Old 03-26-2024, 08:12 PM
Tim Corcoran's Avatar
I wouldn't worry about suspension if it's from a burnout.
Need to know how it's done.
Rolling burnout?
Linelock?
Have a trough to start burnout?
Back into water?
I also wouldn't start in 1st gear for burnout. (or 2nd really)
Then worry about same circumference tires, front to rear tires inline with each other, brakes hanging up on one side or other, so many things.
John
I just hammer it from a dead stop on dry pavement
Tim Corcoran
Old 03-27-2024, 11:40 PM
blueghoast's Avatar
Originally Posted by Tim Corcoran View Post
Adjustable sway bar?
With adjustable links.
I have adjustable upper arms aftermarket lower arms solid bushing on the
lowers air bags and 4-speed brackets and old 3-way adjustable shocks.
I pre-load with my air bags to get the car to go straight and quit a bit of
negetive pinion angle for traction on the street, No front sway bar either.
90-10's up front for shocks. Hope this will help a little.
GT
Old 03-28-2024, 07:52 AM
Formulajones's Avatar
With 3.08's and second gear that's a ton of wheel speed, almost like scating on ice at that point. The rear of the car may drift where ever it wants lol.
Doubtful there is any real cure for it when doing burnouts like that. What's most important is does the car launch nice and straight with sticky tires on a prepped track. That's where suspension tweaking should be done.
Our cars are nice and straight at the track but when we horse around on the street they for sure can be ditch hunters if I'm not careful. Lots of factors play into that like wheel speed, the crown in the road, different types of surfaces. Ya just gotta be on your toes lol.
Me personally I try to keep wheel speed under control with my right foot so the car is easier to catch and manage.
Sounds to me there is probably nothing wrong with your car.
https://youtu.be/XqEydRRRwqE
Old 03-28-2024, 08:56 AM
J.C.you's Avatar
J.C.you J.C.you is offline
You may have one rear brake grabbing on the rear causing this.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 03-28-2024, 10:28 PM
blueghoast's Avatar
X2 Now were hearing the rest of the story. lot of tire speed get u in trouble
GT
Old 03-28-2024, 11:02 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Somebody mentioned double-checking your brakes, which might be a good idea.....unless you've been all over that already and I missed it.
If that's fruitless, then I'd seriously consider getting or borrowing a Go-Pro and mount it where you might be able to spot some unwanted movement in your rear arms or else be able to spot some loose component. Might have to make a few trials with it and switch views depending on the cam model. I dunno.
I almost feel bad for asking this, as I know you're a sharp guy but.....you DID tighten all the control arm bolts with the entire weight of the car on the ground and a reasonably full tank of gas?...Right? You know not to pre-load them, I'm sure...there I said it. Which just gave me an idea. Sure wouldn't hurt to loosen them all a bit, drive around the block moderately, and then retorque? Sure as hell couldn't hurt if you're out of ideas, cuz I am....LOLOL
Funny side story - I have a buddy that's quite good in his class and bracket races an Olds. He's got a GoPro and not only uses it for troubleshooting, but also takes co-workers and friends for a blast. He'll put in the pass seat, mount the cam on the center of his dash, pointing it at their face and then records their reaction. It's a hoot to see, as these folks have obviously NEVER experienced anything like it. It's detuned to run 10-teens and well-sorted. It's how it all started for me....the rush.
Old 03-29-2024, 09:31 AM
ta man ta man is offline
Does it go straight under full traction? With my car I try to avoid burnouts on the street..it can get out of shape real quick..at the track a nice controlled burnout for a short distance can even go slightly crooked, but the car goes down the dragstrip straight and easy every time.
