Old 10-03-2016, 09:44 AM
The Boss's Avatar
The Boss The Boss is offline
Sunroof looks different than mine.....I like the car though. Whoever owns Larry's now should buy this one & have a matching pair!
Name:	IMG_3140 (1280x960).jpg
And go racin' in the street.
  #5062
Old 10-09-2016, 10:07 AM
Larry Navarro's Avatar
That is the same as my old SD. The little "plug" just behind the power switch, gives access to insert a wrench to manually operate the roof if power is lost.
  #5063
Old 10-09-2016, 12:09 PM
The Boss's Avatar
Yup!
  #5064
Old 10-31-2016, 10:56 PM
SD73's Avatar
SD73 SD73 is offline
Anyone with a '73 SD auto know what the stock secondary metering rods are in the carb? I've been tweaking my carb and distributor a little bit and I'd like to compare it to what they originally came with.
  #5065
Old 11-01-2016, 01:31 PM
frank.g frank.g is offline
I can look that up when I get home. I know I have that information somewhere. BTW - changing the metering rods was a known performance upgrade right from day 1 on these engines. For my car, on the original sales invoice, the salesman wrote right on the invoice what rods the original owner should order from the parts dept. (He never made the change).
  #5066
Old 11-01-2016, 02:12 PM
For 1973 SD Carb:
Sec Rod
BV
P/N
7040724
Dia of Tip
0.0300
Tip Length
S
This seems to be a good secondary rod?
Most had a huge tip, making it lean at full throttle.
The short tip may have some problem, but not sure on that.
  #5067
Old 11-01-2016, 02:34 PM
SD73's Avatar
Thank you Frank and John! I suspected it was a BV. Mine is not. If any one has a lead on where to find a set I would appreciate the help!
  #5068
Old 11-01-2016, 03:32 PM
The 7040724 is the original part number, might be able to see if Edelbrock or maybe GM has it.
Edelbrock was carrying a lot of parts for the QJet.
But not sure if this one would be.
  #5069
Old 11-01-2016, 04:12 PM
SD73's Avatar
Thanks John, I'll check around for that part number.
I also looked at the website:
http://quadrajetparts.com/used-quadr...67-p-2097.html
Unless I am reading it wrong, it appears the BVs are some of the richest rods out there. Am I misunderstanding that? The thing I do like about the short tip is it really seems to easy in the secondaries well without that bog that sometimes can occur.
  #5070
Old 11-01-2016, 04:23 PM
The CC rods were the hot tip a long time ago, maybe because you couldn't get anything richer than the smog rods then available?
That site had them:
CC rods
I usually chucked a rod that was similar to the CC in a drill and sanded down the tip and some on the angle to get what I needed.
Usually made a huge improvement.
(along with some other tuning)
  #5071
Old 11-01-2016, 05:56 PM
SD73's Avatar
Thanks! I will check those out.
  #5072
Old 11-03-2016, 07:44 PM
SD73's Avatar
Just and FYI to anyone considering the CC's for their SD, Cliff Ruggles advises against them. Below is what he told me and I thought I'd pass on the Info should anyone else be in a situation for restoring or tuning their carbs.
"CC’s are HORRIBLE in those carbs, small/long tips but really fat on the upper section, we avoid them."
I'm getting some stock BV's and a hair richer CB's from him. He can also machine up a set on his lathe too if anyone needs a set for their beast.
  #5073
Old 11-08-2016, 12:00 AM
sdbob sdbob is online now
Can SD exhaust manifolds be taken off down past frame and starter,and oil filter? I'm replacing my oem with new castings. Oem have cracks.
  #5074
Old 11-08-2016, 12:30 AM
sd7369's Avatar
sd7369 sd7369 is offline
I have always had to remove the filter adapter and lower the starter to remove them and in a timely manner for any cast iron header. Sometimes you can jack the engine up high enough one side at a time after you remove the long mount bolt to get them out if you don't have ac
  #5075
Old 11-08-2016, 08:54 AM
No air.When I ordered min. options. Thanks. Still original exhaust I didn't want to cut studs to remove pipes.But I guess I'll have to.Thanks. I did notice the sfront springs still have tags on them,rear drums have the stickers.
  #5076
Old 11-16-2016, 12:06 PM
F9driver's Avatar
F9driver F9driver is offline
Default '73 SD Fuel Pump
Good morning guys, I am new to the forum and new to the SD world...I have had several 1973 T/A's over the last 30 yrs or so and finally clawed, scraped and traded my way into my dream car...a 1973 Buccaneer Red SD. I have enjoyed it this last year and I am collecting pieces and parts for a future complete restoration. But for now I'm having a blast driving it around...
I believe the fuel pump just went south on me and I am looking for a good quality replacement to drive around with on today's gas...any suggestions on a direction or specific pump for this motor would be greatly appreciated! I am sure I will tap the knowledge of this group in the future as I am not the most mechanically inclined guy, I have some questions on this car and I look forward to making it as close to original as I can. Thanks in advance,
CLW
  #5077
Old 11-16-2016, 02:27 PM
Formulabruce's Avatar
Its the "big Can type" There are some by airtex and others, make SURE its brand new and mentions it can handle alcohol. I bought one recently from ebay because it had the info about new materials on. I think Orileys has the good ones too. Welcome to PY
  #5078
Old 11-16-2016, 03:02 PM
CLW, Welcome to PY!
And congrats on the SD!
  #5079
Old 11-16-2016, 09:51 PM
SD73's Avatar
Welcome Keith!
  #5080
Old 11-17-2016, 08:15 AM
Welcome. I had my original go bad also. Install oem,thinking better to get new pump for fuels today.
