Old 08-15-2022, 07:44 AM
DJ455HO DJ455HO is offline
North,
Yes, original springs back in place. Thanks for the nice comments!
Dan
  #422
Old 09-02-2022, 03:54 PM
SD455DJ SD455DJ is offline
Default It's Really Done!
The big 428HO Cat is a running driving car as of today...full of fluids and breathing through the Waldron exhaust system. Dan took some 'outdoor' shots that really show-off the Verdero paint in the sunlight. The stance looks totally factory correct...because it has it's original factory coil springs in it still. It's been a long road, but finally done...enjoy!
Dennis
ID:	597689   Click image for larger version
ID:	597690   Click image for larger version
ID:	597692   Click image for larger version
ID:	597693   Click image for larger version
The Following 6 Users Say Thank You to SD455DJ For This Useful Post:
  #423
Old 09-02-2022, 04:13 PM
1_Wild_Cat's Avatar
Congrats -- That is insanely beautiful. Thanks for taking the time to share the process with the forum - a nice look at the process and what goes into this level of detail.
The Following User Says Thank You to 1_Wild_Cat For This Useful Post:
  #424
Old 09-02-2022, 06:40 PM
muscle_collector's Avatar
man i love that car. what cam did you use in it? any chance of a video of it running? (especially out the exhaust)
The Following User Says Thank You to muscle_collector For This Useful Post:
  #425
Old 09-02-2022, 06:53 PM
CDN2PLS2 CDN2PLS2 is offline
That's Cool! See ya in November.
The Following User Says Thank You to CDN2PLS2 For This Useful Post:
  #426
Old 09-02-2022, 08:14 PM
Stuart's Avatar
Stuart Stuart is offline
Looks great. It's interesting how the color looks in the shade versus in the sun.
The Following User Says Thank You to Stuart For This Useful Post:
  #427
Old 09-03-2022, 10:26 AM
Thanks Gary! The 428 HO dyno'd at 432 hp @ 5000 rpm and 502 lbft torque @ 3700 rpm with a real 068 cam and a true 10.75 to 1 compression through inferior flowing A-body RA manifolds with 2 1/8" outlets into 2 1/2" mandrel headpipes. It should make a little more torque & hp with the factory long branch manifolds. The heads are untouched and the block wasn't decked to preserve the select-fit piston letters stamped into the deck surface adjacent to each bore. The compression was made up with smaller dishes in the custom ordered pistons.
I have a dyno video, but don't know how to put it on You-tube and provide a link to it.
Dennis
ID:	597727   Click image for larger version
Name:	428_390 hp Dynod Clip.jpg
  #428
Old 09-03-2022, 01:31 PM
i noticed you mentioned a "real 068" cam. do you feel the crane reproductions of the cams arent quite like the gm ones? i have compared engines with the replacement cams running (ra3 ra4 and 455ho) beside a car that has not been touched and the original ones all sound a little bit nastier than the ones with an aftermarket replacement. and i never see the 69 ra3 4spd cams reproduced.
  #429
Old 09-03-2022, 02:47 PM
Dan checked, and it the Melling SPC-7 '068' cam which is pretty darn faithful to the original. The Melling new version SPC-3 '744' copy cam has been severely 'watered-down' and has less duration at .100"-.250" than the factory specs. When you compare the new Melling SPC-3 to an original factory 744 and early version Melling 744 you'll quickly see the square shoulders are gone, so it is a bit tamer.
We've actually measured (degreed) factory 068, 744/SD-Y, and 041 cams to compare to the Melling's offerings and they are spot-on, except for the latest '744'/SPC-3 cam.
I will say that we are impressed with the Summit 2800, 2801, and 2802 cams. They are a great value for the money spent and hard to beat when on a budget.
Dennis
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
  #430
Old 09-07-2022, 04:05 PM
joegpho joegpho is offline
Dennis
OK - now I have to figure out why my 428 HO dyno'd at 385 hp and 480 lb-ft of torque.
Is your block bored +.030", like mine is? My pistons are Keith Black and the cam is a Comp Cams XTREME Energy XE262H. I wanted custom pistons but my builder didn't think such were necessary.
Great car, Dennis! See you at Stanton! (I'm bringing my 68 H/O.)
  #431
Old 09-07-2022, 05:04 PM
Hi Joe! Yes, Dan's 428 is +.030" over. I think that cam is holding your engine back from 400+ hp/500 lb-ft torque. Looking forward to seeing you next week (...already! Where did summer go!)!
Dennis
  #432
Old 09-09-2022, 10:47 AM
This morning I grabbed Scott's Intercomp E-Z Weigh Scales to see what the Catalina weighs. It came in where I was hoping. Not much worse that a 70-72 moderately equipped GTO (auto & AC). The car had 9 gallons of fuel in the tank. Dan.
Name:	68 Catalina On Intercomp EZ Scale.jpg
ID:	598145   Click image for larger version
Name:	68 Catalina on Scales.jpg
The Following User Says Thank You to DJ455HO For This Useful Post:
  #433
Old 09-09-2022, 11:17 AM
Thumbs up
So SWEET!
Dan, the '68 Cat going to make its debut next weekend at the track?
Or wait til Nov @ MCACN?
  #434
Old 09-09-2022, 04:39 PM
I'm going to debut it at MCACN in the Full-sized Four Speed class.
Maybe next year it will see the track. I still have some small things to sort out before I feel comfortable having fun with it.
Dan
  #435
Old 09-12-2022, 02:49 PM
Gorgeous end result! 3,986 is surprisingly low, shows the benefit of the sedan (rather than hardtop) bodystyle and low option count. I weighed recently my 69 GTO hardtop (4spd, AC and heavily optioned) and it weighed 3,885 (2,300 front and 1,585 rear corrected to the same fuel level as yours). Obviously things like AC are a big hit and my car has a lot of other weight adding items that yours doesn't like 8 track, stereo two piece radio with rear speaker, power windows, locks, seat and antenna etc. I have a pretty basic 69 Catalina two door hardtop I should weigh, it is a base engine, single exhaust auto trans with power drum brakes and steering, not much else. At the top of the weight spectrum I should weigh my 69 Bonnie wagon, fully loaded, I'd guess its closing in on 5k.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
  #436
Old 09-12-2022, 03:33 PM
Stuart's Avatar
Given the large physical size of cars back then it's easy to assume they were very heavy, but remember they were basically big hollow boxes. There were no side impact beams or 5 mph bumpers or huge amounts of wiring for computer controls or any of that sort of thing.
  #437
Old 09-12-2022, 07:47 PM
True, 69 big cars (and the GP) were the first to get door beams and the post sedan and coupe bodies often used a lighter frame than for the hardtops since the body provided much more rigidity.
1969 Bonnie Cvt
  #438
Old 09-13-2022, 07:46 PM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
Very nice, car looks fantastic
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
  #439
Old 09-14-2022, 10:57 AM
ursusarctos ursusarctos is offline
Send a message via AIM to ursusarctos
joegpho,
Do you have a link to your engine & dyno results?
Was the dyno done with steel headers or iron manifolds (which ones?), and any pipes/mufflers?
Compression ratio?
Corrected to SAE-J-607 (the old gross 60F 29.92 dry sea level)?
I too am wondering why the dyno results are so different.
  #440
Old 11-20-2022, 10:22 PM
Well, the terrible winter weather we had last week prevented us from hauling the Catalina to MCACN. We decided not to risk the just completed Catalina on the icy roads, but still drove down to honor our judging commitment. We were bummed by the rotten weather that zeroed right on this one weekend! A lot of people were disappointed that were hoping to see the finished car in person, but we were equally disappointed too!
We didn't get New York's 77" of snow, but we had a good 10"-12" over the weekend here in West Michigan.
Dennis
