#421
Good luck, Glenn!
And George also.
#422
So Glenn and I are here at Norwalk and Glenn is just tearing them up! With a different combo on his second pass he runs a 8.01 with a .007 light, talk about knowing how to tune his blower motor!!
He's my Hero! GTO George |
#423
Water grains were very high, I changed timing (added 2 degrees, went against wisdom of the "committee" and went richer, and added air (lot more blower) and got lucky.
Got back to the pits and water was dripping from the rear corner of the right head. Long story short (and several hours) the head bolt was bottoming out. Added a second head bolt washer and it clamp tight. Thought I should do that to the rest of the bolts (should have left it alone) and pulled the threads out of the block on another bolt. Was lucky enough to have a set of cap studs with me, Threaded one in till it bottomed out and torqued the nut and that worked. So....it is bandaided together so we can try again tomorrow, Now I have more work to do when I get home.
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ Last edited by Glenn Lever; 07-15-2017 at 12:01 AM. |
#424
Even with studs I dont think your supposed to bottom them out.
Nice pass. Doing Pontiacs proud. |
#425
I'm thinking in a last chance effort to get a fastener installed he bottomed it out to get every possible thread left in the hole...and it seems to have worked.
I hope it holds and good luck in eliminations! Pontiac to the front!
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#426
It reads headbolt too long not actually clamping head.. you can get torque reading because it's a bolt.
A stud can be bottmed thumb/finger light and work fine. They shouldn't be torqued in threads. When you put washer under nut and torque the stud. Gets pulled up against threads and it's enough to get stud unloaded off bottom. Of course when you loosen nut the stud often wants to come up too. If you want stud tight enough to not do that you but a steel ball under stud so outer edge of stud bottom doesnt stress the holes bottom edge. I prefer blue loctite and just back stud off half turn or so from bottom. |
#427
Some pictures of the new engine, might have something for the quick 16 next year
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ |
#428
Man that's pretty!
#429
Looks great!! Sorta familiar, too.
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#430
Gotta LOVE a Blower engine!!
GTO George |
#431
That looks awesome, Glenn!
Will you be at Norwalk next year?
#432
That is the thought right now so long as it does not interfere with NDRL series or I am so far out of the points it would make no difference.
#433
GTO George |
#434
Quick 16
#435
Great looking engine Glen. What kind/size of blower is on it. What did you think of the IA2 aluminum block ? Fit, finish ect ?
#436
#437
I will run a 7.0 index with NDRL (1/4 mile)
#438
Playing with the BIG Boys............COOL!
GTO George |
#439
We will see how much stuff we can break
#440
Are you running ally? If you are keep your timing under 28 degrees and it shouldn't take more then 12-13 lbs of boost.......you'll be fine!
I don't know if you have them but 2 1/4" zoomies will help. GTO George Last edited by GTOGEORGE; 09-26-2017 at 09:35 PM. |
