#381
I have driven a few of the 8.1 K2500 Suburbans and those things devour fuel. 9 mpg highway and around 5 towing! OUCH! At least my 1995 got around 14 empty and 10 towing, (which ironically was the same mileage we got with the borrowed 2014 Cummins over the weekend).
#383
I figured the 8.1 would be bad, but not that bad. It's sad that your 6.5 got only 130k before failure- maybe you'll find it's relatively minor-head gasket? The 5.3 in my 02 Yukon has 257k now, and hardly uses any oil. Original trans too. It's fine for pulling f- bodies on an open trailer, but it's kind of maxed suspension-wise. I'm looking forward to the Macgyver, I mean njsteve, elegant fix to the problem.
#384
I also have a. 5.3 with 174000 miles and I've towed a open trailer and no trouble with engine or transmission . It's a 2000 Silverado 1500 . Hard to beat that engine.
#385
#386
as mentioned earlier, this wheel is a '72 part;
69-71 wheels had nothing; 72 had the wood grain; 73-74 had black. also! 69-70 had a stee outer ring on the wheel, while 71-74 had no ring.
#387
#388
#389
I was talking with the original owner Rick, today on the phone. His wife had sent a nice email a couple days ago, saying how much he loved seeing the photo coverage of the MCACN show and how seeing his car again literally brought tears to his eyes.
When he called today he was quite excited. He had no idea that I had managed to source a full set of the Firestone 500s. I think his exact quote was "You Son of a B@#$h, she looks exactly like how I bought her new!" :-) Anyway, as we were talking about my dilemma with the blown head gasket and/or engine in my 6.5 diesel Suburban, and we were talking about crate engines, he mentioned that back in the 1970s when GM was getting out of anything performance-related, he went to his local Pontiac dealer on Long Island (not Suburban Pontiac) and they happened to have had half a dozen or so, crated Ram Air IV engines. It turns out that Pontiac was sending these out to all the dealerships to get rid of them, forcing them to try to sell them even though they hadn't ordered them. Rick saw the crates and asked what was in them. When he found out, he bought three of them. They were $3,000 a piece. I know what you're thinking, that's was way too high of a price for mid-1970s. But according to Rick these were complete ready to run engine assemblies from carb to distributor, to oil pan. He said the only thing missing were the alternators. He ended up selling them off eventually. |
#390
That's incredible, too bad he didn't pickup more.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#391
too cool!
#392
Well, After sending the original radio out for rebuild and removing the center console and most of the ducting, I replaced the repaired radio ( just needed cleaning and lubrication / adjustment for AM and FM stereo operation), I took the car out for a little test drive. Very COLD here at 65 degrees( kidding) but with clears skies. Anyway, I noticed a gurgling coming from the heater core area. Sounds just like water running through pipes.
Did your heater core " make noises" before it started leaking? I will say that I don't relish replacing the core after reading the process you went through here and it is not leaking. Also, according to my PHS, my car did not come originally with an 8-track player even though there was one installed when I bought it. Is there any interest for what appears to be an original 8-track player and all brackets and wiring? Quote:
The Following User Says Thank You to West Coast GTO For This Useful Post: | ||
#393
The gurgling noise is normal. It's just the water flowing through the system. If it starts coming out and drippng on the carpet, that's a bad sign.
The Following User Says Thank You to njsteve For This Useful Post: | ||
#394
Update on my Suburban: it was the driver's side head gasket that blew out at the same spot they all fail at - right at the far end where the bore is closest to the coolant port. The local diesel shop pulled both heads and are reassembling with new head gaskets, head bolts, etc. Might be back on the road next week. Here's a shot of the head gasket and the head:
#395
I'm glad to hear it was repairable Steve, good luck with the reassembly.
#396
Steve, I guess that can happen from time to time hauling a bunch of Tin Indians so to speak. Kind of ironic.
#397
She lives! I stopped by the diesel place this afternoon and they had already got the truck back together and they were test driving, and checking for any initial leaks, etc. Another day or two to verify everything is up to spec and then I get her back!
#398
Glad you didn't need a new motor--high compression small gasket area seems to be a weakness there. Are there tougher, more modern gaskets that will alleviate that issue?
#399
Not really any other real gasket choice with these engine and their 20 to 1 compression. Due to the design, these things are rather tough on head gaskets. 121,000 miles on the head gaskets seems a pretty good life span. A lot of the diesel guys prefer the Felpro head gaskets but since it was a GM dealer and they warranty their work, they have to use GM parts. He said he'd be happy to put a Felpro head gasket set in but if the gasket fails all that is covered under Felpro's warranty would be the $20 gasket. With the GM head gasket, GM covers the gasket and the labor, too.
They were amazed though at how clean the engine was inside. The one valve cover they replaced was completely shiny inside. Most diesel engines would have some kind of gunk layer but she was clean as a whistle inside. Shows what regular oil changes will do - every 5,000 miles since new with Shell 15w40 Rotella.(These valve covers don't use a gasket, only silicone sealer - so if you bend one prying it off, you should replace it, especially if it is on the turbo side of the engine with all the extra plumbing there.) |
The Following 2 Users Say Thank You to njsteve For This Useful Post: | ||
#400
Finally got the truck back this afternoon. She runs great. Final bill was $3,400. Of that $1100 was for parts - head gaskets, 34 head bolts at $7 apiece, new waterpump (which was the most expensive part) and assorted hoses, serpentine belt, thermostat, gaskets, etc. Since this is a GM dealer all the parts were at list price. But if something goes bad, they cover the part and the labor to remove and reinstall. All in all, I got away reasonably cheaply considering a new long block would have added about $6400 more to that amount.
Before it could leave the dealer, the 80+ year-old owner had to test drive the truck. He has been running the dealership for the last 56 years and nothing leaves without him first approving the work. In case anyone needs some diesel work done, here is a link to their place: http://www.colonialmotorsofnj.com/Au...chburg-NJ.html |
