#41
I have a 1968 firebird sprint OHC 6: looking for 6cy fan shroud, frame & engine mounts, 2spd shifter, st300 transmission, steering wheel, factory radio
Richard swederlj@gmail.com |
#42
I'm looking for the bracket that the hood release cable handle is attached to on a 79 T/A. The bracket attaches under the nose of the front bumper, direct center, lined up with the red Pontiac arrow crest. Do you have this bracket by chance?
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
#43
Do you have a 4 speed console for a 68?
#44
I sold the 4-speed console about a month ago.
#45
Do you have the hinge covers for the seats and the track covers ?
Thank You Lanny |
#46
Do you have rear tail light panels and gas door for a '79 T/A?
#47
PM sent.
#48
Pontiac Iron- PM sent
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#49
I still have a garage full of pontiac parts for sale.
#50
79 T/A Tilt, " Non Cruise" Steering Column ??
#51
69 FB Steering column rod to Swivel for reverse lockout control. Swivel. Set of Convertible hold downs with Black thumb breaks. What do you have in OHC?
#52
Right now I found a 68 250 block and putting my 1966 sprint head, 4bbl, intake and exhaust on it. It needs a new cam "e" or I will send mine off to Clifford and have it machined to match "e" cam, have to bore .60 over and putting in new forged pistons, lifters/lash adjusters and followers. Had a found a good complete 230 67 block/66 head but wanted to try to get the engine as close to a 68 250 factory engine as possible. So that is the plan now.
#53
Any power seat units?
TODD |
#54
nope.
#55
you have any JC rally wheels or know of where to fing the air breather for 68 4 bbl OHC engine?
#56
The 1969 firebird 400 hood is sold!
#57
Lots of parts left if anyone is interested.
#58
Sent PM
Matt --------------------------------- '68 Firebird - work in progress |
#59
Looking for a heater assembly that works and is in good condition.
John 1968 Firebird Convertible Tsawwassen B.C. Canada |
#60
looking for a 71-72 formula ram air ,air cleaner, any luck?
