THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#41
I foresee "oil hoarding".
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
The Following User Says Thank You to Old Goat Racer For This Useful Post: | ||
#42
Any of the good by pass oil filters, Amsoil, Frantz (what I have), just google by pass oil filters and you'll find options. They aren't cheap, but they'll pay back in a few years just on oil savings.
Engine wear minimization can't really be measured in dollars and cents. Filtering to a finer standard should minimize engine wear 6-8 times of what a standard OEM filter system can do. |
#43
![]() Quote:
I guess it may boil down to which is more readily available (no pun intended). I suppose the Valvoline might be better for cold fall days. Both are synthetic.
1970 GTO (Granada Gold) - 400 / TH400 |
#44
![]() Quote:
The Lucas Oil additive is labeled as a break-in additive but they say you should also use it with any oil at every oil change. One could see why they would want that. They probably want you to shave with it too. Anyway, there are all sorts of things going on right now but there is really a fairly high demand for these products (I think) and when there is demand, someone usually responds. Now, if it gets legislated out of existence that's another thing but it seems like what the manufactures' do to get around stuff like that is to label the product for "off road use only".
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#45
Isn’t that what synthetic is?
#46
Here is a synopsis of what synthetic lubricants can start out as, it can come from many sources, crude, natural gas, etc.
https://www.researchgate.net/publica...s_and_Products It's then improved to raise the upper temperature oxidation level of just mineral oil, and to lower the pour points at the low end of the temperature spectrum. There are different formulas, additives, and base stocks used by different companies. The molecular chains are modified in different ways by different processes, not all oil companies use the same formulas to arrive at a synthetic lubricant, they're proprietary. Natural gas is a base stock used by some companies, but not all companies. natural gas is a less dirty base stock, and requires less processing to be suitable for lubricant production. Pennzoil uses mostly natural gas as their base stock, their claim is it requires less processing as it's less contaminated to begin with. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
#47
My local NAPA had Lucas 10-40 on the shelf. Hot rod,classic car oil. I didn't pay much attention to it at the time
The Following User Says Thank You to straycat For This Useful Post: | ||
#48
![]() Quote:
Some oils have the ZDDP levels for flat tappet cams, others aren't designed for them. 800 is too low. Any of the one's I specifically listed will work for your desired application. A 0W40 and 5W40 will cover everything a 10W40 or 10W30 will cover, only better. For those that want to use a 20W50, the 15W50 will cover, only better. I've run the 0W40 in my wife's '72 Camaro for nearly 20 years. I've run 15W50 in my 'GTO since I put the 462 in 2013. I've driven both cars in the winter months as even with the 15W50 as it has a pour point much lower than any 10W30 or 10W40 conventional oil. The GTO has been driven in all 12 months of the year (nice sunny days only during the winter). |
#49
![]() Quote:
72 Bird |
#50
I'm not too worried that there will be any long term shortage, but you never know. So, I just ordered 58 quarts of Lucas Hot Rod and Classic oil from Summit. It's mineral obviously and it has 2100 ppm of zinc, plus moly and phosphorus. It's mostly 5 quart jugs but I got some single quart size too. I think I prefer the quart size but you do save a lot with the larger size. I should be good for a while.
#51
Anybody else notice back in the day that 10-40 left more sludge in engines than 10-30 even when religiously changed every 3K miles? I always noticed that when popping a valve cover off to change a gasket or adjust valves. It didn't matter what brand oil was used although Pennzoil and Qaker State were notorious for sludging up engines back then.
#52
Real "full synthetic " is NOT ASH BASED. Ash based is carbon based.
Anyway, if you need thicker oil there is always STP. !
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
#53
No way would I ever use 15w-40 in a gas engine. So don't argue with me and give reasons why I should. It AIN'T gonna happen. Ever!
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#54
I put an re-manufactured engine in my friends truck 6 years ago and he's been using 15W40 ever since. It doesn't burn oil and has "0" blow by. I use 15W40 in my 95 4.0 Jeep GC same deal. I do live where it's warm all the time though.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
#55
My local Walmart has 5qt 10w40 Havoline in a BOX - like a Wine Box.
Standard Dino Oil Very economical that way too - was cheaper than their SuperTech mystery oil. I used it last month as a "Clean Out/Flush Oil" in an old van i recently bought. They also offer Mobil 1 10w40 High Mileage Synthetic 5qt. That is what is in the van now, and will continue with. My local Walmart didn't stock the 10w40 Mobil 1 , next town over had it in stock , but went the lazy route and had it shipped to home. 2 days later it was here. You can probably have either of those Shipped-to-Home from Walmart, anywhere you live in the Great48 . Dino oil still has market demand from leakers and burners , and cheapies I've always been religious to Havoline & Valvoline When Mobil 1 became affordable , i switched to it. Their high mileage flavor has healed minor/medium leaks in several of my cars. ![]() |
