#41
Count me in.
I drive mine every single day, plus a 3000 mile round trip to the drag strip to run 120 mph 1/4s. I LOVE my blown Pontiac, -Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5 1933, 1934, 1936 and 1940 Fords, also Pontiac powered. |
#42
#43
Thanks Jack, I guess I'll have to find an alternate use for the current armasteel. If the armasteel crank was stock I wouldnt question what to use. But someone back in the day spent alot of time with it. Found this motor in Fulton Ny a few years ago and almost passed it up as the outside was filthy dented stock sheetmetal etc.. BUT, the ports were heavily taped and it was free (in addition to the 59 Catalina with the original 420a trpower motor in it that the guy sold me.) Later inspection found JE domes(4.12 bore), SD rods, ported heads(60 vintage), Isky E2 cam, edge orrifice solids, aluminum flywheel, and nicely detailed crank. No signs of the engine ever being run. Bearings etc. not a mark, no carbon anywhere. Bearings dated 1964. Dont know who built it but the Decks are stamped JB on the front. The only builder I know from that era was in Rome (John Bravo) and he said he never put his initials on anything. Its a heck of a foundation to work with for sure. Obviously for a blower motor the pistons will have to go and I'm not about to test the early SD rods.
#44
By the way Brian thanks for the Dyers reminder, I forgot about them.
#46
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
#47
Headed for the Seven's!
Dude,
I am still headed for the 7's, getting closer all the time. Just seems like I'm always adding weight to it! NHRA always seems to be changing the rules, seems like they get a kick back from the safty equipment manufactuers. I werighed it at Norwalk, came in at 2,990 with me in it ...........pretty heavey for a tube chassie car! Anyways just came back from the 10 Grand Nationals at Norwalk, raced all 3 days, engine never missed a beat! Ran high 8.30's to very low 8.40's at 159 - 161 MPH. Now thats running the blower at only 3% over ................that's 7 lbs of boost on my Digital boost gauge. Pretty DARN impressive, leaving the line at only 3,500 rpms with a best of 1.17 60 foot at 82 plus degree temps with a head wind all weekend. I now know that I have plenty of power with the KRE High Ports and the MR-1 block. I put double digit passes on it and the engine ran flawlessly and consistent. I learned a lot in the 3 days I raced it. Thanks again to KRE for all of their help! |
#48
WHATS THE DIFFERENCE between 6-71 and 14-71, size of your winkie?
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
#49
Tiki,
I posted this info once before for Pontiac Jack: Each inch of rotor has a volume of 27.2" Every blower has a different length. A 6-71 has a 15" long rotor pack so times 27.2 = 408 cid A 8-71 has a 16" long rotor pack so times 27.2 = 435 cid A 10-71 has a 17" long rotor pack so times 27.2 = 462 cid A 12-71 has a 18" long rotor pack so times 27.2 = 489 cid A 14-71 has a 19" long rotor pack so times 27.2 = 516 cid A 14-71 is about 25% larger vs a 6-71. Tom V.
#50
Tom, Got any info on 3-71,4-71 & 4-53???
#51
A high helix offers what, less pulsations, more consistent pressure?
Gregg V. |
#52
Standard-helix = 60 degree twist on rotors. At the same driven rate, the hi-helix offers more boost potential. Spin it slower for like boost as a standard with less adiabatic pumping losses.
#53
(If you didn't "see" the sarcasm in my post, check out some pictures of my Roots-blown Pontiacs)
#54
Anybody really understand rotor helix in Roots blowers?
#55
As far as I know they still run a roots type, just much larger than they used to be............maybe Im missing something.
#56
Is a PSI still considered a roots? Who's running a roots, hi helix or a PSI, which classes?
Gregg V. |
#57
They still run roots type blowers in Top Fuel...that's all the rules will allow. Whipple type blowers aren't legal, even though they're more efficient, largely because the blowers creator and company owner will not pay NHRA and SFI the exorbitant fees involved with having a part safety spec'd by SFI for use in competition.
#58
#59
Brian- If I remember right (questionable!), high-helix blowers showed up before the "retrofit" deal did. If so, then I'm just as puzzled as ever about how the higher helix improves flow. And doesn't Dyers or somebody still sell straight-rotor (zero helix) blowers? But, come to think of it, they were two-lobe, weren't they- which would increase the displacement, so that would just confuse any direct comparison.
#60
