#41
[QUOTE=Milepost;4613327]
[QUOTE=Half-Inch Stud;4652539]
or a 1/2 angle of 9 degrees. Assume 9 degrees full angle. Tom Vaught
#43
[QUOTE=Tom Vaught;4653157]
Proud member of the CV-1 "Banned of Brothers" ![]() |
#44
My Dynomation software shows that an opening 30% larger at the plenum - 10.5 in up from valve is 1.7degree taper ?? if I play with the software and get anywhere close to a 9 degree set up - power suffers ??? Is it just the way we here are calculating this -- or ???
#45
![]() Quote:
#46
I have messued it - and the pot along with the intake is aprox 10.5 - If i remember right
#47
measured and port - got in a hurry
#48
I can understand that! ....Ya just got to take advantage of those sunny days in Seattle! LOL Thanks Curt
#49
[QUOTE=Milepost;4653612]Been told the taper is usually close to about 4 degrees.
![]() Agree, that is why I was asking HIS about his number. I like the CSA percentage change deal much better. Tom Vaught
#50
Taper is not a cut and dry thing by any means. Every motor will tolerate taper levels differently, depending on many factors.
There are some motors that have an 80%+ increase in area in less than 3 inches in the runner. Programs that suggest runner lengths, wile good are only so good. Most all of them are factored at a standard temp or atmosphere, and we dont race at those temps that they are using as standard. The speed of sound is relative to the local atmosphere and temp , and we are tuning sound waves. I wish all this could be simplified or generalized like some of you are trying to make it, but it just cant ![]() And even the best manifold guys cant nail it first shot, if you want it right you have to test , test , test. |
#51
Guess I would say I have learned alot by making one. Bottom of the runner intersects the head at 90°. Top of runner is at 5°. 6.8° on the side with between the ports at 0°. Well I have 25% tapper to my ports. Think it will make more power than a Victor? To bad it's just a "green" E85 bracket car. Zoom that unit!
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
#52
![]() Quote:
... and the best part, they sell them off for scrap to local guys that dont have a clue what they are for, except weight ... ![]() ... there many factors to take into consideration, some of which are intake port centerline to manifold centerline convergence angle, and convergence of plenum entries, in reference to pulse sharing, distance between inlet radius at the plenum entry, distance between inlet radius and surrounding walls, you could spend a bunch of time on one, and find out what the engine doesnt want, lol ... ... another area often over looked is surface texture ... i just love manifolds ... ![]() |
#53
![]() Quote:
#54
Almost done. Went with 1095 sleeves I had to have someone make for me since I can't buy them anymore. I also copied what was done to my E85 carb. Anyone have a tune for the carbs they would like to help me with?
#55
Sorry to leave you all hanging. 4.5 deg & 4.5 deg. It's just a starting point, not the be-all, end-all.
Ya know since the port height is 2x the width, there can be great debate on flaring the width faster to yield a round inlet vs keeping the "squareness" for focused plenum. Runner taper helps feed the most mass-volume through the head (short-turn) and CYL expanse. Let's conside how to feed those RUNNERS; ================================================== = Me thinks the small open plenum is a frustration. Basic goal is to have a steady stream through the venturis, yet momentum preservation pre-venturi, and post venturi seems and typicall wholly ruined on most vehicles. Does anybody have performance data (dyno or track) on "torque tubes" on the carb airhorn? Once that difference is seen, then the plenum design will have a similar design importance. Seems it would be fun and profitable to debate small single-plane plenums vs long& large plenums(Wenzler, DNE, bathtub, OFFYL Dual Quad), when run with a single carb having the largest throttle plate CSA(CFM rating?). |
#56
It's alive! I need to rig up something better for the linkage. The pedal is rock hard and I think the cable is going to break even without return springs hooked up yet.
#57
![]() Quote:
Like the Tarantula ( I think) bbc intake from back in the day. |
#58
![]() Quote:
#2 is the most forward cylinder on a Pontiac. It also screws up machine shop guys trying to install rods on pistons. Tom Vaught
#59
Man that looks AWESOME! Can't wait to hear how it runs!
#60
We ran into the same problem. We bent up a some 1/4" round stock and threaded the ends for heim joints. Worked perfect.
