Old 04-06-2008, 06:44 PM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
Originally Posted by keepat
Most of the underside of the T/A is cleaned, red oxide primer, and clear coated! Now it time for the rear aft. Most of the work is fun, but this under the car cleaning stuff suck! At what point would the black paint for the firewall start from the bottom of the car? a picture would be great! Thanks
Pat
What paint did you use for the red primer. And is it orange red or brown red. Pictures sometimes tend to look different color?
Thanks - looks great!
Bub
1974 400 4 speed
  #42
Old 04-07-2008, 05:14 PM
keepat's Avatar
keepat keepat is offline
Bub,
I used Dupli-Color red oxide it’s a shade or two on the red side but when I put the low-gloss clear over the red oxide it looks closer to the original paint on the bottom of my car
Thanks!
Pat
  #43
Old 04-09-2008, 11:08 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
lookin' good.
where in maryland are you?
if ever need stuff/tech drop by if you're local; my shop's in rockville.
-mike
is this thing on?
  #44
Old 04-10-2008, 01:43 AM
keepat's Avatar
Originally Posted by speedshopmike
lookin' good.
-mike
Mike, I'm in Edgewater, MD just south of Annapolis. Next time I'm in Rockville I'll stop in!
Thanks!
Pat
  #45
Old 04-29-2008, 11:30 PM
keepat's Avatar
I finished the bottom of my T/A, what a pain in the backside! The question/request for today is. How is the lower edge of the rear tail panel shaped at each end where it meets the quarters? A picture of the bottom edge of the tail panel / valance would be great!
Thanks!
Pat
The Following User Says Thank You to keepat For This Useful Post:
  #46
Old 04-30-2008, 09:52 AM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Pat, is this what you need, I took it last year at 'Firebirds on the lawn' so I could get mine right. Regards Bruce.
1970 T/A RA3 #'s match.
The Following User Says Thank You to GRNMTGOAT For This Useful Post:
  #47
Old 04-30-2008, 11:45 AM
keepat's Avatar
Yes that's what I'm looking for! How they bent the bottom edge to make room for the exhaust. Thanks! Any other pics would be great!
Pat
  #48
Old 04-30-2008, 06:04 PM
njsteve's Avatar
njsteve njsteve is offline
Here is a shot of the area you are looking for.
  #49
Old 04-30-2008, 08:22 PM
Almost looks like the tip is touching the sheetmetal. I think there may be a spec for that in either the assembly or the service manual, but it should be a minimum of an inch clearance - exhaust pipes can move around a lot.
  #50
Old 04-30-2008, 10:29 PM
keepat's Avatar
Steve, that's the pic! Thank you!
Pat
  #51
Old 05-11-2008, 11:43 PM
keepat's Avatar
I converted my drivers side 1981 dated fender to look like a 72 T/A fender this weekend. Cut some rust out of the bottom right fender and welded a small patch in. Both fenders are ready for the body shop! I also would like to give a big thumbs up to Butler Performance for the great looking rotating assembly I received last week, Awesome stuff!
Pat
  #52
Old 05-12-2008, 01:39 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
nice work!
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #53
Old 05-12-2008, 10:16 PM
ta-kid ta-kid is offline
Pat
Nice job on creativity on the fender.I would of proably went with more of a flat satin finish on the red oxide finish on the undercarriage,instead of the gloss finish,but it looks like its coming along fine.Your boy still giving you his expert assistance.
  #54
Old 05-12-2008, 10:50 PM
keepat's Avatar
Ta-Kid
Thanks, I used a low gloss clear and it very close to the original color and gloss that was under the seam sealer. I think the flash of the camera makes it look more like gloss? When I work with anything that puts out fumes I keep Kurt out of the garage, but when it’s time to put the motor back together he will be there!
Pat
  #55
Old 05-13-2008, 10:39 AM
Understand on the flash and on the fumes.This is the part I enjoy the most myself ,the restoration.Once its all done and I drive it a bit ,show it off,I am out looking for my next project.I get bored easy.Even at car shows I do not look at all the nice cars,just the pontiacs and the rare different cars like corvairs etcc....No disrespect to the other cars,they are all nice.
  #56
Old 05-13-2008, 10:46 AM
Just a suggestion or a heads up on the transmission tunnel,some firebirds came with some heavy undercoating spray'd in the top part of the tunnel and down somewhat on both sides.More of a sound proof for the tranny noise then anything.Your call wether you want to do that or not.
  #57
Old 05-13-2008, 03:58 PM
njsteve's Avatar
Here is the original trans tunnel in my 72. Nothing in the back section but a bunch of sloppily sprayed undercoating near the shifter opening,
ID:	132563   Click image for larger version
ID:	132564   Click image for larger version
ID:	132565   Click image for larger version
  #58
Old 05-13-2008, 04:47 PM
keepat's Avatar
I'm with you on enjoying the restoration more then using the car. I got back in to car two ago, rebuilding a 68 hemi charger. And love it! Before that it had been over 14 years since my last car project a frame off 64 GTO. Work, kids, and time pull me from the car seen. Add that up it equals $$$. But I'm back and like you I’m thinking about my next car project and I'm not even 1/2 way into the T/A. I hope my son Kurt gets hooked along the way!
Thanks!
Pat
  #59
Old 05-19-2008, 01:34 PM
keepat's Avatar
I need to replace the right side door skin, no rust just too many dents. My question for today is, how’s the fit of the repro door skins, and has any one replaced one?
Pat
  #60
Old 05-19-2008, 10:37 PM
keepat's Avatar
Big thumbs up to Bill in TN for the awesome restoration job he did on my brake booster & master cylinder. Thank you!
