the way to 3rd with it so I don’t roll out in 2nd. I also need to get a different spring rate in my car front and rear because I think I can get a 1.2x 60 out of it...still foot braking it...
Some real data from my travels over the past couple years. My wife and I race 1/8 mile predominantly and have traveled from Minnesota to Florida and many tracks in between over the past three years. My car has run as fast at 5.27 at Huntsville and Bradenton with -300 DA's. We ran 5.49 this past weekend here in Minnesota with 3300 DA on a bad track. This is the exact same car with jetting changes only. Our engine/trans/gear combination has not changed in that time. For comparison purposes my 1/8mile ET's at Norwalk in the Q16 5.34-5.36. Hope this info is helpful.
![]() Quote:
Considering the air at Norwalk, I'm confident you'll go 9.20s closer to sea level. How's you 60ft and mph? |
![]() Quote:
My 3 Saturday passes, the last one was a 9.92 but it broke all the torque converter bolts off right around 950 feet into the run and just coasted. You can see the best 60 and 1/8th was the pass the bolts broke in first round of eliminations. Friday night I went 6 rounds in the gamblers race and took home a little money. Of the time run passes I made this weekend 9.46 was the slowest and 9.42 was the fastest and I foot braked it every pass, shift it myself by ear as I never pay attention to the tach...lol ![]() Sent from my iPhone using Tapatalk
Your first two slips show the exact same et from 660 to 1320 so the third slip would've been a 9.402.
Your 60ft is slightly less than optimum for your et. That said. Better air will prudish more power, which will work the converter harder. You will run 9.2x or so in "mineshaft" conditions. Assuming the car hooks, it should go at least 1.29. Probably quicker. |
The Following 2 Users Say Thank You to Gary Kubisch For This Useful Post: | ||
Best air I ever saw was at Sears Point in the winter, something like -800’ DA.
Just log & track performance against the DA. It is the accepted method when calculating aircraft performance, so it will work for you race car. Keep in mind the atmosphere is constantly changing and the DA method simply compares current conditions to a “Standard Air” which only exist in theory…it is a yardstick for measuring air, so to speak.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
The Following User Says Thank You to 455firebird1969 For This Useful Post: | ||
![]() Quote:
#38
![]() Quote:
#39
The old Fremont Drag Strip in the Bay Area had about the best air possible. On a big High Tide it was close to 0' elevation.
I hear the property is still undeveloped since its closing. Sad. |
#40
Well yeah, on the east side of the salt flats in the bay, yes it is very close to sea level, as you refer to as the “Best Possible air”. There are a lot of drag strips around the country that are close to sea level. What you fail to recognize is the MSL is fixed, it will never change, The atmosphere is the great equalizer, it is a living breathing animal. It can and will change.
