Old 01-19-2023, 09:57 PM
unruhjonny's Avatar
I would expect that someone like OPH would know;
the fact that him and Dennis both suggested that HF wheels are the originals, had me scratching my head.
GM was known for replacing one part with another, and my post was me thinking out loud, that maybe XE was the replacement (but it may have also had an earlier application).
I only have 67-76 Firebird, 77-81 Pontiac, 85-91 Grand Am, and 85-91 (Oldsmobile) Calais master parts catalogs - so I cannot reference any pre-1977 Pontiac parts which is not listed in the Firebird MPC.
Someone will know !!!
What's ".50 offset" ??
Your reference describes "primed" XE wheels. I guess that makes sense for replacements but suggests any XE wheel has non-factory paint?
that's the wheel’s offset;
https://www.tyresizecalculator.com/wheels/wheel-offset
1970 Formula 400
Old 01-19-2023, 10:03 PM
SD455DJ SD455DJ is offline
Jonny, I'm going to double check the wheel codes on the Lemans & Tempest this weekend to make sure what code they are...I know the '69 Custom S is HF. Don't take my word as gospel...lol!
Dennis
Old 01-19-2023, 10:18 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
I have a '70 build sheet for a 06-01 build with XE listed. My 02-06 had XE's. HF may have used late in the '70 build as HF was the code for '71s.
So long, farewell.
Old 01-19-2023, 10:26 PM
Have had quite a few XE coded steel wheels, '69 production usage dates, early '70 to late Jan '70 usage wheels. Were they manufactured & installed later in production on mid '70 models, HFR has just sounded off. I will ck & get some feedback from two local '70 GTO customers who have March & April '70 built steel wheel cars w original trunk spares. One is original owner to his car, bought it new. I've seen his spare & it's def original.
HF coded 14x6's definitely made it onto numerous '70 V8 Tempest, LeMans, & GTO's, began chasing singles & pairs of HF's before picking up a date matching set to run on my T-37 Coupe.
Old 01-19-2023, 10:33 PM
From Il & Parts Catalog:
(not sure how accurate this is, but is older manual)
Old 01-19-2023, 11:04 PM
Bad info John. Many superseded code wheels.
Old 01-20-2023, 05:31 PM
goatboy1970 goatboy1970 is offline
I contacted the 1970 GTO tech expert for the GTOAA. He confirmed that the correct steel wheel code for 70 is XE.
1970 GTO I Pepper Green, YS Code, numbers matching, PHS documented
Old 01-20-2023, 05:37 PM
unruhjonny's Avatar
My experience from big car shows doesn't lend to a post like that (#27) as the end-all.
It reads to me as though there may have been two codes used depending on build date;
As an example all the 1969 Camaro guys get hot & bothered over XT wheels, meanwhile that wasn't the only wheel used - just the more common 14x7" steel wheel code for that model/year.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 01-20-2023, 05:47 PM
That makes plenty of sense, especially given the strike. I think if I already had HF wheels with good date codes, I wouldn't lose any sleep over them. Since I need a set, I'm gonna chase the XEs for a while.
Old 01-20-2023, 05:49 PM
Shiny Shiny is offline
Is there no factory documentation for these wheel codes?
I can neither confirm nor deny my XEs are original but the date code on my 70 LeMans' tag is 09C, Pontiac plant.
Old 01-20-2023, 09:05 PM
My '70 Tempest is dated 9E on the trim tag, so a real early production car too. The Lemans is dated 03B, so a late mid-year car. I'll be checking the codes and dates tomorrow. I have no idea if they are the original "born-with" wheels, or not, but we'll soon see.
Dennis
Old 01-21-2023, 09:19 AM
Heres some dates, am sure have more HF's & poss some more XEs. Have a considerable amount of mounted steel wheels to break down.
K-1-0 6 @ 14 HF
K-1-0 9? @ 18 HF (the 9 is upside down)
the latter set! have an upside down 9 in the month designation, I bought that set through GTO JOHN (RIP) before "the auction". These are the set I'm restoring the finish for the T-37 Engr car & will be running Pontiac-Pontiac standard hubcaps. The T was ordered out with heavy 14x7 HC's & will be running those for show only.
the pair of 6/14/70's I personally removed from the front of a late 70 model LeMans.
Old 01-21-2023, 11:34 AM
unruhjonny's Avatar
is there a compiled assembly manual for a Tempest/Lemans/GTO?
if so, the wheel/tire pages might shed some light on the subject.
I would think that June 1970 stamped wheels would normally be for 1971 model year cars.
1970 Formula 400
Old 01-22-2023, 11:03 AM
I could only access the original wheels from the 09E Baltimore built Tempest and all 5 are 8/2/69, or possibly 8/12/69 (the '1' in the 12 is very faint), and XE coded. I was mistaken in my earlier post. Now I'm really curious to see what came on the 03B Fremont, CA built Lemans.
Dennis
ID:	605722   Click image for larger version
Old 01-22-2023, 11:07 AM
unruhjonny's Avatar
ok then, based on what I am reading now, early 70’s should probably be XE, while late should be HF.
1970 Formula 400
Old 01-22-2023, 04:45 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
With all the dates thrown out there for the application of wheels. How far in advance of a cars production would the wheels be dated? My GT-37's production date is early sept 70 (appears pre-strike) and the build sheet shows JT for the code.
Old 01-22-2023, 06:29 PM
On a 09A or even early 09B body build GT-37, that was actually built before the big strike, I'd expect a JT coded wheel most likely dated in the 8/13/70 range. 8/13/70 is a valid date, know of a set that was sold in the last year by a longtime collector & PY member.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
  #38
Old 01-22-2023, 10:28 PM
CraigGT37's Avatar
Thanks Roger. It is an 09A build.
  #39
Old 02-17-2023, 07:05 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Originally Posted by unruhjonny View Post
Can anyone explain for me the HF vs XE 14x6" steel wheels that both seem to be purported in this thread as being for a 1970 GTO?
(I am currently adding info from this thread to my wordpad file on steel wheels)
In my 14x6" steel wheel section, I moved the HF & XE wheels up, and have a description for them, but the following codes are ones I have noted as not currently having any application information:
CC, CZ, EM, EZ, FC, FM, HG, HH, HK, JJ, MH, R, XF(*), XJ, YB, Z6
* = I figured this was a typo on someone's part, and figured maybe the person who wrote this as a 14x6" code, meant to write XE.
The 14x7" steel wheels I have identified on my list are XT, IF, CL, EM, UC TB (I have examples of all but the first one);
I have the following codes as possible 14x7" wheels with no application information:
XG, JZ
If you accidentally reversed those characters, I may be able to help;
I have noted that there was a UA coded 14x6" steel wheel, I have written that this code was used on was 1975+ F-body.
The HK 14 X 6 steel wheels were originally for 68 Firebirds with disc brakes. I am looking for a set or even a single for a car I am restoring.
HG 14 X 6 steel wheels are interesting, I have a couple of sets. One set is for drum brakes and the other is for disc brakes. I would have to do some digging to find the dates on them.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
